Project: MAXcube
Discussion in 'Project Logs' started by mr.X, 21 Apr 2005.
  1. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    Hi everybody,
    Just a couple of months ago I saw a casemod somewhere on the internet. That was the first time I saw such a modded computer :eeek: and I liked it a lot. So I went on searching the net for more casemods and a little later I found this superb forum. I've been watching a lot of project logs over the last couple of weeks and I think I'm quite hooked right now.. :thumb: So here I am with my first project log of my first mod ever (wish me luck). :clap:
    I'm starting with a lot of acrylic plates, my workmate, a hacksaw, jigsaw, files, sandingpaper and so on.
    First I'm going to make three cubes out of the acrylic. I'm planning on putting the DVD-Rom drive, FDD and fancontroller in the bottom cube. On top of that cube there will be another (smaller) cube. In that one I'm planning to put the harddrive. And on top of the second one, I'm putting the last cube. In there I'll put the PSU and mainboard. It will be a simple computer because it only will be used to surf the internet (so no spicy features on this one). :p
    Enough talking.. Let's get on with some pictures.
    The acrylic I'm using:
    The first plates:
    Some serious sanding (they were not all the exact same size):
    A quick test fit (with tape):
    Now I was looking for a way to connect the plates. I don't wanted to use the "connection cubes" (?) I've seen in several acrylic cases (you can buy) because I don't like them sitting in the corners. Because I want to have green UV acrylic too in my case (yes... I know I'm not the only one), I figured that I could make the connections out of the green acrylic:
    WHAT was I thinking?? Pfff what a lot of work this is.. :duh:
    And now I only need to do "some" more filing, sanding (lots of sanding..) and polishing the edges. :naughty:
    Untill the next update..
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Cuberific :D
    Just dont fall into the stereotype of making it into an electronic lightbulb with big obvious cathodes ;)
  3. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Haven`t you got any arts of your idea`s :idea: :idea:
  4. Redwolf
    Redwolf Supermodel
    7 Apr 2005
    too many cubes, boot good luck.
  5. BagUd
    BagUd What's a Dremel?
    5 Jan 2004
    have you got any images of what it will look like.
  6. mr.X
    15 Mar 2005
    RotoSequence: there will be lights in it but not much. A little UV and maybe green.
    I'm not that much of an artist but I gave it a try.. This is the main idea :idea:
    Still filing and sanding... :dremel:
  7. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    interesting design, this could turn out pretty well!
  8. mr.X
    15 Mar 2005
    little update
    After hours and hours of filing and sanding, I couldn't stand it anymore and wanted to do something else. So I decided to try to mod a DVD-ROM drive. :dremel:
    First I wanted to give the housing a nice color but after I took ik apart, I got another idea.
    Let's get creative:
    A little hot air and bending to do
    tadaaa
    I needed the round "thing" from the inside of the original drive:
    A little glue:
    Now the inside can take place in the "new" housing..
    And last I made a "lit" for the bottom-side:
    Still have a lot of filing and sanding to do before I can put together the first cube.
    See you at the next update..
  9. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    I really like the design of the case. It has originality. Nice design skills you have there.
  10. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    sweet work dude and really nice original design.
  11. Pitbull
    20 Mar 2005
    LOOOl nice :D
  12. MikeK
    MikeK What's a Dremel?
    6 Feb 2005
    Impressive!!!
    Wow, that looks like a really good idea, haven´t seen anything like that and i really like it.
    Good luck and don´t forget to update. :rock:
    I give you at least six :thumb:
  13. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Hmmmm.... My favorite Color... Let's see where this goes, I'm intrested.
  14. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    cool uv neon green
  15. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Wow Im very interested in the project. I love anything with acrylic, but might I ask where you got youre UV neon green acrylic from? I need some :D
  16. mr.X
    15 Mar 2005
    thanks for the nice replies everybody. That's one reason to put even more effort in it :D
    Because I liked the new housing for the DVD-ROM drive, I wanted also to make new housings for the FDD and for the FanController.
    FDD
    new housing for FDD
    New housing for FanController
    All together now :D
    :hip:
  17. white modder
    white modder What's a Dremel?
    19 Sep 2003
    looking great man
  18. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Maybe you should paint or vinyl dye the plastic innards of your cd drive so they present a nice background for the uv shell. I like the looks of this project so far, very cool looking.
  19. RotoSequence
    6 Jan 2004
    Loving the green acryllic housings :thumb:
  20. BrokeEnthusiast
    28 Mar 2005
    did you find a how to guide to do that? I want to do that to my CD drives and my Hard drives even tho its kind of dangerous...
