Project: Lian MDF
Discussion in 'Project Logs' started by Jelte89, 18 Dec 2005.
  1. Jelte89
    Jelte89 What's a Dremel?
    18 Dec 2005
    First i wanna give you a word of who i am cause i'm new here,
    I started with casemodding 4 years ago when i was 13. I did take a lot of practising and now i'm here. I builded about 9 cases who where not completely finished and very bad looking :wallbash:
    But since there are a few very good cases on the internet, i started to sketch someting on my paper.
    Then i started to buy some materials for the case. I like the way _ferry_ build his case and Ediejo with his extreme lian li.
    But i don't have the skills to work with aluminium or metal. But i'm very good with wood, so i build my case from MDF. First i had the idee to begin with a desktop but that was not a solution for what i want, so i started to make a tower.
    Here are some modding pictures.
    This is my LCD (a datavision 240x128 for Winamp)
    This is the top of the case you see on the next a picture a better detail of it
    I made it from 3mm (white) plexi and then 4mm mdf to end with another 3mm plexi. The alumium strip you see is for placing the led's
    The three layers next to each other (they need some work)
    This is the motherboard wich is placed on a 3mm plexi plate, on the top a 4mm MDF plate
    a couple resistors
    a few buttons for control winamp
    My own made psu
    This gonna be the front like the lian li pc 60/70 (I have to make the on/off button
    This is the back of the case, the holes for the lpt/com1/com2 do i have to make.
    You can commenthere
  2. Jelte89
    18 Dec 2005
    Here you can find my Project log
    You can post here your comments
    Hope to get some pos/neg feedback :D
  3. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Not bad, not bad ;)
    I like the LCD idea :D and it would be nice to have a bunch of resistors here :(
    KUTGW!
  4. Blackcrown
    Blackcrown What's a Dremel?
    1 Oct 2005
    :worried: Veel succes met je mod, hopelijk wordt het wat moois :worried:
    Lots of succes with your mod, hopefully it will become something nice [​IMG]
  5. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Nice idea, looks promising :D
  6. AppL3 S4uC3
    AppL3 S4uC3 What's a Dremel?
    31 Mar 2005
    SweeT! Definitely skilled with wood there. Keep up the good work, good luck on completing it! :clap:
  7. Jelte89
    18 Dec 2005
    Thanks for the compliments so far.
    I'll have to go to school tomorrow for 3 hours and then i have vacation So i'll update as much as i can. Perhaps i get gigabyte as sponsor :) :clap:
