Case Mod - In Progress Project M1
Discussion in 'Project Logs' started by Cpt.Zakhar, 27 May 2019.
  1. Cpt.Zakhar
    Cpt.Zakhar What's a Dremel?
    25 May 2019
    It's been a long time since I’ve this idea in my mind to make ITX CASE and several time I designed many cases with different ideas but Unfortunately none of them goes further than that
    but in few months ago I started to design a new project and its almost toke around 120 hours to be completed
    the entire case will be built by 4 mm & 10 mm aluminum sheet and the entire fittings, tubing will be custom made as well as Distro Plate.
    Spec:
    M.B: Asus ROG Strix Z390-I
    CPU: Intel Core i7-8700K
    VGA: NVIDIA GeForce GTX 1080 Ti FE
    Ram: Corsair Dominator Platinum 32GB (2x16GB) 3000MHz C15
    PSU: Corsair SF600 Platinum
    Storage: Samsung 970 EVO Plus 500GB
    Dot_Kappa likes this.
  2. Cpt.Zakhar
    25 May 2019
    Update #1
    I made a few fittings with 20mm brass tube and they look good and I’m happy with the results.
    also made a reservoir out of curiosity, which is very heavy due to the weight of brass
    [​IMG][​IMG]
    [​IMG][​IMG]
    arduum, Dot_Kappa and Cheapskate like this.
  3. kim
    kim hardware addict
    10 Jan 2016
    wow, heavy metal modding here :jawdrop:, renders are more than yummy :naughty:...I feel a stunning mod coming to life :dremel:
    Cpt.Zakhar likes this.
  4. Cpt.Zakhar
    25 May 2019
    Thank you for your kind word
  5. Cheapskate
    13 May 2007
    On your first project post, you pull out a lathe. :D I suspect you will be popular here. Welcome to BitTech.
  6. Cpt.Zakhar
    25 May 2019
    thank you, it's not mine but i wish i had one :grin:
    I'm not a moder and doing this out of curiosity.
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Custom reservoir made of brass :clap:, I can't miss this log.
    What about the cylinder ?
    Remember, Glass is the way...:grin:
    Uh, you think so? :nono:
  8. Cpt.Zakhar
    25 May 2019
    yea, that's right. GO BIG or go home :thumb:
    it's so heavy, more than 3 pound just for Compare with EK-RES X3 250 it's 2.5 times heavier.:hehe: its hard to keep it in place :grin: it's easy to find acrylic tube but I'm thinking about glass.
  9. bolous
    bolous What's a Dremel?
    14 Nov 2012
    Great mod: from the model it seems very cool. Maybe it will be an hard work but incredible result. Chapeau!
