Case Mod - In Progress Project M8 (CaseLabs M8 workstation mod) COMPLETED! Final pics on page 33
Discussion in 'Project Logs' started by p0Pe, 13 Apr 2011.
  1. Huge
    Huge aka Dave
    11 Jul 2011
    Sweet build man! Going to keep an eye on this one.
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome! Your builds are always amazing Pope :rock:
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    nice! love the rads ! :D
  4. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Sweeet rads indeed :D
    May have to get one of them if I eventually watercool my next PC build :D
  5. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Will you even need both ?
  6. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks man! :)
    Thanks Bill:D Yours are rocking too:clap:
    That makes two of us :D
    I dont know much of the performance yet, but the build quality is awsome!
    Both? There is 3 dude:p And it is massive overkill :rock:
  7. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Those rads are gorgeous!
    Where from?
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    They are Aquacomputer AMS radiators:)
  9. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    That's some awesome radiators dude! nice to see the build progressing along smoothly :D
    We are looking into getting a 3D printer at work, every time I read more of your log I keep getting inspired and praying they decide it's a good idea :D
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Time to get on with this, so it will be somewhat ready to S7 Lan at my school:p
    First of all, I have been busy with some other stuff that I will post tonight, or tomorrow:D But i will give you a teaser:
    Anyways, on to the big and expensive thing that I am about to cut holes in :D
    So, as mentioned earlier i had to cut off a piece of the mobo tray to make it fit with the radiators.
    Also had to cut off the two thingies that I think is supposed to hold some feets for the mobo tray, if you want to use it as a bench table :D
    Like a glove! Fits lovely in there! :)
    So, got my hands on some raw material! From this,
    I made this. But what is it? I will show in a min.
    First, I cut a hole in the case :D This hole lines up with the radiator in the other side. You see, instead of connecting the two radiators with tubes, I will just connect them with the piece shown in the previous pic.
    So just put it in, make it go into the radiator on the other side aaand...
    Mount radiator number two:) Saves me a couple of fittings, and it looks darn clean!
    Here you can see it connected to the two radiators:)
    That was all for now fokes. I have some dye coming in, so that I can hopefully colour the 3d printed stuff in a real black, and not some brownish like the last dye I got :(
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Sweet solution, but how will you make the threads to make it possible to screw this piece into both rads at the same time?
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    I guess it must just plug in nicely & not screw in :) knowing p0Pe I'd say so, big on the tiny details :rock::D sweet little piece :thumb:.
    Nice fit for the rad too :).
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks mads:D And for your question. Look below:)
    As always, you are right waynio:p
    This pieces:
    Have o-rings in both ends, so the pieces is just "plug and play" :) Took quite a while to make it on the lathe, since the measurements had to be exactly if i did not want it to leak:D
    I am at the moment building a "leaktester" that will work with air and a pressure gauge, so i dont have to fill water in the loop to leaktest lol:p
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    3d printer = amazing
    I am jealous
  15. Korvus
    14 Apr 2011
    Are those radiators Aluminium on the inside or just the fins? They are just too nice looking.
  16. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks mate:D
    They are brass on the inside i think, or copper:) The fins are alu:D
    This aint dead guys:D Just been very busy with other stuff :(
    Came around to mill a prototype for the small "reservoir" :)
  17. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    LIKE A BOSS! nuff said.... :)
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    Ugh I want some deus ex type implants so I can match the accuracy & speed of CNC with a dremel :D:hehe:.
    Looking good p0Pe :).
  19. alain-s
    alain-s Minimodder
    12 Jan 2011
    Looking good pOPe ^^
  20. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Haha thanks Alex!
    Thanks dude!
    Thanks:D
    I will do another testrun tomorrow with the final settings for the POM I will mill this from. I should have the acrylic i need next week so hopefully the final reservoirs will be done sometime next week:D
