Project .:M^4:. MultiMedia HTPC (update 8/6/4)
Discussion in 'Project Logs' started by BadKarma, 19 May 2004.
  1. BadKarma
    BadKarma What's a Dremel?
    4 Feb 2004
    This is my first mod posted on bit tech's forums. so far i have decided to name this pc M^4 which is short for "martin(my last name) multi media machine" if only i knew how to write exponents in html...
    anyway this box no larger than the average DVD player will house a mini itx board. the CL1000 to be exact. here are some specs
    1ghz
    256mb ram
    160 gig maxtor hdd
    150 watt psu
    slim DVD drive
    MO 20x4 blue LCD
    basicaly all of these components will be fit in a small a box as possiable. I am looking for something flat and wide rather than tall or long. here are some pictures of the first few mock ups in sketchup
    the motherboard will rest on standoffs elevating it above the DVD drive which will sit below it. the hard drive will be under the ati all in wonder. the ati will have all of its ports rewired to short cables that connect directly to the back of the case rather than use the cables it comes with. the motherboard will be mounted a few inches short of the back of the case. extension cables only for the ports needed (network and usb) will be made. a vga cable from the ati card to the back plate will be made as well.
    i am trying to get this to look as much like a finished product and less like a modded box. so the back will just have the necessary ports instead of a big rectangle cut out for the mobo.
    the psu will be re wired so i only have as much cable as i need and the right lengths. the final colors should be silver and brushed aluminum in the front.
    let me know what you guys think... more picture comming shortly
  2. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Mmmh, I suggest you re-thinking your fan placement: you have two fron fans for intake and no fan for blowing out hot air.....
    Just my 2 cents! :naughty:
  3. n0ll4k
    n0ll4k What's a Dremel?
    1 Jun 2003
    first i have to agree with papeniglio you should have one fan blowing hot air out of the case
    and i think you should try the new mini-itx board the EPIA MII 12000 because it should be a little bit faster with its 1,2Ghz
  4. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    you mean M^4 ?
    looks interesting, I hope it works out OK
  5. SJH
    SJH Minimodder
    24 Dec 2003
    Looking good so far :)
    -Sam
  6. dirk_j
    dirk_j What's a Dremel?
    19 May 2004
    I think he just means M^4 :thumb:
    M^4 = M4
  7. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    How do you write those numbers that way??
    Cheers,
    Mike
  8. Canuck
    Canuck What's a Dremel?
    25 Mar 2004
    Subscript Chars
  9. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    just type:
    PHP:
    M[sup]4[/sup]
    to get M4
    good luck with your project, the designs look nice =)
  10. BadKarma
    4 Feb 2004
    Well the design of the box has changed a little since i did those sketchup models.
    i decided to scrap the 2 fans in the front due to the ammount of noise they will generate. the psu fan is also now facing up instead of to the side and a hole will be cut in the top of the case to allow the air to come out. the psu will also suck air in from acrost the motherboard. i may add a fan near the hard drive to cool things down over there, otherwise that many fans are over kill.
    here is a pic of the current state of the project in a cardboard box :naughty: so i can get more of an idea how all the parts will fit before i decide on the final size of the real thing
    I know its a mess but it gives me a good idea of how big i need to make everything so that it fits right.
    this is a pic i drew a few min ago for the design of the front plate. soon as i can get the sketchup model finished (at work :D ) i will post those pics
    but this shows the basic layout for parts in the front. i want to keep it as simple as i can. the red thing is an ir sensor and the blue circle is the power switch. thumb screws int he corners and the vent hole design i came up with.
    more to come...
  11. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Iinteresting... I am looking forward to see what results from your so far ghetto modding :D
  12. BadKarma
    4 Feb 2004
    I have more sketch up pic's of the aluminum box that will be built with the demensions i need so far. my video card is comming tomarrow so I hope to start on the box then.
    front pannel
    back of front pannel. the blue parts willl be clear plexi with blue led's inside so that from the front the vents will glow a suddle blue
    assembled
    bottom piece
    Final box with demsions
  13. nightwalk8r
    nightwalk8r What's a Dremel?
    26 Apr 2004
    How did you get your Capture card to sit like that?? a riser?
  14. nightwalk8r
    26 Apr 2004
  15. BadKarma
    4 Feb 2004
    yeah. i found a nice small one designed for servers for $5 online and with the height the mobo will be raised with the standoffs and the height the riser extends the card it should just clear the har drive below...
    *note that is not the AWI card in the picture.. its actuially a isa sound blaster used to give me an idea of how much room the card would take up.. the real card is on the way and will be here tomarrow. 32mb ati aiw off e bay. should be just plenty for watching movies etc.
  16. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    32mb! :eek:
    I really like the front panel, very cool looking. But don't use red for the IR reciever area, it sticks out too much. Use black tinted plexi instead (or maybe some blue plexi to match theme).
    P.S. it's spelled "subtle" :p lol, sorry, doing english homework at the moment.
  17. BadKarma
    4 Feb 2004
    the red color was only there to show what that shape was. in reality it will end up looking black and hopefully blend in well.
    more updates tomarrow inc. the Ir circuit and some custom cables :)
  18. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looks like my server design...
    I like the sketchups or what ever you used. Looks like you have your hands cut out there. Good luck
  19. Rogan
    Rogan Not really a
    6 Oct 2003
    agreed, and maybe you should try to fit larger slower fans in there, those look suspiciously like 60mils, they'll be noisy :worried:
    looks really compact laid out in mockup though .. nice :D
  20. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    looks very nice ideas but i would agree with Rogan, a larger fan running slower, maybe 2 80mm's at 7v, if you get decent ones they should be inaudible
