Modding Project log name ?
Discussion in 'Modding' started by [S]huttle, 25 Oct 2003.
  1. [S]huttle
    [S]huttle What's a Dremel?
    15 Sep 2002
    Ok, this HTPC case should be arriving to my house by this coming Wednesday. I am going to be doing a project log and I am having troubles on coming up with a name. Anyone have any ideas ?
    Here are the Features and Specs of the case
    Special Features:
    High performance, efficiency and classic design
    In style and tasteful shape easy to fit into future space
    Excellent choice for professional individual
    Stream-lined styling with hi-tech capability
    User friendly, tool-less assembly/disassembly,
    for easy maintenance or expansion
    Specification:
    Material: All Aluminum Alloy
    M/B Type: ATX Motherboard
    Color: Silver & Black
    Drive Bay: 5.25" x 2 ( Exposed ) / 3.5" x 2 ( Exposed ) / 3.5" x 4 (Hidden)
    Cooling: 8025 mm fan attached back panel ( Exhaust )
    Expansion: Slot x 7 pcs
    Others: Dual standard USB ports IEEE1394 and Audio
    Weight: 4.2 kg
    Dimension: 450 mm ( D ) x 425 mm ( W ) x 159mm ( H )
  2. LCDNinja
    LCDNinja What's a Dremel?
    22 Oct 2003
    depends on where you're goin with it. Looks sorta like a retro futuristic computer almost.
    My suggestion is Project Futropia
  3. carloshax
    carloshax dealer
    29 Nov 2002
    my choice of names:
    Retronic
    Mini-malist
    Carl
  4. naelq
    naelq What's a Dremel?
    14 Oct 2003
    hi there,
    what about Silver/Crome-Line HTPC ?! :hip:
  5. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Moved to the Modding forum as this doesn’t yet qualify as a project log under forum rules here. Let an Admin or Moderator know once some solid work has been done and posted and it will be moved back to the Project Logs forum.
    Happy modding :) :dremel:
  6. white modder
    white modder What's a Dremel?
    19 Sep 2003
    big black
    lightening
    godlike case
    silver stripe
    Xcase
  7. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Silversurfer .... :D
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    'Project Barcode'
  9. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    my chromey homie theatery pcyyy
    :eyebrow:
  10. Pug
    Pug What's a Heatsink?
    16 May 2002
    How about Project Monoblock?
    The first thing I thought of when I saw the case was an amp.
    Otherwise "The Entertainer", as that's what it's hopefully going to do...
    It's a SilverStone then, is it? Looks nice in black.
    [Edit] :idea: Ooh, how 'bout Project BlackStone? Has a nice ring to it...
