Case Mod - In Progress Project "Lightning" + Transforming racing SIM Desk
Discussion in 'Project Logs' started by m.standish, 31 Jul 2014.
  1. m.standish
    m.standish What's a Dremel?
    29 Jul 2014
    Ordered some clear cast resin and I have a mould being made over the weekend for the replacement fan rings so im looking forward to getting my hands dirty with this experiment.
    Still in planning for the backplate, i keep getting different ideas so I havnt yet ordered the acrylic as dimensions keep changing slightly.
    Should be ordering the fittings soon i think. At the last count on the current plan, theyres 42x Hardline fittings and 15x 90 degrees, so its a good job i upgraded to a dual pump. I think im going to be using these [​IMG]
    As i simply cannot afford to buy a full set of Primochill revolver dual tone which i think would look amazing, nor can i afford to use monsoon fittings which i already have some of.
    Recieved the 2nd delivery from Corsair :clap::clap::clap: Thank you yet again, and a MASSIVE thanks to Jon, who helped me find out the details of the internals as the first Force GT i modded has been changed, along with the rest of the range, they have all switched to a thinner, lighter 7mm shell and the PCBs have changed as the technology has evolved. I specifically wanted a large pcb and Jon helped enormously to find out the info for me
    So thank you to Corsair and Jon for providing 2 Force LS 240 SSD's
    Aww, a warranty card, thats nice :)
    And now useless :dremel::dremel::dremel: But the thought was there :)
    The plan for these was to raid 0 them. I had some difficulties with this at first on X79-UD3 as i simply wasnt getting the performance. 380mb single drive 400mb raided. Until i found that the intel ports are 6gb/s along with the marvell ports. BUT it seems that the marvell controller simply cant handle these at full speed so having 2 controllers i switched one to the other controller and low and behold, the speed doubled :)
    I think this is still wrong as i realised today the specs are 560 read 320 write which is perfect for my purposes which will see these 2 used for games installations which will not really benefit from super high write speeds. (they will still be double that, but its the 1gb/s read speed that gets me excited.
    I think in my haste & testing I have left the Sata controller for these as Raid instead of AHCI, so im going to switch this and test again.
    Thats me for the weekend I think as its off to the seaside for fish and chips, but maybe I can get a few things done.
  2. m.standish
    29 Jul 2014
    Bit of testing done and it turns out the low speeds are due to the marvell controller on the X79 UD3 being a bit poor and they simply wont get the most out of the drives.
    Upgraded to a 4930k too but it will only hit 4.3ghz, and its not too happy at that. Im starting to see the setbacks of this motherboard now im saturating it. Maybe an upgrade at some point??
    Managed to get the SSD Twins ALMOST done.
    Started witha rough sand to remove the black paint
    Before & After:
    Planning out the window size:
    Marked up and cutting:
    Chopped, No going back now :)
    Then Worked up through 400, 600, 800, 1000, 1200, 1500, 2000 grit wet and dry sand paper, about 15 minutes each drive on each paper!!
    And Before and after polishing with Peek polish!! Love this stuff, it always amazes me
    Test Fit:
    Turns out that the shrink to 7mm drives left me next to nothing for the plexi window, but I managed to use some 1mm stuff. And a Little placeholder sticker FOR NOW....... :)
  3. m.standish
    29 Jul 2014
    Materials should arrive today for the fan ring mod, just need to get a syringe and "hopefully" the curing times should mean i have a prototype clear ring by the end of this weekend.. Ive never worked with either of the materials ive bought so this should be interesting. My colleague came up with a fantastic suggestion regarding the lighting so ill also try to try that as its a bit less invasive than my original idea
    Wish me luck!!
  4. m.standish
    29 Jul 2014
    Crystal Rings
    I made a start with the rings and learnt a few lessons on the way with the first attempt (note "attempt" :( )
    Heres what I used:
    • RTV Silicone
    • Activator
    • Bucket 1cm larger than the ouside of the ring
    • Syringe for measuring
    • Plastic cup for making a void
    I rolled out a strip of silly putty to make a seal around the cup so i could make a void and waste less silicone and stuck this central so it made a 3 cm dognut
    Measured out 175ml of water, marked the top point and replaced the water with silicone as the mrs would have been happy me using her measuring jug :jawdrop:
    Mixed at a 100:4 ratio = 7ml of activator
    Placed the ring centraly and glued to the base with 2 tiny drips of superglue so it didnt float up and filled
    6 hours and it was ready to be removed & filled, I mixed up some of the resin and using the syringe overfilled the mold and scraped off the excess
    **MISTAKE** Left the rest of the resin in the mixing pot to judge when it set without disturbing the mold - and the mrs's legs for good show lol
    SO.... this set solid after a about 4 hours - still a tiny bit rubbery so i left it overnight and next day while we went to Skipton. Assuming this would have over cooked it i removed it from the mold - It was like toffee! and had a very tacky edge which i was aware mat happen but i intended to sand it down, sadly it had shrunk below the mold and made it too small to do this, I left in a warmer place out of the mold for 48 hours and it stiffened up a lot. The edges ended up with a melting look which i assume is due to it being demolded too early and the lip is a mess because of the shrinkage.
    Test fitted last night and realised the shrinka e had caused more problems than i fore thought, it is now not a 120mm ring, more like a 117/118 making it catch and not fit
    I have found out that the smaller the part, the longer curing is required as it cant build enough heat in itself to cure which is where i made my first mistake
    Im trying again currently and will leave in the mold until thursday/friday, I have also covered the exposed lip with cling film as this should stop the surface becoming tacky when its exposed to air
    Heres the first test failure. Hopefully they will get better but theyre going to take quite a while!
  5. m.standish
    29 Jul 2014
    PSU
    Today I received another parcel from Corsair... A PSU, Not any psu, but a huge monstrous, Nuclear power station of a PSU, I wouldn't be surprised if it didn't weigh more than a couple of computers i've had over the years. Sadly i'm at work and I cant do this thing justice on my Note 3 camera here
    Its an AX1500i :) - Thanks Corsair for providing, without doubt the best PSU on the market! :)
    [​IMG] (The coke is for size comparison, I dint get a drink with the psu, hint hint ;) )
    This should now put me back into the green zone with regards to % load.
    The system was built around a 3820 and 3x 290x's and if you read back in the beginning you'll remember I was a little bit unsure about the 1300W Superflower I chose as I was unsure if it was enough but decided to go for it because of a black friday offer and the fact it peaked at 1600W alleviated my concern about lack of power, That was before i switched to the end goal 6 core 4930k and that bumped my readings at the wall to about 1350W, while im aware due to efficiency that i wasnt breaching 1300W load (1246w i calculated), It was still runnning at 95% capacity which isnt very good, ideally i would like to run a psu at no more than 80% load, this monster, by my calculations should put me at 83% load which im very happy with. Goddam AMD and their eco unfriendly 290x's LOL (lets not mention theyre actually ok until you OC em to wall)
    Im looking forward to getting this wired into the Link system so i can monitor loads during stress, Ive missed this feature since i had a Gigabyte Odin 800w that allowed it. That, if i remember didnt have a silent mode, this AX1500i will run fanless up to about 500W and i would suspect thats quite a large percentage of this machines uptime so I should be able to now tie in some of the fans to the PSU load and get a semi silent pc until gaming is involved.
    So while the SP120 fan rings cure for another few days I can get the psu swopped out, maybe drain the loop, add in the Dual pump and work out some measurements for the rear mounting. Its starting to get difficult to work around a live system but i'm trying to minimise the down time by stacking up all the little jobs that I can do during 1 full rebuild.
    Once again, A HUGE thank you to Corsair for having belief in me it makes me very proud to have some one as big these guys behind me and for my first ever sponsor. It means so much personally that such a well respected company are happy for my pc to showcase their gear, it means to me that the hard works worth it and i'm doing things right! And a massive thank you to Jon, You've been a complete superstar! and Corsair, Give that man a bonus, hes been a perfect example of helpfulness and going above & beyond to help :thumb:
  6. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    i could only dream of ssd speeds like that!
  7. m.standish
    29 Jul 2014
    I thought id show nearly the last 6 years of building this pc and where its come from. I thought to myself a minute ago while picking the pictures, that i had now finally gone full circle and that all the original components had been replaced - Until i saw the cpu block and realised yes, I have gone full circle, im starting to reuse parts again! :/
    anyway enjoy, I certainly have over the last few years
    2010
    2012 - 1st Dual Card setup
    2014 - new platform & case
    2015 - Year of the Triple
  8. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Looks great.
    With the moulding, a tip I found when researching to make moulds for a model a friend asked me to build for them is that for resin or silicone you need to allow for something like 8-10% shrinkage, so scale up 120mm by 10% and it should give you closer to 120mm. Of course it varies with different types/brands of resin/silicone, so it will be a YMMV type scenario. Good luck :)
  9. m.standish
    29 Jul 2014
    Now its all arrived I took a quick pic of the components provided by Corsair
    And a few unboxing of the psu:
    Inside I would a very heavy plush velvet bag, a wash bag, a weird cable that dosen't fit my TV and a couple of magazines
    Further inspection found hidden in the wash bag and (i presume) a make up bag a very large PSU and enough cabling to rewire the house
    more than enough connections!!
    And more than enough cables! Glad im not sleeving all these!. Ill be using the bottom row of cables, the top row are surplus (for now) Fair to say theres enough here to connect a minimum of 5 GPUs and god knows how many drives!!!, best part of 30!!! :eek:
    Enough length to reach nearly any case i can think of, probably too much if space is an issue, thankfully ive got spare in the rear of the Air 540 that i can hide the excess
    Side by side from the old Leadex 1300
    and a quick test fit for measuring and visuallising
    Next is the fitting and redoing loop, I started 2 days ago and am still in the progress, ill try get some pics tomorrow
  10. m.standish
    29 Jul 2014
    bionicgeekgrrl thanks for the advise, Im trying to work out how to make it larger heres whats happened
    Came out quite well, (the rim needs sanding)
    But once fitted, you can see its quite a bit smaller
    Anyway i left it on for a couple of days and it seems it shrunk further pulled too tight and split in 3 pieces, ill play with splicing a couple of mm into the ring and remaking the mold in the next few weeks but I suspect this idea may be a failure
  11. m.standish
    29 Jul 2014
    Some weekend progress pics, theyre not much im afraid just little niggly jobs I needed to get done to prep for the the rear panel and get some measurements
    Before I started - AQ bit of a temporary mess:
    Stripped down the rear
    Res out - Apologies for the mess of tubing & connections - Ill get that fixed
    Old pumps out
    And its new home along with its brother, This 2nd pump was an interesting project its a laing pump from ebay, new but it was originally designed for a mac g5, the wiring had to be redone as it had a proprietary connector and a pressure relief port through the centre needed to be filled.
    Centre port filled with JB Weld
    Started stripping out the main section
    All built and a quick leak test
    Stripped out the lower panel, LCD & Bottom res for a panel rebuild
    Old and new ready to be cut in, Much easier the second time :)
    Test fit - Note fan orientation switch, for 2 reasons, I want to do some clear lit rings and them be visible ans also Im going to try switching the airflow to see if it helps with the temps, im hoping this direction should, with some help (later ;) ) pull cool air over the gpus rather than warming them up, downside is that im now open to dust bunnies in the rad and im still trying to work out how to combat that
    Checking the res still fits and i made a dummy back panel to help with the rear manifold planning and to clean it up in the meantime, The res has been moved back and now has only a couple of mm clearance for the GPUs
    Test fitting SSDS and measuring for the LCD placement, decided to switch the direction of the Res ports
    THIS feels like a cop out to me but Ive had to cover it with vinyl rather that hydrodipping as due to the weather i need to hydrodip inside and i need to time this very carefully so it may stay like this for a while until i get some clear space to be able to fumigate the flat
    Under the panel & and res drainage solution
    Fitting:
    Back to the back
    Couple of things of note here:
    Res: I retapped the res to g1/4 from g1/8 and retubed it a bit more elegantly. Yes there are still 2 input ports, the res it built this way to allow a waterfall effect over the front glass and i quite like it so i didnt want to close it off, Also due to the positioning of the 2 input ports i thought it may make filling easier as air can escape easier. I has planned to make the fillport enter directly from the top but due to the size of the res this isnt possible as it runs into the corner of the case
    I mounted the rear cpu block and pulled tight sandwiching some thermal pads. Here i needed to notch out the edges of the 775 heatsink for the screws to fit, not the most elegant soloution but im hoping to cover this with an acrylic panel that will also house some type of heatsink for the rear naked VRMS pictured above the block, I have an old block im considering using but im strugging with the mounting, so maybe this will happen, maybe it wont?
    And some tubing placement planning, im really struggling with this as im going to switch to hardline soon and cant bring myself to buy more fittings so im trying to work with what i have spare which isnt right much now.
    I am considering adding a 140 rad into this side, however it will use almost all the available space here so im not sure if i can fit it which is a shame but it looks like ive reached the limits of an Air 540. which is
    • Triple GPU
    • 2x Reservoirs
    • 4x SSDS
    • 1x HDD
    • 10x fans
    • Dual Pump
    • Dual CPU Coolers
    • 2x Fan controllers
    • 240 Rad
    • 360 Rad
    • 140 Rad
    • Oversized 1500w PSU
    • 1x DVD Drive
    • 2x Lighting controllers
    • 1x LCD
    Quite impressive for the case! Corsair did well with this one.
    Thats me up to date for now, im still working out the rear space routing and ive no doubt the next update will be it finished until I get the planning together for the water manifold then it "should" be the last teardown before I complete the build. I want to be 100% sure about the panel so it may take some time and checking/double/triple checking before this gets built, in the meantime i think ill get the steel work ordered for the debezeled triple monitor mount as thats getting annoying now
  12. m.standish
    29 Jul 2014
    Another order just in for the next few mods, So I should be able to wire up the GPUs and the 90 degrees will hopefully fit between the GPUs so I can run tubes to the manifold for each of the 6 ports removing the triple block, I had to get some alphacool 90 degrees as the barrow ones are just slightly too long and they wont fit correctly, these are supposedly 2mm shorter in total so im really hoping that will give me enough clearance. Also picked up some new thermal paste as im out and some heatsinks for the rear VRMs, thought i suspect it wont help overclocking any.
    Downside is that ill now need to wait fro this to arrive before i can rebuild the system so i can test fit these, then its time to order the hardline stuff
    SKU Product Item price Quantity Total
    17056 Alphacool Angled Adaptor 90° Rotary G1/4 Outer Thread To G1/4 Inner Thread - Chrome £2.99 6 £17.94
    17156 Alphacool GPU Heatsinks 7x7mm Black - 10 Pack £2.99 1 £2.99
    12099 Alphacool Double-Sided Thermal Adhesive Pad 120x20x0.5mm £1.69 1 £1.69
    31052 GELID Solutions GC Extreme Thermal Compound £5.99 1 £5.99
    82066 mod/smart VGA Power Connector 6Pin Socket (Square) - Black £0.59 3 £1.77
    82161 mod/smart VGA Power Connector 8Pin Socket - Black £0.79 3 £2.37
  13. m.standish
    29 Jul 2014
    Brilliantly quick delivery from C&C Central, Even shipped the same day after i missed the 2:00 cutoff, so fingers crossed these will let me fit the GPU's seperatley cooled, I like the terminal block BUT i think that each card hardline tubes will look so much better. Fingers crossed, Ive only got a couple of mm to spare :/
    Passed by my local GAME store and notice some drives on sale, spotted a 2.5" 500gb for a ridiculus price so i had to buy it. I have no use for it but at that price i couldn't not! Im sure ill need it at some point
  14. m.standish
    29 Jul 2014
    Its been being rebuilt for nearly a week doe to planning and things so heres a couple of progress pics and planning ideas/measurements
    First up, I cooled the rear VRMs, Not very pretty but they wont be seen
    With these:
    Ill probably have a go with a black marker so theyr'e not so obvious as it annoys me, I hope they hold as if they fall off they could cause a short, They may be altered to make sure this cant happen
    A test fit proved the alphacool fittings + low profile g1/4 plugs do fit, theyre goddam tight though so theyres a possibility i may file down the very top if the fitting to release some play when i fit them fully later once the manifold is completed, I would like to get some super low profile g1/4 plugs if anyone knows where to get some
    0 space but not i can run tubes singly to each card
    I have also found that with a bit of redesigning the rear I can fit a 140mm rad and single fan in the rear which as well as extra rad area will also help cool the VRM sinks and the BigNG which is going to be used to power the 2x WC pumps and monitor the flow rate meter. The Corsair Link Mini will be used to run the rad fans in pairs on the 6 channels
    CH1 - 360 Top 2 fans
    CH2 - 360 Mid 2 fans
    CH3 - 360 Bot 2 fans
    CH4 - 240 LH 2 fans
    CH5 - 240 RH 2 fans
    CH6 - 140 Rear fan
    I was originally going to wire it as
    CH1 - 360 Front External 3 fans
    CH2 - 360 Internal top fan
    CH3 - 360 Internal mid fan
    CH4 - 360 Internal bot fan
    CH5 - 240 top 2 fans
    CH6 - 240 bot 2 fans
    This config would allow me to always run the front 360 fans in pull for silent running
    then the top fans for midrange and then to ramp up the rest for high performance but this dosent work well once i add another rad in the rear plus i would rather split to load over all 6 channels evenly.
    It should fit in the space in front of the Big NG here:
    Ive played about with setups and im almost there, i just need to do some final mountings and i should hopefully get it all filled for the weekend.
    I can almost see the end in sight now :) - Updated the jobs to do
  15. m.standish
    29 Jul 2014
    Finally got the mid way rebuild finished so its going to stay this config for a few weeks until i get the rear manifold built.
    Fabbed a very rough mount for the 140, drilled the roof of the case and bolted it in place
    Just some of the mass of wires that are hidden in the rear, I thought is take a quick pic as without this pic i dont think anyone would believe how much wiring its in the back of this thing
    Leak testing
    Found on leak at the front inline filter, Hopefully ive managed to tighten it up in situ otherwise theyres a drain and fill coming v soon
    And a quick shot to the rear, Still have a few bits to do back here but im happy with it so far.
    It was pretty close to be able to get the 140 in there and above the pump where i wanted it.
    On the front i have reversed the 240 rad but the old hydrodipping didnt work well on this side so i've covered it for now. Once I get a window, ill be hydrodipping the rad,bottom plate & I/O cover back to how their meant to be.
    In other news, I may be getting a triple monitor stand tonight so I may need to buy the aluminium to be able to debezel them v soon.
  16. m.standish
    29 Jul 2014
    Couple of really really badly taken - semi finnished shots
    Still need to make a cabling cover and mount the HDDs
    and the front side for the last time with soft tubing
    The new Monitor stand in use - First thoughts......... This needs debezeling - QUICK
    And a quick play in portrait - Its interesting to say the least
    So next large jobs are to debezel the screens and then to require the gpu power. Then im onto the manifold & hard tubing, then finnishing up this year long project. Fingers crossed itll all be done before my birthday
  17. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Having the monitors in portrait is much better I've found as you don't need to faff so much with FOV values, tho' playing the Dead Space games for example on 3 monitors in landscape takes away some of the pants painting as you can see the buggers coming more easily :D
    Though one of these : http://www.philips.co.uk/c-p/BDM4065UC_00/brilliance-led-backlit-lcd-display
    Is argueably cheaper than 3 monitors & at 4k @ 40" it's not far off the same real estate as in my case of changing from 3x Dell 27" monitors in portrait @ 2560x1440, plus no bezels :clap:
  18. m.standish
    29 Jul 2014
    I had it running through a 32" tv for a short while and tbh, i found it a little too large, the 27" was just about right and i wanted the triple screen for the immersion in racing so 1 4k screen woukldnt work well, However, it is too wide and if i had complete choice i would have prefered to to PLP with 20 - 30 - 20 but when i was looking it all up it seemed really difficult to run it with eyefinity. And i definatley wouldnt have been able to do it at 100hz
  19. uerseya
    25 Aug 2008
    Different horses for different courses.
    I did wonder what it'd take to run 3 of the 40 inch'ers in portrait with NVIDIA surround :geek:
    I'm running overclocked 3x GTX 680 4GB under wtaer @ the moment and they seem to be under less strain with just one monitor to run even though the resolution difference between 3x to 1x isn't that much, the 4k is less.
    But anyways hurry up with your build, less building more game playing :clap:
  20. m.standish
    29 Jul 2014
    Finally got around to debezeling, I have seen a few "destructive" methods, I wanted to keep the screens as close to original as possible so they could either be warranied and mainly put back to normal & resold if required. I had originally found a method of using U bracket to hold the screen but this could have been problematic when using them vertical.
    I deciced to use m6 roofing bolts, using JB weld and fixing 10 of these to the rear of the screen and bolting the control panel to these in the same original position
    Screen stripped and bolts glued
    screens stripped of the front bezels
    All sprayed matt black
    Finished
    1st screen hung and 2nd in progress
    Rear of the mounted screen, you can see the mounting method, not the cleanest method i could find but it does leave the screen fully functional and able to be put back into the housing should the need arise
    And all mounted
    Note the bracket above, This is a broken bracket, Gibbo @ Overclockers very kindly sent a replacement that is holding the screen but this one will be used to secure the centre speaker angled down.
    I found a pioneer 5.1 xbox setup which were a bargain, but the wrong colour and these will be used for the external sound
    Maybe these will be painted matt black to match
