Case Mod - In Progress (Project Log): Epitome, BitFenix Prodigy/ATX build [Updated 8/8]
Discussion in 'Project Logs' started by Fridge Gnome, 13 Jun 2013.
  1. Fridge Gnome
    Fridge Gnome Blue Everywhere
    11 Dec 2012
    I used an acrylic cutting knife, a routing table, and a few different files to make the bottom acrylic piece. It isn't illuminated, although I originally intended it to be. Since it goes over some of the PCIE slots I would have had to rig some sort of lighting thingy under the case to properly light the whole piece.
    I can say it looks quite nice with simple white LED strips behind it. If you have more room in your case I highly recommend it.
    Little bit of an update to give today. Progress is going excellently so far.
    I replaced the original white portion of the front Prodigy panel with an acrylic one that I cut out. It's super shiny, and I was able to use a blowdryer to remove the bitfenix logo with stickiness intact, so I plopped it back on the new acrylic panel.
    I also did some work on the back of the case. I painted the PSU white, installed the harddrive and mount, and I got a little sleeving work done too.
    In the front of the case, I sleeved and installed the northbridge fans. They cover up the whole for the usbs and stuff nicely, and should also get a little more airflow going through the case.
    I am having to repaint the fitting portion of the GPU blocks. I was lazy and didn't prep the surface right and now I am paying the consequence :/
    That's it for now. Hopefully I can start putting the roof on this thing once the GPU pieces are done being repainted.
  2. Fridge Gnome
    11 Dec 2012
    This project is pretty much done!!!
    I ended up staying up late the night before I left to finish leak testing everything. But I got it done. Hopefully I can take more pictures soon.
    On to the pictures!
    I'd also like to once again thank my sponsors for helping me afford this project and motivating me to get it done.
    And one last hi-res.
    Thanks for following the project, it's been a lot of fun for me. I'm extremely happy with how it turned out.
    For my first serious modding project, I never expected to be able to make something this cool looking.
    I hope to be able to post a few more updates on a few things I wasn't able to finish in the future too...
    Thanks for reading!​
