Scratch Build – In Progress Project: LAN Truck (My First Mod)
Discussion in 'Project Logs' started by Ant, 6 Jul 2004.
  1. Enak
    Enak Also known as Kane
    23 Jul 2002
    Just had a great idea :idea: ... Build a projector into the trailer!!! :D
    Kind of like your own drive in movie :clap:
    Comon, get to it! :dremel: You're not working fast enough!
  2. irsekz
    irsekz What's a Dremel?
    23 Feb 2004
    looks awesome it would of been cool tho to have it so when the CD tray opened the back doors flew open... ultimate stealth job :D i cant wait to see it done
  3. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    so did you really get a free Ipod, Irsekz?? just wondering
  4. Cecil-San
    Cecil-San What's a Dremel?
    10 Dec 2003
    Haha..thought I'd seen all the vehicular type w/ the various Hummers and sports cars....definatly very cool tho..
    Are you gonna cut a window for the LCD? or just have the side removed??
    If your just gonna remove the side...try to find a way to cover up all the toher electronics....or just have one section of the side removable??
    keep it up btw
  5. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    Man you have to take video the first time you drive this thing into a lan!!
  6. Ant
    Ant What's a Dremel?
    15 Jan 2004
    Hi just a quick picy of how the truck is looking with the side panel now finally on, will be putting some pics of how it got to this later, but going off for a week now so will post when i get back!
    I have also moved the front usb ports that would be at the front of the case to just above the crash prtects on the truck. ( where the cables are going into)
    This is just a test out of abs, will be machining it out of the ali piece I have later.
    Ant
  7. milgo
    milgo What's a Dremel?
    12 Jan 2004
    looks great :D
  8. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    So what about the 7" lcd next to the radio thing? Do you have yet to cut it out?
  9. Enak
    23 Jul 2002
    Ant's planning to get the TFT when he's back from his hols!
    There's a couple of little bits he needs to tidy up on the side panel then he can cut the final version (out of aluminium).
  10. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    that looks sooooo awesome!!!!! i have a question for you....can you still drive it around using the controller and stuff? that is cool if you can because you can come rolling up at quakecon and not have to carry your PC at all. :thumb: :thumb: :thumb: props to my modding brother!! :rock:
  11. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    ha that is so sweet, what you should do is make a second trailer that holds all of the extra crap that us gamers carry around, or even make it a little "mini-fridge" and have a case of bawls in there or somthing, or just a spot to hold your keyboard mouse etc. Mod looks very very nice, glad i followed turning out so sexy
  12. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    Man that is cool. What was your budget on this? Hey you should pick up some of those spinners and have a pimp tricked truck like that hummer :rock:
    [REDNECK] Tha'd thang goddah hemmie? [/REDNECK]
    :p
    -Rob
  13. Enak
    23 Jul 2002
    Here's the video!
  14. MrBurritoMan
    27 Jun 2004
    that is awe-freaking-some!!
  15. Ant
    15 Jan 2004
    Hi all
    Thought i would post up a better video clip of the truck driving! :D Truck video clip I have now Ordered the 7 inch tft so hopefully will post up some progress shots towards end of the week.
    To stop the truck from rolling off the desk, which is a possibility i use some wheel chocks, which works very well!
    Budget on this has not really come into it as i needed a 2nd pc to take out and about. So far I have spent about £800, but I have not got alot to do, to get it finished! :D
    Ant
  16. Bones
    Bones What's a Dremel?
    14 Nov 2003
    Great Mod!! And it looks awesome driving around. Would rock to drive that into a lanparty. Keep up the good work! And cant wait for more!
  17. Enak
    23 Jul 2002
    Shame about the video quality, but a cool vid none the less!
  18. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    No comment. :hip:
  19. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    looking awsome ant :D really and inspiring piece can't wait to see whats to come :hip:
  20. MRKIKKOMAN5645
    MRKIKKOMAN5645 What's a Dremel?
    2 Aug 2004
    %$!@in awesome man makes me wanna try somethin really cool.. last time that happened i spent about 50 bucks and couldnt return any of it
