Case Mod - In Progress Project: Little Big 840 {Completed}
Discussion in 'Project Logs' started by ColdzeroTeam, 21 May 2011.
  1. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    Hello everyone,
    this is a mod i've done a while back, before we started using mate plexi (as you'll see by the hardware used) but i decided to share it with all of you :)
    The theme for this mod will be the video game Little big planet, which i'm a fan of, and i hope you like it.
    Laser Hetch on the side panel.
    Case being ready to be worked on...
    and this is all that is left :p
    Plexi parts begin to appear :p
    Standard Radiator supports.
    New ones for 420 Black Ice GTX rad
    Custom 5.25" bays
    Test for the radiator placement.
  2. ColdzeroTeam
    9 Dec 2010
    here come some more photos :)
    Used the standard rails in a diferent way, so they would be hidden :p
    Memory coolers
    Standard Mb tray...
    New One :p
    Our Very first custom backplate :p (in prototype form)
    Finished Midplate
    Finished backplate. a little diffent from the ones we're using now... this really brings back some memories...
    and that's it for now :)
  3. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    WOW! Nice start :)
  4. jhanlon303
    7 Sep 2006
    Pictures are back! Not your issue - PhotoBucket problems. Very nice.
    Where did all the honeycomb mesh come from? With the case?
    john
  5. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Realy nice mod bro! I really love how you installed each part in the case!! Fits magically !!! :)
  6. domthecondom
    domthecondom Noob Modder
    27 Jun 2010
    What hardware you using
    Also black plexi?
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Good old 840 ATCS. Still one of the best cases around and you do alot of nice stuff there with it :thumb:
  8. ColdzeroTeam
    9 Dec 2010
    no, all the honeycomb parts are laser cut black plexi
    Tks !! :)
    Tks :)
    that machine had
    intel i7 920
    12GB ram
    Gigabyte ex-58 extreme
    2x gtx 295
    1x corsair 1000w hx
    2x ssd
    yes, i was using black plexi
    yeah, we finishing one more project with another 840 :p hopefully, it will be finished this week.
    expect another thread when it's done :p
  9. Cheapskate
    13 May 2007
    This is looking really clean. That's not easy with as much gear as you have packed in there. I like the layout.
  10. GeorgeStorm
    16 Dec 2008
    Looks awesome!
    Cannot wait for this to develop even more
  11. KidMod-Southpaw
    28 Sep 2010
    We need more! That backplate is great, wonderful start.
  12. ColdzeroTeam
    9 Dec 2010
  13. domthecondom
    27 Jun 2010
    Great job :). Is the waterblock on the Extreme not rubbish?
  14. ColdzeroTeam
    9 Dec 2010
    its nickel plated copper, so its not as bad as the old ones from Asus.
  15. ColdzeroTeam
    9 Dec 2010
    Here are some more photos, project is nearly finished...
    Replacement for the front lid, with the shape of the Cooler Master Logo
    New psu plate, for some more stuff :p
    External HDD Box :)
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Nice build dude... although in this config wouldn't the water just pass straight thru without going through the blocks?
  17. Guest-56605
    Guest-56605 Guest
    Looking at that pic I make you right it would :duh:
  18. ColdzeroTeam
    9 Dec 2010
    lol, no it wouldn't. these 295gtx are not like all the other blocks. there's 2 holes on each side, but they are connected. so for the waterblocks to work, the in and the out must be on oposite sides. be it aligned or not ;). So yes, they are correctly assembled :)
  19. domthecondom
    27 Jun 2010
    Are thoese LBP images etched in? and who done it? looks stunning. My Girlfriend wants this mod ;)
  20. ColdzeroTeam
    9 Dec 2010
    yes. all laser etched :p
    we did this. it was the first laser cut project we did back in 2009.
    just to finish the project... the side panel that took me a long time to prep for the etching... unfortunately the images don't do it any justice :(
    the image used...
    photoshoped versions :p
    THE END :p
