Project: Liquidmod update 5th March
Discussion in 'Project Logs' started by revlimit, 11 Feb 2006.
  1. revlimit
    revlimit What's a Dremel?
    25 Aug 2005
    Okay folks, here is my first project log so go easy on me. I've been reading countless mods from [H] and Bit-tech. I have combine some ideas from people such as Top Nurse, AlumaxX, PilouX, and whoeever I may have missed. Here are the parts list.
    Asus A8N32-SLI Deluxe
    AMD Opteron 170
    Lian Li V-2000B
    OCZ PC400 Gold Edition 2 x 1GB
    OCZ Modstream 520
    IMG]http://i25.photobucket.com/albums/c90/revlimit1995/17-104-155-03.jpg[/IMG]
    XFX 7800 GT
    Creative X-Fi
    IMG]http://i25.photobucket.com/albums/c90/revlimit1995/DSC01893.jpg[/IMG]
    Swifttech Apex kit
    Aqua Computer parts
    Aquaero VFD
    Aqua Computer Flowmeter
    Aquatube
    Got a nice custom lazer etched side panel from www.voyeurmods.com
    I was starting a new build and realized that I never posted the finish product of this one. So here it is:
  2. revlimit
    25 Aug 2005
  3. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    That is some very, very nice hardware :D
    *bookmarked*
  4. Jipa
    5 Feb 2004
    Money talks. Lets see how this ends up..
  5. revlimit
    25 Aug 2005
    I decided to disasemble all the rivets and replace it with hex nuts and bolts.
  6. deiol
    deiol What's a Dremel?
    14 Jun 2001
    awesome looking case, cool hardware too!
  7. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Nice hardware, nice case, should turn out quite well. But do you mind resizing the pictures, some people are still on dialup (me for this week). And im not much of a final fantasy fan, but that window is awesome.
  8. revlimit
    25 Aug 2005
    I've resized it. Sorry about that.
  9. revlimit
    25 Aug 2005
    here are some picture of the parts painted and polished.
  10. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    That paint job doesnt looks so good, it's not smooth like it should. And that polishing doesnt look so good either, you need to sand it with different grits. like p400-600/800-1200 and metal polish in the end ;) make shure to clean it when you are finish with sanding ;)
  11. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    ditch that aquacomputer flow meter & res(unless the res is bored out) its highly restrictive and will be like trying to push a elephant through a drain pipe you will bascily be killing all your flow in the loop to the point that you could spit faster down the pipe. (if thats a storm g4/swiftek storm block which i see that will only benfit from highflow). get a swisflow 800 thats a big bore flow meter and use the res that comes with it or get a fass-o-matic :D
  12. revlimit
    25 Aug 2005
    I like the way the res look. I'll be boring out the flowmeter but not the res.
  13. revlimit
    25 Aug 2005
    Ya, got to put some more elbow grease.
  14. sc4mpi
    16 Jan 2005
    Boring out the flow meter will do jack sh*t... tbh, its still going to be like a 6mm inlet, on 12mm tubing =/ and theres the fact your going to be feeding you pump through a 6mm inlet as well at least bore out the res for 1/4" barbs, if you leave it its going to render all that high perfomance stuff absolutly useless. why do you need a flow meter anyway ? its not like that pump is silent heh :p
  15. revlimit
    25 Aug 2005
    I'll take the temp measurement with the aquatube and flowmeter installed and without to see if there is a major difference.
  16. revlimit
    25 Aug 2005
    here is picture of the plexi I ordered from voyeurmods as well. I deceided to stack the blue plexi on top of the original one.
  17. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Voyeurmods effing STOLE MY WINDOW!!!!
  18. customh
    customh conflagration.
    22 Oct 2005
    Nice block, i want it lots, it'll be in my next mod as it stands now. Its the best high production block on the market.
  19. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    should be a nice looking looking fast pc at the end of it all.
    What lighting are you gunna use to get the best out of the window.
  20. Koradhil
    9 Nov 2004
    Ditch the AC flowmeter, it sucks. Get a Swissflow SF800 instead. I've got one of those myself (I got it for free from Swissflow to 'test' it). Haven't used it yet but I'm sure it's much less restrictive (even when you bore out the AC flowmeter) and also much more accurate.
