Project: Lian sLi - Update June 24 - PSU mounting complete
Discussion in 'Project Logs' started by WPELLE, 8 Apr 2005.
  1. WPELLE
    WPELLE What's a Dremel?
    4 Apr 2005
    As some had already guessed the PSU had to be mounted to the front of case.
    I was worried at first that there wouldn't be enough clearance between the motherboard and the PSU but fortunately it worked out just fine :thumb:
    There are some work left on the PSU, like routing a power cable from the front to a plug at the back, but that's for the next update ;)
  2. Jipa
    5 Feb 2004
    humm that's interesting place for PSU. It's allmost a pity I don't shame to modify my Nexus PSU :]
  3. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    are you gonna have the power cable coming out of the front, or root cables round to the back and put in another power socket?
  4. WPELLE
    4 Apr 2005
    I'm going to route them to the back and put install a new power socket.
  5. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    you probably should flip that psu's fans so it's an intake, or at least duct the rear fan to the side panel so it has some cool air
  6. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Yeah, just flip those fans around and that would solve that problem
  7. jopers1986
    7 Jan 2005
    yer good plan! sod the warrenty :D
  8. Firehed
    15 Feb 2004
    It's what modding is all about :thumb:
  9. shplade
    shplade What's a Dremel?
    10 Dec 2004
    If you install a new socket, make sure you remove the one up front, otherwise stray fingers will easily come in contact with live mains power :eeek:
  10. WPELLE
    4 Apr 2005
    I'm not sure it will be necessary since it will exhaust all the hot air through the front ventilation holes, but i'll keep it in mind.
    See pic :D
    I assembled the Aquabay/Aquatube/Aquastream today as well:
    More to come... :)
  11. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    looks nice, hope you can update some more before i go on vacation
  12. WPELLE
    4 Apr 2005
    Thanks man. Hope I have time to do some more work next week.
    Since I mounted the radiator and the fans this weekend I just had to fire em' up ;)
  13. shplade
    10 Dec 2004
    Oooh clever :)
    Thats a really good idea for the psu, I might consider it in my PC60...
    Looking great, can't wait for updates :)
  14. WPELLE
    4 Apr 2005
    A friend of mine donated an Antec Smartpower 500W to me. Since it's modular and can be fitted with 2x PCI-express connectors out of the box I thought it would replace the Powerstream for this project.
    Here are some pics of the finished PSU-mounting:
    To mount the plug at the back I cut a bit of acrylic to fit where the PSU used to be:
  15. dahl
    dahl What's a Dremel?
    3 Apr 2005
    DAMN! Nice!
  16. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    ur gonna fix that power cable sticking out the front, right?
  17. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    I don't think that would be visible with the front cover on, would it?
  18. Pistol
    Pistol Guest
    It wont be visible
  19. WPELLE
    4 Apr 2005
    As some already said, it will be covered by the frontpanel. I had to shave off some of the plug to make it fit.
  20. simosaurus
    12 Jun 2005
    oh yes, silly me :) cool then :D
