Scratch Build – In Progress Project: LAN Truck (My First Mod)
Discussion in 'Project Logs' started by Ant, 6 Jul 2004.
  1. Ant
    Ant What's a Dremel?
    15 Jan 2004
    hi, the colour that the truck is sprayed is BMW Baltic Blue. pics tommorrow of it reassembled!
    Ant
  2. Ant
    15 Jan 2004
    Hi all just posting a picy of the truck how it looks at the mo (wanted to show you all!). I am going to post all the pics leading to this point but it takes time to resample them all!
    The angle is not the best in this one, but saving the good shots for build post :D
    Ant
  3. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    :jawdrop: :jawdrop: :jawdrop:
    dude....duuuuude.....man is that sweet
    love the color.....gives it ALOT of class....
    cant wait for the rest.
    did you think it would turn out this good?????? :eeek:
  4. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    pfffffffffffft man thats awsome :rock:
  5. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    Sweet, really nice colour you got there.
  6. Ant
    15 Jan 2004
    Hi all
    Sorry been awhile to update with pictures, but here they are enjoy:
    Under View of the truck
    Quick test fit to see if it all ok.
    Close up view of the back panel
    Motherboard shot, cable wrap used to tidy the cables
    All the parts for right hand side panel (the TFT/ LCD screen) fitted to the polycarb frame
    Placing the power supply back in
    Trailer chassis attached to make sure all at the same height!
    Right hand panel with parts fitted (cover in place)
    Right hand panel Cover on tft removed
    Looking from behind the right hand panel
    The jungle of cables inside the truck, space is tight!
    Motherboard/ Top panel placed into position
    Looking from behind the cab
    Testing the truck, all working after the rebuild
    Will post some more shots soon, just got to get some decent shots of it put together. Still got to strip it down thou to wire the xbox ports in!
    Ant
  7. Incorpirate
    2 Jan 2004
    awsome work ant :D love it... cant wait for more pics of it totaly finished
  8. Springs
    Springs Boing boing
    29 Aug 2004
    just woundering where did ya get the screen and the LCD from?
  9. crash32953295@msn.
    crash32953295@msn. What's a Dremel?
    2 Aug 2004
    yea really nice, did you use a mini atx board and what psu u using, yea i also want to know wat lcd it is as well
  10. Ant
    15 Jan 2004
    Hi The lcd came with the MSI Mega PC 651 as did the motherboard, and the PSU which is a 200w supply! Which when the pc is not on powers the cd rom and lcd and acts like a HIFI. The TFT is the LILLIPUT 7" TOUCHscreen VGA.
    Ant
  11. Springs
    Springs Boing boing
    29 Aug 2004
    ahhh all came out of 1 computer... still a great mod..
    how much did that conputer put u back?
  12. Ant
    15 Jan 2004
    the Barebones system only cost £220 so perfect for the job! :D
    Ant
  13. gigik
    gigik What's a Dremel?
    18 Aug 2004
    very very nice
    btw ihmo 2 displays is too much on one side :eeek:
  14. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    You can't seriously mean that this is your first mod, it's so sweet. Maybe it's your first mod, but definately not your first interaction with self buildt pc's!
  15. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    its not hard :p
    anyways, awesome project! keep it up
  16. Ant
    15 Jan 2004
    Its my first attempt at building my own PC case rather then buying one. I have got a Lian-li case with a watercooled setup and the Aquarium
    Here is a shot of the truck almost sorted got to do a few more bits yet to it!
    Ant
  17. Springs
    Springs Boing boing
    29 Aug 2004
    he he he nice aquarium
    btw where did u buy ur plexi?
  18. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Whats in the back of the truck?
    Computer parts.
    Oh cool you deliver computer parts!
    No, no no. Its a computer :D
    Whats in the very back of the truck (not where you placed the shuttle) The second hang on thingy...?
  19. Ant
    15 Jan 2004
    Hi I get the polycarb out of a skip!, Surprising what the local plastic company calls offcuts! :eeek: The Trailer carrys the keyboard and all the other bits required to operate the pc. Which means I dont have to carry anything when I go to lan's!
    Ant
  20. Mosha
    31 Jul 2004
    Somebody is going to be rolling in style! :rock:
