Case Mod - In Progress Project M8 (CaseLabs M8 workstation mod) COMPLETED! Final pics on page 33
Discussion in 'Project Logs' started by p0Pe, 13 Apr 2011.
  1. peteski
    peteski long live the pc
    8 Jun 2011
    looking good mate :rock: :rock: :rock:
  2. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    thats is just too seeeexy !
  3. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Same as above :D.
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks man! Glad you like it! :)
    I like both Homer drool and +rep:D Thanks;P
    Thanks Pete!
    Thanks dude:D Might not be as compact as your build though lol:D
    Hehe thanks:D
    A little something something I am working on:) What do you think of the design?
    LooseNeutral likes this.
  5. LooseNeutral
    LooseNeutral New Member
    13 May 2010
    :jawdrop: ...reaches for chest ... *gasp ..*cough ... you're killing me pOPe!
    [​IMG] I wants pleeeeese!
    p0Pe likes this.
  6. yassarikhan786
    10 Aug 2011
    That design look's fantastic to say the least, I love it.
  7. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    This is insane pOPe!
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I LOL´d at that picture:D +rep xD
    Glad you like it ! :)
    Thanks hannes! With photoshop, everything is possible:D
    A tiny update:) Got the front reservoir done with plate and everything! :)
    Got the reservoir + acrylic plate screwed onto the front:) I will use different bolt/screws for the final mount, but this was what i had:D
    Fillport in the top^
    As you can see here, the fillport goes down into the reservoir. This should make filling quite easy.
    Also drilled a hole in the bottom to do the same thing there, but havent drilled the hole into the reservoir yet.
    And a few views over the hdd holder, and how I will route tubing from the motherboard side to the reservoir.
    A little closeup of the thing i printet to fit into the precut holes on the M8 case:D
    Thats it for now lads:) Off to prepare for another exam -.-
  9. riekmaharg2
    riekmaharg2 has started the PowerCore scratch build
    22 Feb 2009
    Wow your measurements really are good, everything fits absolutely perfectly :thumb:
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks Kier! Measurements is key in this build:D One wrong one, and I Have to make a new part -.-
  11. myrizzle
    myrizzle Member
    23 Nov 2011
    HP, old pal.. You ownz :D
    Someday i will come visit your evil modding lair :dremel:
  12. yassarikhan786
    10 Aug 2011
    Yeh man, I must agree with all of the above, everything fits so neatly/perfectly :)
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I will make cookies then:D
    Thanks man! :D
    Small update! I have 3 suprises for you over the next couple of weeks:D This is one of them, and you can proberly guess what it is! ;)
    Big update will come soon, but for now, a big thank you goes out to Gareth from Corsair;)
  14. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Nice. That was what I was asking for earlier. ;)
  15. -Jv-
    -Jv- New Member
    29 Mar 2011
    Very nice work I have to say !
    On the logo: very nice but why does everyone has to go over the top with inner glows and drop shadows ? I'd also go for black&white, not brown&white :p And for the love of god remove the yellow from that inner glow. Sorry for the 'harsh' comments but I couldn't stop myself. I'm only giving tips :D
  16. Cheapskate
    13 May 2007
    Looking majorly sweet. I have to say using the printer for something that can be milled seems overkill, but if that's what you have access to... kill ...over?
  17. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Yeah... I want MOAR! :)
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome job Pope! This will go down as best M8 project in History :rock:
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    I ever so slightly overlooked the project name & didn't know the case model was M8, thought the M8 was short for mate :hehe::lol:.
    And I'm as sure as Bill this will be the best M8 project :rock:.
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Oh noes what has been seen can never be unseen :( !
    Looking awesome dude, seems like you have the contrast between white and black working perfectly and the component placement is just genius!
