Case Mod - In Progress [Project] Lian Li A05NB
Discussion in 'Project Logs' started by OC Maximus, 19 Jun 2011.
  1. OC Maximus
    OC Maximus New Member
    7 Aug 2010
    Simply me having fun water cooling my rig.
    Keepin' things neat, simple and functional.
    Original Parts:
    Case: Lian Li PC-A05NB
    PSU: Corsair HX620w
    Ram: 2x2Gb Kingston HyperX DDR3 1600MHz
    Mother Board: MSI H57M-ED65
    CPU: Intel i5 670
    CPU HS: Thermalright Venomous X
    GPU: Undecided
    HDD: VelociRaptor 300Gb
    Water Cooling Parts:
    Rads: x2 EK-CoolStream RAD XT (240)
    Rad Fans: x4 1850 RPM Gentle Typhoons
    Case Fans: x2 Scythe 120x25mm SlipStream SY1225SL12SH
    Pump: MCP-355
    Pump Top: EK-DDC X-TOP Rev 2 Black Acetal
    CPU Water Block: EK-Supreme LTX - Nickel
    GPU: Undecided
    Reservoir: EK-BAY SPIN - Acetal
    Tubing: PrimoFlex Pro LRT Black Tubing -3/8in. ID X 1/2in. OD
    Fittings: Koolance
    Inspired By:
    Project Mayhem
    Watercooled LL A05B
    [LL A05] Simplicity
    Watercooling by Malik
    MDPC
  2. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    looks good
    are you installing ventilation holes on the top because i heard it reduces graphics card temperature by 20c +
  3. Karrek
    Karrek Active Member
    7 Jun 2011
    Hey, as long as your in there, I'm sure you'll find a couple other things to tweak... wiring, paint, etc...
  4. OC Maximus
    7 Aug 2010
    Thanks,
    Lower radiator mounted.
    Upper Panel Complete.
  5. Matticus
    Matticus ...
    23 Feb 2008
    Very, very nice work!
    Are you going to put on some chunky feet to give the radiator a bit more room to breath?
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Subscribed, love this case
  7. OC Maximus
    7 Aug 2010
    Thanks, and yes, MNPC Tech billet case feet.
    _________________________________________
    Fathers Day present from my beautiful little daughter.
    Microsoft Sidewinder x8
    Happy Fathers Day to all you dads out there :thumb:
    Still working on getting the back round whiter.
  8. suenstar
    suenstar Collector of Things
    13 Sep 2009
    Really like what I'm seeing with the mod so far, looking forward to seeing how it progresses.
    Excellent little mouse you've been given there.
    Been using mine for about 2 years now and so far I haven't found a mouse that I like the feel of more, it just fits into the hand so perfectly... the only thing I would of liked more is for the macro recording button to be on the right hand side, as there is plenty of space for it there and my little finger is lonely being the only finger without a button. :D
  9. OC Maximus
    7 Aug 2010
    Thanks!
    GPU?
    GTX 580 hot off the bench...
  10. andrew8200m
    andrew8200m Well-Known Member
    4 May 2009
    Very tidy! Modding an a05 myself, would be nice to see how this goes :)
  11. StonieX
    StonieX New Member
    23 Dec 2003
    sub´d!
    I´m working on one too
  12. Droih
    Droih Your too close if you can read this
    17 May 2010
    looking good!
  13. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    Wow, what are you doing to your Gpu?? Looks complex that's for sure.
  14. xXSebaSXx
    xXSebaSXx Active Member
    21 Aug 2010
    Now this is my kind of modding right here.
    That my friend is a voltmod on the GPU so that one can push more volts than are normally achieved via SW when benching under extreme conditions.
    :D
  15. Rai
    Rai New Member
    22 Jun 2011
    What kind of glue or epoxy is covering the wires and soldering? Even with water cooling, that could get hot enough to come loose, depending on what it is.
  16. OC Maximus
    7 Aug 2010
    Thank you everyone for the kind comments. I'll have a few more pictures in a few days.
  17. OC Maximus
    7 Aug 2010
    Here's a pre-ln2 rape shot of the GTX 580 on the bench
  18. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Are you going to do LN2 or something? :eek:
  19. OC Maximus
    7 Aug 2010
    Nah, she is retired from ln2 duties and ready to go in my 24/7 machine.
  20. OC Maximus
    7 Aug 2010
