Case Mod - In Progress Project Lightning (Silverstone FTZ01 + MSI 980 Ti Lightning)
Discussion in 'Project Logs' started by Derick, 4 Nov 2015.
  1. Derick
    Derick Senpai Studios
    26 May 2012
    I'm scaling down my current ITX build for something that will fit under my TV a little better :) no name yet, but I'm sure it will come soon.
    I'll be using this build for streaming from my main rig, HTPC activities, and recording console peasant game play. Might give Steam OS a try for a bit as well!
    Onto the specs!
    Intel 4790k or 5775C - Haven't quite decided this yet, I'm going to attempt to delid for my first time so maybe whichever one survives eh?
    EVGA Stinger Z97 WiFi - this unfortunately might have to change due to the WiFi card sticking up like it does, but hopefully not.
    2x4GB Corsair XMS RAM + EK Monarch Modules
    MSI 980 Ti Lightning!
    Silverstone SFX 600W
    2x Intel 530 180GB SSDs in RAID 0
    Slot Load Blu-Ray drive
    Silverstone FTZ01
    EK Liquid Cooling!
    Soooo as most builds start, I had very small plans with this, was going to air cool and everything. Then the more I sat on it and saw others doing liquid in this case, I figured I may as well do it as well, of course. So without further ado... lets start.
    Don't mind the fingerprints, will be cleaned up a bit later.
    Pretty standard SFF case. I went with the FTZ01 for the aluminum unibody
    Whoever started doing this layout first with the GPU brackets is genius.
    Very subtle logo, love it.
    Got two fans on the bottom for GPU/radiator and one for the PSU
    One on the top for CPU/Rad
    Looks a bit crowded already...
    Take that bit off though and it reveals a bit more space
    Lovely 15mm thick fans
    Cable management going to be fun...
    Board fitted
    SSDs + Slim slot ODD
    The beast...
    Not that you can tell, but man is it a tight fit :D
    I put an SSD between the GPU and fans to hold off on the sag for now.
  2. Derick
    26 May 2012
    Quick unboxing of the MSI 980 Ti Lightning here. MSI did an amazing job keeping a high end GPU, classy.
    So shiny, like a holographic Pokemon card
    Details and such on the back
    A chest!
    Beautiful finish
    The king has arrived
    So cozy
    Accessory box
  3. Derick
    26 May 2012
    Quick update, still more to come!
  4. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Not all your pic's are loading, and they're a tad on the large size, try resizing them maybe ?
    Thanks
  5. Arboreal
    21 Jan 2011
    It's ITX overload tonight, with this and the Nightblade getting dremelled.
    Take a nice little case and shove in an unfeasibly large graphics card and water cool the lot with apparently no room to do it in. :eeek:
    Mod on sir!
  6. step
    step What's a Dremel?
    8 Aug 2014
    Nice build mate! Very good use of the space.
  7. Derick
    26 May 2012
    Been traveling but I brought the rig with me to do some on-the-road-modding with a familiar face :)
    Anyone recognize? :D[​IMG]
    Unfortunately it will not fit :(
    Back to Bitspower...
    Had to shave down the hole we drilled earlier in order to make the plug flush for the lid to close properly
    Started sleeving...
    While none other than Peter Brands (L3P) started cutting the Lightning stock cooler
    Great photo! But all sleeved
    The plan! MSI wanted to maintain their branding, this way I can have it hooked it up the GPU still and plus it will bring more air into the radiator :)
    To accommodate the pwm cable from the Lightning fan assembly we needed to cut the radiator
    Yours truly doing the honors:
    Perfect!
    We had to cut down the 120 rad too... super tight fit, every mm counts
    Now... to extend the slot in the front of the case that would normally be used by the DVD drive...instead we are putting the RGB glowing logo from the Lightning
    Cleaning up the cut...
    Now with both the RGB logo and fan assembly:
    Coming together again...
    Now in Zagreb for InfoGamer show!
    Thanks!
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Great weekend Derick! :)
  9. Icelander
    Icelander Minimodder
    3 Mar 2015
    heheheh. nice work guys.
  10. Derick
    26 May 2012
    Update to Z170!
    This board is soooo much more SFF friendly it's ridiculous. The layout makes everything much easier, the top 120 rad now fits much much better.
    Changed to a pair of slightly larger drives I had sitting around. The main reason was because they're black compared to the silver Intel's. They look much better now.
    See, all black. Don't mind the orange, it's just to make sure nothing leaks before adding the top cover with 120 rad. The case is a little beat up from traveling :( it needs some love.
    And together!
    I think I'm going to cut another 240 grill on the top of this side to help with the exhaust of hot air, and to spice it up a bit eh.
  11. uerseya
    25 Aug 2008
    Hi, nice build, well what I can see of it, do you know how to use MS Paint ? :duh:
    It doesn't take very long to use a graphics program to resize your pictures, you can use MS Paint to do it :idea:
    Thanks in advance :hip:
  12. Derick
    26 May 2012
    Haha they're only 2400x on the long side. Maybe I'm just spoiled with 105Mbps down :brrr:
  13. uerseya
    25 Aug 2008
    I've got fibre and the cabinet ~500m down the street and still not all your pictures show :idea:
