Case Mod - In Progress Project: Macross Frontier Side Panel tile spacers/glue for side panel part 2
Discussion in 'Project Logs' started by milotic858, 4 Mar 2009.
  1. The boy 4rm oz
    10 Apr 2008
    Simply amazing, they both look insane.
  2. Infiniti
    Infiniti i modded the wheel!
    3 May 2009
    Man thas some mad skillz with the etching work!!! pretty damn awsome! loving the logo's to truly inspired, can i ask if you will be tackeling the airflow off this case? most reviews ive read say that its pretty poor due to the location of the psu smack underneath one off the 120mm fans?
    still awsome work so far def watching this one from now on:thumb:
  3. numps
    numps Noob G5 Modder
    30 Apr 2009
    I like the paint work u've done so far...the yellow is very coo...
  4. milotic858
    milotic858 What's a Dremel?
    20 May 2008
    Side Panel Armor
    I test cut all the pieces of the side panel armor on cardboard first in order to do a test fit. Used cardboard because it is cheap = free. Just used pieces from leftover boxes that I would have thrown away anyways. It really helped me get a better idea of what the side panels will look like.
    First test panel armor
    This is the first idea and test for the side panel. I decided to redesign it, but figured I would show you guys. The panel that will hold the skull leader logo isn't big enouph, so I had to change that. It just seems a bit too uniform. Went back to the drawing board and redesigned it.
    Redesigned side panel with nuts
    I added the appearance of nuts to each panels as if it were really screwed on. It adds a more authentic look that is similar to the battleroid.
    All the "nuts" together in a pile....I think I might be regreting this part. They are so tiny.
  5. milotic858
    20 May 2008
    I did notice that about the location of the psu. Right now the case is in pieces, so I haven't really thought about it, especially since there isn't any hardware in it yet. But, thanks for the heads up. :thumb:
  6. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    wow.. thats really cooll..
    looking forward to more soon i hope
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Love the industrial design! :thumb:
  8. TiTON
    TiTON IRONMODS
    23 Mar 2004
    Wow.. the panel layout is nice!! Can't wait to see more :)
    - Ton
  9. docodine
    docodine killed a guy once
    10 Feb 2007
    This is going to be a great mod. :eek:
  10. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Nice design, and a fine laser cuted skull leader.
  11. milotic858
    20 May 2008
    I have a lot more to do with this mod. So, you definately will be seeing more. :thumb:
    I am glad you like the design. I had to make sure I didn't make it too girly :p Maybe one day I will do a girly mod.
    Thanks... working on getting this case done faster. Had a bit of a mental block :wallbash:, but I think I am on the right track now!
    Thanks. :blush:
    I thought about taking a dremel to it, but just can't get the details that I wanted out of it.
    next update coming soon....
  12. milotic858
    20 May 2008
    Now that I have tested the panel pieces and everything fits the way I want it, this is the layout of the panels. The blue coloring is just the plastic backing left on. It makes it easier to see.
    Skull Leader side panel
    The very tiny nuts that will go in each circle
    SMS logo side panel
  13. TiTON
    TiTON IRONMODS
    23 Mar 2004
    WOW!!!! that looks awesome. I am assuming that the plexi backing will come off. are you going to be painting the acrylic parts?
    - Ton
  14. DonT-FeaR
    23 Jul 2008
    oh cool that looks great
  15. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Awesome! Looks like a shield from the middle ages. You going to back light that skull leader?
    Great work Milotic! :thumb:
  16. milotic858
    20 May 2008
    You've got it right! Prime and paint is up next. Yes, plexi backing come off. It makes some interesting sounds when you pull it too. :D
    Thanks :thumb:
    I'm not sure what to do with the skull leader right now. Want to light it up, but don't think drilling a hole in the side panel is an option right now. Any suggestions?
  17. The boy 4rm oz
    10 Apr 2008
    Beautiful plexi detail, truly amazing.
  18. milotic858
    20 May 2008
    Sand, prime, and paint
    The panel is pretty heavy so to make it easier to paint all sides I put it on a lazy susan. It made it so much easier
    All the pieces that will be on the side panel
    Painted the side panels a mechanic grey. This will serve as the base color of the side panels.
    Side panel all together.
  19. skreenname
    skreenname SFF Forever
    11 Jun 2009
    That bright yellow you're using reminds me of Gundam.
  20. The boy 4rm oz
    10 Apr 2008
    Lol same, I love the Gundam Series.
    I really love the colours on the side panel, very nice colour scheme.
