Project Log: Vortex.Micro - Finished!
Discussion in 'Project Logs' started by XNDR, 31 Oct 2003.
  1. XNDR
    XNDR What's a Dremel?
    31 Oct 2003
    After browsing this board for a while I decided to register so that I could post as well... This will be my first post.. Here we go!
    I have built a custom alu/plexi case as a replacement for my home server which was very ugly, big and noisy. The case was designed around a Via Epia M9000 and it had to be small enough so that I could place it on my desk. The case would be in the line of sight all the time so it would be great if it looked nice... :cooldude:
    Here's a short version of my full project log:
    I first needed to get some plexi:
    And some alu tubes for the frame of the case:
    Time to assemble the frame:
    Finished frame:
    Mounted the Via Epia Mainboard and the PSU Cirquitboard:
    Mounted the CD-rom drive and the 240 x 128 Graphic LCD:
    Working on controlpanel:
    End result:
    The full project log can be found here:
    http://www.xndr.com/pages/hardware/vortex.micro/projectlog.html
    Let me know what you think! This is the first time that I've posted this mod on the web... I still had to write the project log... I'm currently working on my personal website, more mods and projects will be added during the following days...
    This is my first custom case project by the way... I got the LCD from Modwarehouse and the rest of the parts from local hardware and DIY shops.
    Stuff to do: The LCD cable still has to be soldered and I need to install the EL wire. I also have to find a way to get rid of the wire mess inside the case.. I hope that I can free some time for that next week.
  2. DrSpYdeR
    DrSpYdeR What's a Dremel?
    28 Oct 2003
    Good job, This is how I wanted to do my Project - Mini Me
  3. Shoobie
    Shoobie What's a Dremel?
    21 Oct 2003
    Cool mod man! I like the aluminum tube idea, rather than angle bracket things. I may have to steal that idea if I ever build a cube. :lol:
    No offense, but the wiring inside looks pretty messy, and the LCD looks a little unlevel. It's probably not, though. Just work on maganging those wires. And remember, I'm really just a wannabe modder (no tools yet :grr: ) so take this with a grain of salt.
  4. XNDR
    31 Oct 2003
    Yeah.. the wiring... I think I will add that to my 2 do list.. There are to much wires for such a small space.. but I'll try to figure out what to do with them..
    I will have to open the case anyway when I'm going to install the LCD cable and the EL wire.. My 120GB harddrive is also still lying on top of the CD-rom drive.
    Thanks for the comments :thumb:
  5. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    That alu tubing looks really clean. I like it.
    If you do get round to doing your cables, hope you will post more pics.
    I like the look of the control panel too, it really fits with the theme of the case....Good work man.. :D :D
    **Edit**
    And welcome to the boards, there is no turning back now!!! :eeek:
  6. djengiz
    djengiz Pointless.
    16 Aug 2002
    Nice! :rock:
  7. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Alright!! :clap: It's always good to see a fellow Dutchman do such a good job!
  8. XNDR
    31 Oct 2003
    I'll post some new pictures when I'm going to work on the wiring and and the LCD... A few shots "behind the scenes" are always interesting :cooldude:
  9. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    A suggestion for your wiring. You could try to hide some of it by running it IN the square tubing!
  10. CharlieCat
    CharlieCat What's a Dremel?
    12 May 2002
    And I thought I was the only one to use those plastic connectors/tubing :naughty:
    Very nice looking :thumb:
    What's the overall size ? it looks about 12" cubed to me...maybe smaller.
    Cheers, CC
  11. Hitman
    Hitman Minimodder
    18 Oct 2002
    That is very, very nice :thumb:
    I love the construction method, its so simple, yet it gives excellent results.
    I really need to make a case myself now :D
    Does any one know where I can get similar aluminium tubing and the plastic corner connectors in the UK?
  12. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    nice work man!
    looks great :clap:
  13. isisfreak
    isisfreak What's a Dremel?
    19 Jul 2003
    Looks good! Where did you get those corner pieces?
  14. Mr. Red
    Mr. Red Minimodder
    1 Aug 2003
    Sweet! Love the control panel. :thumb:
  15. Hitman
    Hitman Minimodder
    18 Oct 2002
    Yo can get the corner brackets at Ross Handling. :)
    Im just finding it hard to find the aluminium tubing.
  16. Shoobie
    21 Oct 2003
    That's a great idea!
  17. RaptorRed
    RaptorRed What's a Dremel?
    31 Aug 2003
    nice case man i realy want to see a shot of the LCD in action!
    ps you may want to turn your site link into a clickable via the magik of vb
    [edit] or html cant rember which for sigs [/edit]
  18. noCode
    noCode What's a Dremel?
    16 Oct 2003
    That is so sweet! Awesome minicube!
  19. Lithium
    Lithium super spunk
    26 Jul 2002
    Very nice job dude!!!
    Ya gotta get rid of that beige drive thought. A Coolermaster Silver Bezel would look sweet. Those feet have got to be lit up too.
    Nice work :rock:
  20. XNDR
    31 Oct 2003
    Thanks!
    I thought about stealthing the drive or something similar.. but I think I will leave it this way... It would have been nicer to have the drive match the case, but I think I will swap this drive for a DVD burner in a couple of weeks.. so it's not worth the trouble right now...
    The feet do light up when I turn the glow leds on... The leds shine through the plexi, downwards towards the feet.. It's just as if the feet have built in lights :D
    I spent a couple of hours yesterday to create the LCD cable. I also mounted the harddisk in the case (it was lying on top of the opened case for about 1.5 months.. :sigh: )
    I also wanted to install the EL wire in this case.. but I didn't go through with it.. there's just not enough space left :(
    Here are some nice shots of the LCD output and the caselights:
    I've also updated my project log.. you can find some more pictures and info over there...
    I think this project is done! Everything works okay now.. Finally some output on the LCD! Let me know what you think of the end result!
