Project: MAXcube
Discussion in 'Project Logs' started by mr.X, 21 Apr 2005.
  1. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    That looks damm amazing :D :thumb:
  2. morishani
    morishani What's a Dremel?
    29 May 2004
    So far so good :)
    love it.
  3. Jipa
    5 Feb 2004
    I don't like that green UV-plexi because of:
    1) I don't have it
    2) It is just too yellow to be cool :< IMO.
  4. GuardianStorm
    26 Apr 2005
    Im not a fan of floresant green, but i think it works really well with your design, as i said earlier, "That looks damm amazing" and it does :)
  5. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    This is gone look sick when its done, although it will be one of those projects that I like to watch more than just see finished, cause then its over :sigh:
    But Keep it up man!
    -Brad
  6. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    Thanks guys for the nice comments. :clap:
    And a little update. I've been very busy lately so I haven't been able to do a lot. I also promised you a picture in the dark:
    Nice.. isn't it? :D
    The middle cube is my next target so.. here it is
    And this is the way it'll look at the end. In the middle cube there only will be the HDD.
    until the next update
  7. GuardianStorm
    26 Apr 2005
    That looks awesome :) well done :)
  8. bjones247
    bjones247 What's a Dremel?
    30 May 2004
    Nice. The picture in the dark is incredible.
  9. DLoney
    DLoney What's a Dremel?
    21 Feb 2005
    keep it up!
    :thumb:
  10. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    Thats a good looking cube. I like how what holds the pieces together is part of the design. Very sweet. Should look really interesting when finished.
  11. Guest-6374
    Guest-6374 Guest
    Wait a minute. If the middle part is also a cube, then the part on the top isn't going to be a cube at all! It'd have to have eight sides (can't remember what to call those), not six.
  12. mr.X
    15 Mar 2005
    The topplate of that middle cube wil have a triangle cut out :dremel:
  13. ZuNe
    ZuNe What's a Dremel?
    2 Jun 2005
    Looking very good, that pic on the dark is shweeeeet :dremel:
  14. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    It seems hard to get a clean look working with acrylic and stuff that you can see trough, but damn thats nice=) good work man , keep the pics coming=)
  15. Draeth1
    Draeth1 What's a Dremel?
    5 Jan 2004
    This is looking pretty sweet. I like the squared off covers more than the bent ones, they should fit in there easier now also :)
    The abstract design of this should have it very unique by the end.
    Mod on!
  16. crazybee
    crazybee Black & Yellow
    8 Apr 2003
    VERy nice, looking forward to seeing this one completed :)
    keep up the good work :rock:
  17. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    I'm really impressed with your fastening system; normally (imo) using bolts causes a more cluttered look, but you've pulled it off very well! (the connection pieces were well worth all of that sanding) Also i like the design you came up with, very original and nice looking. Looking forward to more updates.
  18. mr.X
    15 Mar 2005
    a little extra time on my hands..
    So I made myself two holes in the middle cube.
    What would I do without my jigsaw?
    Of course the green UVLED fans:
    And a nice overall shot (the nightshot will come later :D )
    untill next update :dremel:
  19. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    *applauds* Looking better every update! Keep going!
  20. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    Orac 3 anyone? :D Love the green plexi + clear plexi, it always looks great, this is no exception! great job dude keep it up :D cant wait to see this finished :thumb:
    Retro
