Case Mod - In Progress Project : Make it shine : Finished : 3/20/10
Discussion in 'Project Logs' started by The_Beast, 21 Feb 2010.
  1. shakka65
    shakka65 New Member
    17 Jan 2010
    This is incredible! I may be picky, but although I can see some of the mirror shine you put on the case. It could still use a little more light to see the true fruits of your labor.
  2. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Ok, i'm a bit confused... what did you do to get to this result?
    320 -> 1000 -> 1500 -> 2000 -> rubbing compound -> Mother mag polish (?) -> dremel cotton wheel.
    Is that it? i'd like to know, i have a few parts with which i'd like to attempt the same finish, you made me want to invest the time with those pics :D
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Do you have any suggestions on photographing a mirror?
    Thanks
    It went like this
    120 -> 320 -> 1000 -> 1500 -> 2000 -> Mothers mag polish with felt dremel tips -> Some hand polishing with a microfiber and Mothers to remove any marks left by the dremel
    I will suggest that you don't use 120 grit, it's too rough of a grit and is a PITA to sand out with later grits. The rubbing compound would work but I found the Mothers to be better (if you can't find it in holland) plus it has a built in wax that protects the finish.
    Also as a tip, more so for 1000 grit and up, sand left to right, look for and deep scratches (sand them out), sand up to down, look for deep scratches (sand them out), then sand in small circles. Then move onto the next grit and repeat. If you find any imperfections (like missed spots) after polishing you can spot sand with 2000 grit and repolish.
    Just another FYI after you polish with the dremel (or whatever) you're still going to have to hand polish to remove the tooling marks the dremel leaves behind. But still using the dremel is worth is because it saves a lot of time and effort hand polishing the whole thing. And always polish in one direction, both dremel and hand. Hope this helps
    What kinda finish is on the part you want to finish?
  4. jhanlon303
    7 Sep 2006
    Could you please tell an old guy who doesn't get out much who makes the enclosure? I couldn't find it in your log but then I'm old and tired.
    john
    Oh, And I had to give it some stars since it looks so much like one of my G5 cases and the work was excellent.
  5. The_Beast
    21 Apr 2007
  6. InfernoZeus
    InfernoZeus Member
    30 Jan 2010
  7. Darkraven
    Darkraven New Member
    23 Dec 2006
    Great job !! :thumb::thumb:
    And good point on photographing a mirror. Even case windows cause problems with reflection.
    Seems like I've spent far too much time polishing stuff, between hot rods & motorcycles it can eat up a lot of time. Sometimes worth it tho, seems like polished aluminum, nickel and stainless have a depth that chrome lacks.
    Mothers has a billet polish that works great. Also had good luck with charging my cotton wheels with jewelers rouge. Couple other products I've found that work well; Meguiars Scratch X, tho only use it on smaller pieces. And Eagle One Nanowax for further protection without creating more work from impurities in the aluminum bleeding back up.
    But like a good paint job, you can't side step the prep work, it's all about the sanding. You can't polish pits, gouges and scratches. Nice to see some people understand this and willing to show folks the results of going the extra mile.
    Hats off to you mate, :thumb:
    Now if someone would just get the words time, tarnish, oxidise, and weathering out of the equation.:wallbash: :D
  8. The_Beast
    21 Apr 2007
    With time, work and the right tools anything is possible, go for it
    I don't mind a little touch up work now and then to deal with, tarnish....
    BTW thanks for the kind words :thumb:
  9. Xtrafresh
    27 Dec 2007
    Thanks for all the tips!
    It's this little mosfet block i'm making:
    I figure that with a good polish those tubes will reflect nicely and look even better. I'm going to light the red fluid with a little UV-lightplug in the fitting, so a good polish on this piece will make it pop out even more :)
    I have two new ones that aren't bent yet, and i'd like to polish them before i do. I'll show you my succes (or lack thereof) in a few hours :)
    Sorry for thread-hijacking, but since you are done, i thought it would be a nice follow-up to see how a complete newbie (to polishing) like me fares :hip:
  10. Xtrafresh
    27 Dec 2007
    Hmmmm. I've done some experimenting, nut never got anywhere near the mirror-shine you got. I'll have a look into getting some polish and lint-free cloth tomorrow, so far all i have is the dremel polish and a kitchen wiper :D
    Still thanks for all the tops, i've come a long way!
  11. Cheapskate
    13 May 2007
    :D
    1. Take it outside in the daytime to photograph.
    2. Turn it so the mirrored surfaces don't reflect directly back and show that you are naked while photographing. (-outside even! Shame on you!:nono:) This works good for a flash too. (-not the naked kind...)
    3. Use a tripod/table and the camera timer.
    4. For black and mirrored surfaces: Put a sheet of paper in front of the dark object you wish to photograph. Use the timer feature on the camera. Hit the shutter button, let the autofocus do it's thing, and when the timer starts counting, remove the paper.
    5. Don't use a friggen/bloody cellphone camera!
    Actually I'm content with the last set. I could see the finished work this time.:D Excellent work.
    I think John wants to make a pico g5.:worried:
  12. The_Beast
    21 Apr 2007
    Sorry it's the only camera I have. How did you know I was naked? Are you spying on me?
    As for the pico G5 (I've had the same though after seeing the wooden level 11 here on bit), check this link out, the Mac Pro Ultra Mini
    http://wolphbite.com/blog/?p=62
  13. The_Beast
    21 Apr 2007
    Just remember it's allin the prep work, because remember you can't polish a turd
  14. Xtrafresh
    27 Dec 2007
    O rly?
    Anyway, advice well taken. I'll sit down with some good stuff on TV, and start rubbing. Gosh, i'm really happy that didn't come out wrong in any way... :eyebrow:
  15. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Fixed, just use the part after V=
  16. Xtrafresh
    27 Dec 2007
    thx, fixed too :)
  17. The_Beast
    21 Apr 2007
    Just an FYI, the case shows finger prints like no other and if pretty easy to scratch. And what I'm really kinda pissed at is the fact that the threading is really lose compared to what it was before I polished it.
    So if you're thinking of doing something like this you know
  18. Matticus
    Matticus ...
    23 Feb 2008
    Glad you bumped this, really love the look of the enclosure. Was going to pick one up myself, $40 in the US or £50-£60 here, kind of annoying that it is double the cost :(
    Looks great though, shame it hasn't turned out exactly as you wanted. Not really knowing much/anything about polishing myself, is there no way you can seal in a mirror finish? Would a clear lacquer ruin the look of it?
  19. bulldogjeff
    2 Mar 2010
    I missed this one totally, thats a really nice finish. I'm going to have to try some thing like this myself some time...Top polishing dude:dremel:
  20. The_Beast
    21 Apr 2007
    Honestly I'm more pissed about it messing up the threading. The feet don't attach right and it's pretty wobbly. I don't really mind having to wipe it down every time I look at it. All in all, I would do it again, just protecting the threads this time. BTW check out my "Make it Black" same thing except flat black paint instead of polishing, a TON less work :lol:
    Once I repolish it, I'll probably think of some kind of coating/seal. At the time I was pretty busy with school and work, I'm surprise I even go it done. It took a lot longer than I thought it would, partly because I started out with too low of grit
