Scratch Build – In Progress Project Malin *update 2/9*
Discussion in 'Project Logs' started by shinji2k, 20 Jan 2013.
  1. shinji2k
    shinji2k Member
    15 Sep 2012
    Project Malin
    Concept
    I ended up with an extra i5 so I decided to do something simple to keep me busy during the winter. mITX seemed the way to go so I picked up some more parts and I was ready to go.
    According to the internet, Malin can mean "little strong warrior".
    Components
    • i5-3570 (non K)
    • ASRock H77M-ITX
    • 150W PicoPSU
    • X-25M 80Gb
    • Noctua NH-L9i
  2. shinji2k
    shinji2k Member
    15 Sep 2012
    Update #1
    Pile O' materials
    These will be the sides.
    Pieces of 1/2" to join everything together.
    Sometimes hand tools just work better.
  3. shinji2k
    shinji2k Member
    15 Sep 2012
    Update #2
    These will be countersunk eventually.
    Cut the mid-plate.
    Time for the bottom. More flat head screws are on the way so ignore the random hardware.
    Case feet from an old Lian-Li case.
    Cut the top panel. Nice spacers are on the way too, just using washers for now.
    Picked up some maple for the front and back.
    Threaded inserts for joining everything.
    Here's where it sits for now.
    I don't have much time during the week so hopefully there will be an update next weekend.
    Livio likes this.
  4. GuardianStorm
    GuardianStorm Active Member
    26 Apr 2005
    Very nice so far, subscribed :)
  5. Guest-23315
    Guest-23315 Guest
    Pweety.
  6. Mosquito
    Mosquito Active Member
    24 Mar 2011
    Nice work. Reminds me of the Mini-HTPC I built.
  7. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    What a wonderful start! look forward to seeing the progress :)
  8. shinji2k
    shinji2k Member
    15 Sep 2012
    Thanks!
    :D
    Hopefully it turns out as nice as yours!
    I hope you aren't disappointed. ;)
    I've already had a bit of a rethink. I was set on hiding as many screws as possible and made a lot design choices based on that, but then I have four right on top where everyone can see. That top panel is only there to mask the fan intake and cover the screws holding the side rails on so I think I will make another piece but just mount it with magnets.
    I was also set on a minimalist, modern look but I've been thinking of adding some small accents. Some art deco-ish alu inserts in the wood may work and/or something on the side rails. It'll still be sleek and simple but I'm hoping to give it some character. I'll play around and see if any of my ideas actually look good outside of my head. Thanks for reading!
  9. Ream
    Ream Member
    17 Nov 2010
    Looks real nice, would sit rather pretty nest to my TV.
    Cant wait to see the finsihed photos.
  10. exexs
    exexs Member
    4 Mar 2010
    Boner alert
  11. dream1
    dream1 New Member
    26 Feb 2011
    Wow ooks good so far :)
  12. shinji2k
    shinji2k Member
    15 Sep 2012
    :worried: I'm flattered?
    Me too :D
    I'd love to show you more but it's way too cold right now to be out in the garage, my little propane heater won't do much.
  13. morgansk
    morgansk I've got wood
    12 Jan 2013
    Very nice - and good to see some wood. :)
  14. Ream
    Ream Member
    17 Nov 2010
    Can you see exexs from where you are.
  15. Sissilisko
    Sissilisko New Member
    26 Apr 2012
    that's really nice :)
  16. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Seen a lot of SFF Pcs lately. Liking this so far. Ill be watching.
  17. shinji2k
    shinji2k Member
    15 Sep 2012
    Update #3
    I prefer to have the countersink the same diameter of the screw, but I didn't feel like buying a countersink to fit my 6-32 screws. So I made my own. Grabbed a cheapo from a local hardware store and ground it down to 0.300".
    Used it to countersink everything and install the mobo standoffs.
    I also went ahead and finished counterboring the screws for the front and back panel.
    Time for the cpu intake.
    There should be just enough space under the mobo to mount two 2.5" drives. I'll probably only be using the one ssd but there was room for a second, so why not.
    Rabbiting bit ready to go. Don't try this at home! I purchased a mini mill for cheap but it's back-ordered so I won't be able to use it for this project. I wish I had it for this.
    I ended up redoing the wood pieces. It was really hard to get everything lined up when I installed the threaded inserts. I cut the new ones slightly oversized and will trim them down later.
    It started to get late so that's it for now. It'll be pretty warm the next couple days so I hope to get some more done.
  18. dream1
    dream1 New Member
    26 Feb 2011
    LOL me "ooks" good.
    :D:D:D
  19. Guest-23315
    Guest-23315 Guest
    That HDD mount is awesome.
  20. shinji2k
    shinji2k Member
    15 Sep 2012
    Update #4
    I squeezed in a little modding today. First up is finishing the hdd mount. Since I prefer to keep all my fingers, I made a jig to route the other side.
    I had to order more 1/8" to redo the top and it came in today. I never bothered to show how I made the other panels so I'll walk you through my technique. First, a rough cut with the jigsaw.
    Then to true up the edges, a belt sander at a 45 deg angle works wonders. Just move side to side with it and you end up with a nice edge.
    I also received my neodymium magnets. I'll wait until I decide on how I finish the aluminum to glue them on to the top panel, but here's how it'll work.
    I also trimmed down the new wood pieces.
    I still need to do some fine tuning and cut out the I/O panel, but it's starting to come together :rock:
    Thanks for reading!
