Case Mod - In Progress Project - Lian Li V2000 B Side pannels polished - Update - 20/4
Discussion in 'Project Logs' started by corso13, 5 Mar 2009.
  1. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Wowzers... How long did that take?
    Looks beautiful.
  2. skullen
    skullen Minimodder
    31 Oct 2007
    Nice job corso,very nice :thumb:
  3. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Oh wow.
    This makes me want to buy one and do the same as you did......... *picks up jaw from the ground*
  4. Franzy
    Franzy I have dremel 300
    24 Feb 2009
    Incredible.Good job.:rock:
  5. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    aa this crom looks sweet and nice case!!!
  6. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    That's an amazing finish you got with all that sanding,are you going to clearcoat it ?
  7. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    Can someone get my eyes for me? I seem to have misplaced them...:eeek:
    *edit* Darn it! your log inspired me to take pictures of my V2000b, but my card reader is at work! I'll PM you a link to them once they're up, hopefully you see something that will help you.
    GREAT looking work so far, definitely subscribed!
  8. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    Awesome job on the stripping and polishing. Instead of wax you might want to consider a couple coats of clear powder coating.
  9. Denrik
    Denrik What's a Dremel?
    2 Mar 2009
    That strip and polish job is very well done mate, good work.
    Dan.
  10. HaSLeS
    HaSLeS The Observer
    12 Jul 2008
    Can you pls tell me why you use WD40 instead of just water for the sanding?
  11. Fisher.
    21 Jan 2009
    Finally got around to uploading pics, but I won't clutter your (awesome) thread with them, so here they are. Basically, there's a few holes drilled for cables and a lot going on that you can't see from the front. When I get some good pics of the back, they'll be in the same folder.
    There's my update, how about one from you? Can't wait to see more!:rock:
  12. corso13
    corso13 The Cheff
    28 Feb 2009
    thank you all for the comments
    I have been quite busy the last couple of weeks in work so i dont have much time to put my hands on the side pannels as wished
    Next week ill go get some spare time to start the second stage on the sanding and start on the polish ( hope so )
  13. corso13
    corso13 The Cheff
    28 Feb 2009
    thank you for the advice but i have seen a lot of ALU Polished and clearcoted and looses all the bling and by the time passes gets all Foggy
    further on i will show a Detail ( like in the Cars ) on the case to get that perfect Mirror efect...
  14. corso13
    corso13 The Cheff
    28 Feb 2009
    Its for not geting an electrical shorcircuit on me :D and on the sander, also helps to get the surface highly lubed and the sandpapper last longer
    nice WC setup you got there , thanks a lot on showing the drills ill be doing allmost the same but whith acrilic parts between but thats is for latter now i must concentrate on polishing :wallbash: its an hard hard work
    thank you all and sorry for my bad and rusty english
  15. Fisher.
    21 Jan 2009
    Your english is better than my Spanish or Portuguese will ever be:lol:
    Just an FYI, I took some quick pics of the back side/cable management after I saw your most recent post, they are now under the link I gave you before. It's (always) a work in progress, but I'm taking a break for now. Soon I will move the 24-pin and the 8-pin EPS cable, and eventually I am WC'ing the GPU.
    Enough thread-jacking, can't wait to see more of the outside and I hope those pics will help on the inside as well!
  16. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Ooh, i like shiny cases. You might try waxing to prevent fingerprints and darkening.
  17. corso13
    corso13 The Cheff
    28 Feb 2009
    thanks a lot Fisher:thumb:
    Thats is what im plannig to do mate:thumb:
  18. x_JesusNinja_x
    x_JesusNinja_x What's a Dremel?
    8 Mar 2009
    Awesome polishing job!
  19. corso13
    corso13 The Cheff
    28 Feb 2009
    Hi to all again
    i have been busy at work, after 3 weeks whith no days off i had this weekend to do some polishing on the side pannels
    So lets beggin whith te set up of stuff to do the work
    side pannels sanded to 2000 grit
    the machines that helpe me do the job
    in this pic i have a spay can of cleaner that is good for alu some microfiber Applicator Pad i dont know the name for the buffing stuff in english, sorry :wallbash: and the mothers alu polish compound
    funny this one :D
    microfibers towels, lots of them, i used this type of towels because they dont scratch and remove a lot of dirt
    first and second pass whith the buff
    4th pass --- getting better but not perfect
    this one is for you guys to see all the crap that polishing promotes
    Getting there , lost my count on how many passes i made :wallbash:
    maybe 2 hours later and i dont know how many passes of buffing and cleaning and again , and again............ ITS DONE the first side pannel :D:D:D
    this is the MF towels after they passed through the washing machine, all of this was only for 1 side pannel
    starting on the other side pannel
    1st pass
    and is time to get a new spray can of cleaner and continue the job
    maybe at the end of this week im finishing of polishing, and start on the washing of the entire case whith a MF Mit, car premium shampoo and WAXING to get more bling and smootheness on the surface of the polished Alu and also for Protecion
    thats all for now thanks for watching and stay tunned :thumb:
  20. jhanlon303
    7 Sep 2006
    Very nice job and welcome to the world of polishing!
    It is very time consuming but the results are worth it.
    I watch.
    john
