[ Project ] < LCD Bay > By Samtech > + Pictures !!
Discussion in 'Project Logs' started by samtech, 19 May 2004.
  1. samtech
    samtech What's a Dremel?
    26 Dec 2002
    Well i've been to do this long time ago , but always witout time to do it, but , i managed to get this as a school project and so here it is the final result with lot's of pictures of all the Work progress and the Bay in action
    THe Start !!
    The used LCD ->240 x 128 with T6963C Controler
    The front part of the Bya being adjusted
    http://pwp.netcabo.pt/samtech/mods/lcd_bay/imag0101.jpg
    The acrilic base for the LCD Bay
    View of the LCD bay and it's metalic base
    The first LCD tests and from the base and rest of the ilumination
    The ilumination test from the Acrilic base
    The LCD Test
    The board wiith the ilumination conectors, the inverter conector and the LCD conector:
    More ilumination test's
    The sides of the bay , the acrilic molding ans the painting.
    The acrilic base after all ajustment's ,holes and some edge polishing:
    The sides before adjustment
    The sides after adjustment and polishing
    A very goo hair dryer from Black&Decker with 2000W :D to mold the acrilic (Aka heat gun) :D
    The acrilic for the back cover after molding, and preparing to finish up the sides
    The sides and back cover after finished and polished:
    THe painting of the metalic base, the sides (Tha were painted on the inside , so we can get a miror finish ) and the front of the bay:
    To place the acrilic on the bay there were 2 ideas , but othe firs on gave some bad result's due to a chemical reaction between the acrilic , the paint and a paste used to fill in the space, so i opted by polishing the front acrilic as the other part's and the result was much better then i expected :D
    And what all we where wainting for , the final result !!
    Left , right and front view of the bay
    back view
    The Bay in action
    It's content's after all conected:
    My WOrk Bench :p
    Well that's all , hope you to enjoy it as much as i do ;-)
    Samtech
    Portugal RULA !!!!
    Modding PT By SAmtech
  2. FuzzyOne
    FuzzyOne
    19 Sep 2002
    w00t first post, v nice mod there, wheres the lcd from?
  3. samtech
    26 Dec 2002
    Thanks :D
    Well this LCD was from a damaged copy machine , so i recycled it and made out the Bay ;-)
    The LCD is a 240 x 128 with T6963C controler , and at that time i was runing LiquidMp3 (www.schijf.org)
    Samtech
  4. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    :jawdrop: That is 1 schweet mod you done there.
  5. Mondak
    Mondak What's a Dremel?
    27 Dec 2003
    Very clean and very nicely done!
    Where did you get the front to start with? What was it before? Also, how did you get the paint like that? It looked rough in one shot when you were still working on it sanding etc. and then it was the finished product. It looks great and in the pictures almost looks textured.
  6. Madyeti
    Madyeti Supermodder & sig shrinking victim
    1 Dec 2002
    my god that's beautiful! One question: What are the small microphone shaped cylinders mounted in the back for?
    here's a one of your pictures with them:
    Great work though! :rock: :rock: :rock:
  7. toidiochysp
    toidiochysp What's a Dremel?
    30 Apr 2004
    that is a great way to enclose an LCD, good job!
    edit
    the microphone looking things are LEDs, the blue ones that light up the bottom
  8. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    very nice but the enclosures a bit too large for my taste, but very well done :rock:
  9. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    i believe those are LED's you can pick some up for like 10 bux now (us)
  10. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    That looks amazing, great job on that. Where did you get that lcd? I want one for my next proj.
    JEEVES
    ps. those are leds, he shows them in a pic further up
  11. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    he says he got it from a printer.. READ THE THREAD!
  12. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    :duh: :duh: :duh: :duh: :duh: :duh: .............oops my bad sorry.
    JEEVES <--------- embarrassed
  13. Chrizzle
    Chrizzle What's a Dremel?
    6 May 2004
    Good work. I love it.
  14. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Dude.... SWEEET!!!!
  15. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    dude thats awesome! really nice mod. altho i would switch the reset button with something else >.<
  16. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    damn man thats a sweet mod!
  17. dirk_j
    dirk_j What's a Dremel?
    19 May 2004
    I really like the finish of that paint job :thumb:
    How did you paint it and what paint did you use?
  18. verse
    verse What's a Dremel?
    28 Mar 2004
    :D I want one!
  19. samtech
    26 Dec 2002
    Thanks you all :rock:
    Well , now answering to all of you that have some doubt's:
    The LCD , and part of the front, as i said it was taken apart from a Copy-machine along with some more things :D (Aka wires , board's etc) , then it was time cut off some part's of the machine , and to put paste and glue to get the thing together in the front panel as in the picture.
    The cilinder led's were for in Car lighting , so as they looked realy cool in the box i adapted them to it, they were less then 5 € ans give a very good light !
    The Reset button , well , honestly it's there , but maybe for no much time , i'm thinking on to put one off those anti-vandal butons (with ilumination or not still to see)
    The paint i used was from AKI (name of the Store in Portugal) it's from MOTIP type Autolack Acril , it's a sorth of a metalized grey form there it apers to be a bit textured, it's the can from the picture above
    As for the painting method , i give first one light coat of paint at about 20 cm never pushing too much the spray button, then wait about 5 min , and then again giving another coat, and so on till i get the desired efect , it takes about 3 ou 4 coats to be great on a smooth surface.
    Any more doubt's just say :thumb:
    Samtech
  20. JRY
    JRY What's a Dremel?
    28 Feb 2004
    V SWEET work!
