Scratch Build – In Progress Project: LAN Truck (My First Mod)
Discussion in 'Project Logs' started by Ant, 6 Jul 2004.
  1. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    omgizzle you didnt tell me about the ps and xb ports :eeek:
    WOW!!!!!!!!!!!!!!!!!!!! :hip:
  2. Death Reaper
    Death Reaper What's a Dremel?
    27 Jul 2004
    Words can not even describe that...
    Amazing! <--Still, it doesn't describe it
    Good job man!
    Regards,
  3. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    can't wait to see the completed project.so far it looks really kool.
  4. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    Excellent mod, especially for your first, you and robster should have a drag....although i rekon the hummer has more grunt :p
    Cheers
  5. Buzku
    Buzku What's a Dremel?
    7 May 2004
    OMFG! That is absolutely awesome! :rock:
  6. Ant
    Ant What's a Dremel?
    15 Jan 2004
    Thanks for the positive feedback :rock: The TFT goes in! final put it together and perfect fit first time :D
    and a close up of the side panel!
    Just have to work out the posistion of the speakers now!
    Also got the paint mixed today so its getting time to strip it all down again take some internal shots and spray up. Just the trailer to finish off now and get all the cables fitted in!
    Ant
  7. Incorpirate
    2 Jan 2004
    OMFG!!! :eeek:
    **** ant, thats emence
  8. Death Reaper
    27 Jul 2004
    Holy...crap..can I steal that from you? Seriously...that is...godly!
    I want more pics! :rock:
    Regards,
  9. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    Haven't posted much but had to on this one, You should definitely consider a Optimus Prime (Transformers) paintjob, I think that'd look amazing on it
  10. Josh2k3
    Josh2k3 What's a Dremel?
    4 May 2004
    yeah I totally on u - would b sweet
    btw - arent u gonna cover up the space between the cabin and the back of the car cause u still can c a bit of the TFT and I dont think that is how it supposed 2 be?
  11. TheMuffinMan
    26 Apr 2004
    I think it'd look sweet
  12. Ant
    15 Jan 2004
    Hi all Optimus prime idea is pretty cool although would look better on a usa truck! that is my plan for a normal rc truck :D The panel behind the cab is indeed missing, it is only just put together for test fitting as its all got to be taken apart to be sprayed!
    Ant
    (viewing on the Lan Truck at the mo :D )
  13. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    ha ha ha that is sweet i love Tranformer's
    and on a late note, we got a CNC mill, and Lathe that are table top, they are like the size and a computer panel in base size and about 2 to around 3 feet tall, that is the smallest i have seen and it workes really good for what they need
  14. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    Very, very nice job man. How much did that 7inch TFT cost ya?
  15. Enak
    Enak Also known as Kane
    23 Jul 2002
    Do a search on Ebay for "Lilliput touch".
  16. TheMuffinMan
    26 Apr 2004
    Transformers are you friend, and in any case, can't wait to see this baby finished looks amazing
  17. nessaizfit
    nessaizfit What's a Dremel?
    10 Aug 2004
    Nice mod, keep up the good work! Wot spec is the machine in the back coz iv not seen wot the spec is yet unless its me bein think lol.
  18. lillbrorsan
    lillbrorsan What's a Dremel?
    26 May 2004
    Best mod i've ever seen!!!!!
    And it's your first one!!!!!
    GJ!!!
  19. Ant
    15 Jan 2004
    Hi all, just thought i would post a picy of the parts all sprayed up!
    Just got to put the truck all back together now! some more pics on monday of the rebuild!
    Ant
  20. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    that paint you used looks really cool, i like it, (could you perhaps tell us what color it is??)
