Project : LAN -::Y::-
Discussion in 'Project Logs' started by yodasarmpit, 15 Sep 2003.
  1. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    As Project -::Y::- nears completion I've decided to rework the first case that I modded.
    It was just a generic beige thing to start with before I cut out a couple of windows, a blowhole and painted it metalic blue.(sometime last year) http://forums.bit-tech.net/showthread.php?s=&threadid=20882
    Here's how it stands right now.
    When its finished it should look like a smaller version of Project -::Y::-
    The case will be painted in a metalic grey, the closest I've found is Plasti-Kote "pewter" spray paint.
    I'll also be tinting the windows, adding a rheobus and small LCD
    I'll just be sticking to air cooling for this one.
    Dont be expecting many updates just yet, but hopefully there will be a few soon :dremel:
  2. Penguin4x4
    Penguin4x4 What's a Dremel?
    31 Jan 2003
    So shall we call you the Three -::Y::-'s Man? :worried: :hehe: :lol: :D
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    One -::Y::- and two not started, but yeh if you want :D :lol: :D
  4. CsM
    CsM What's a Dremel?
    21 Jul 2003
    it's going to look good
    if your building a new case u wont need your old 1 then i'll have it off u LOL :D :D :lol: :lol:
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    But as broadband is finally going to be coming my way, I'll be needing a file server/download/pr0n machine :D
    I might even manage to finish it in time for the exchange upgrade (about 3-4 months)
  6. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    your 1st paint job looks a little beat up... did you LAN a lot with it or something? if you're still gonna LAN with it, check out getting it powdercoated. That stuff is indestructable!
