Case Mod - In Progress Project : Make It Black : Finished : 4/5/10
Discussion in 'Project Logs' started by The_Beast, 28 Mar 2010.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Another simple, no sponsor case mod, much easier than my last, or so I think :lol:. So lets get right to it....
    Look familiar? :hehe:
    Everything hung-up and ready for priming. Don't worry the sticker was taken off before painting.
    Everything is primed, even the screws.
    Tomorrow is wet sanding, oh joy :sigh: but I'll soldier on :dremel:
  2. The_Beast
    21 Apr 2007
    A boring update I know but an update none the less
    After drying overnight, I wet sanded at 1000 grit
    Everything was washed, dried with a hair dryer, then rubbed down with rubbing alcohol. Everything was rehung in the garage/paint booth :hehe: and then primed again.
    Everything was then rehung again in the basement to dry overnight
    Tomorrow is wet sanding an then painting :thumb:
  3. The_Beast
    21 Apr 2007
    Everything was wet sanded at 1500 grit, washed, dried, and rubbed with alcohol clean the surface just in case anything was missed in the washing. After everything was hung up in the garage (aka my paint booth) they were painted with Rustoleum flat black auto paint.
    I can't do anything since the dry time is 2 days, so no update tomorrow but the next day there will be.
  4. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Looks good.
  5. _-..zKiLLA..-_
    _-..zKiLLA..-_ Member
    8 Jan 2008
    Gotta love flat black +1
  6. The_Beast
    21 Apr 2007
    Well I wet sanded again today and put another coat of flat black on, I would have pic but they would be the same as above. Right now everything is hung up to dry, final pics should be up within a few days.
  7. The_Beast
    21 Apr 2007
    All done
    Since the paint sealed the button some paint had to be removed so it would work, it's a little sloppy but everything is fixed now
    Since black is hard to see in the dark recesses of my desk this will have to do for now
