Scratch Build – In Progress Project Log : Wooden Apple -- Small Update -- 4/2/08
Discussion in 'Project Logs' started by rowin4kicks, 30 Jan 2008.
  1. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    Hey guys this is one of my first logs, so be nice!
    I've had this idea in my head for a while now and have been flicking it around, however i have got alot on atm so i will try to get the updates going as fast as i can.
    The log is for a case to protect my 12" ibook G4 for when i take it to school and around about places, ect. Here are a few concept pictures i have knocked up for the log (edit the new images are below)
    By gilmr0001 at 2008-01-31
    The top opens up and reveals the secret inside!
    Start off with a large piece of wood that you have releaved from your schools stock pile :D
    By gilmr0001
    By gilmr0001
    Cut that bad boy in half, the perfect size to let me attach it to the mill later on!
    By gilmr0001
    By gilmr0001
    Size it up with the laptop, looks spot on!:thumb:
    By gilmr0001
    Mark out the outline of the laptop onto the wood, ready to router out the inner edges of the piece.
    By gilmr0001
    Quick shot of the router
    By gilmr0001
    Unfortunatly the design department at my school had a bit of a gas leak so i didnt get any pics of the outer egdes of the piece routed out. However the next day i came back to cut out the middle part of the wood.
    I used the wooden hole cutter type thing to cut out the unwanted wood as i have killed the router:wallbash:
    By gilmr0001
    By gilmr0001
    By gilmr0001
    Nearly done
    By gilmr0001
    By gilmr0001
    The mess i had to clear up afterwards as well! :eeek:
    By gilmr0001
    Unfortuanatly the hole cutter had not bode well for the levelness, and smoothness of the section i cut away, so i banged the piece onto the mill.
    This is much more like it! and much quicker as well!
    By gilmr0001
    By gilmr0001
    This is the wood as it stands now, still quite a long way to go! Needs to be cut down, sanded, and the edges rounded off!
    By gilmr0001
    By gilmr0001
    And with the laptop sitting in it!, remember the there needs to be another piece like that sitting ontop of it.
    By gilmr0001
    By gilmr0001
    By gilmr0001
    Thats it for now but expect an update soon!
  2. Supra55
    Supra55 New Member
    10 Oct 2006
    Nice work with the mill, always wished I had one :D
  3. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    good stuff :)
    will you run the laptop inside the wood? Cos i think you'll have a problem keeping it cool (no airflow).
    Also, how many peripherals are you carrying around? It might be worth the trouble to make a casing for usb mouse, power wires, etc etc.
  4. rowin4kicks
    5 Feb 2006
    No the case will be for carry the laptop around not operating withinin it! mixing apple laptops with wood is probably a bad idea!
    You my good sir are a genious! i had thought about making one for my ipod but now im definatly gonna have to have a go at other things now!
    thanks for the replies! keep them coming
  5. Cheapskate
    13 May 2007
    A laptop scabbard? Now I've seen everything.:hehe:
  6. NZ_mod_man
    NZ_mod_man New Member
    26 Aug 2007
    Different! But still cool. :)
  7. Stonewall78
    Stonewall78 New Member
    21 Oct 2005
    I would felt line the case so you don't scratch up the laptop.
  8. rowin4kicks
    5 Feb 2006
    My plans exactly, but i am undecided wheather to go for black or white lining!?!? i guess i will wait and see as it will be the last thing i do to the case.
    Be prepared for alot more detailed sketchup drawings on their way tonight!
  9. rowin4kicks
    5 Feb 2006
    Just updated the first post with my new skechup drawings! they look much better than the ones that were there before and are a much more realistic version of what the case will look like when finished!
    hope you like
  10. sik19
    sik19 New Member
    2 Jan 2006
    Wow that will be definetly an unique case for your macbook.
  11. TapperSwe
    TapperSwe New Member
    20 Nov 2006
    Cool project :thumb: , i love new ideas/solutions that has never been seen/done before GL.
  12. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    I am a pc lover and i despise mac but this is cool so subscribed
  13. rowin4kicks
    5 Feb 2006
    Hey guys first update
    I have finished the second piece of the case on the mill. Heres a few pics for you...
    By gilmr0001
    By gilmr0001
    I then proceeded to bolt and glue the two pieces of wood to create the case, i used 4 hex head bolts and some pva glue and left it in the vice and clamped it overnight.
    By gilmr0001
    Here is it the day after all glued...
    By gilmr0001
    By gilmr0001
  14. rowin4kicks
    5 Feb 2006
    Next day of modding commences, yesterday i was left with a couple of bits of wood that looked crappy. So i decided to do something about it, and took a band saw too all my hard work!
    By gilmr0001
    First cut ...
    By gilmr0001
    The second cut...
    By gilmr0001
    Third...
    By gilmr0001
    All tidyed up and squared off, i think it looks much better now and should continue too look better through the comiong updates!
    By gilmr0001
    By gilmr0001
    Laptop sitting inside ...
    By gilmr0001
  15. rowin4kicks
    5 Feb 2006
    Another update for tonight, i milled the sides of the case to start the rounding off process, which will make it much, much easier.
    By gilmr0001
    By gilmr0001
    First side done
    By gilmr0001
    Second side done
    By gilmr0001
    By gilmr0001
    All the edges have been beveled
    By gilmr0001
    By gilmr0001
    I used the belt sander to round off the edges that hadnt been beveled
    By gilmr0001 at 2008-02-03
    By gilmr0001
    By gilmr0001
    The started to file down and round off the beveled edges of the case.
    By gilmr0001
    By gilmr0001
    By gilmr0001
    Thats where i stopped tonight as it got dark and late, the case is probably about half way done as i still need to make the top section of the case. The finish of the case still needs to be decided, varnished, waxed or something special that i have planned...
    ... it should look good but i have to do some experiments on spare bits of wood.
    I should update later on in the week.
  16. widmod
    widmod Member
    9 Oct 2006
    looks good :jawdrop:
    i want one
  17. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    sweet lord of hell :) it's nice idea. I hope You will put smth. inside this wooden cover to protect your mac from scratches. Soon someone will copy your project but for macbook Air(won't be me for sure). This tiny laptop really needs protection :)...
    Good work rowin4kicks, i will keep my eye on this project!!
  18. jhanlon303
    7 Sep 2006
    Good start! Any idea on how much it weighs or will weigh when finished?
    John
  19. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    A rubber for your mac? ;P
  20. HeXeN
    14 May 2006
    good idea for big fans of mac... :D but i'm happy of my anty mac style of living :D
