Case Mod - In Progress Project Maximus Monsta
Discussion in 'Project Logs' started by fireisdangerous, 29 Apr 2013.
  1. fireisdangerous
    fireisdangerous What's a Dremel?
    2 Sep 2011
    This build came around as I wanted to get a new case and had planned on going for the new fractal design arc midi 2 but then that got delayed until the end of April which scuppered my plans. But then Alphacool released probably the best looking rad ever and I needed to own it!
    So I purchased the rad and then had the issue of finding a case that would fit it!! Enter the NZXT switch 810 matte Black edition. This project has been a bit of a slow burn as I have had all the new components since January but I have been waiting for my NZXT switch 810 to be modded. It has been with the modding company for over 2 months. But hey good things come to those who wait!
    I am having a custom back plate created without all the numerous grommet holes that the original had as I think it looks to cluttered. I wanted it to look nice and clean with only a couple of holes for cable routing. It is being made out of aluminium and will be powder coated Black .
    New vs Old :)
    New motherboad tray fitted
    Once powder coated it will look like this (pic is from another user's mod)
    They are also making me a psu cover that will run the length of the back plate but leaving me enough space to get my Monsta 240 rad with one set of fans in the front. Again this is made of aluminium and will be powder coated black.
    The final mod they are doing is making the window bigger as I hate how the default window is triangular..
    Whilst I have been waiting for my case I have managed to sell most of my old watercooling stuff from my current build and obviously purchased new parts
    Just what every build needs a massive fluffy cat!!
    Also got by psu braided by martin at cables4pc, looks preety awsome if i dont say so myself :)
    Hardware List:
    I5 2500k @4.5ghz
    Asus Maximus V Gene
    16gb ddr Corsair Low profile ram
    120gb Corsair SSD
    Corsair AX850 – custom braided
    NZXT Switch 810 Matte Black
    8 x Corsair SP quiet edition fans
    2 EVGA 570 superclocked editions with full EK waterblocks and Black plates
    Alphacool Monsta 360 rad Bhite
    Alphacool Monsta 240 rad Black
    EK supreme CPU water block
    XSPC D5 Bay res
    D5 pump with bitspower mod kit
    White delux Bitspower compression fittings
    Primichill tubing
    Mayhems blood red collant (might change)
  2. fireisdangerous
    2 Sep 2011
    Fan Grills have arrived, think they look awsome :)
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    This looks good subbed.
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking good man ;) Thanks for using E22 grills :)
  5. fireisdangerous
    2 Sep 2011
    Some more pics!
  6. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    The white rad and grill look sweeeet together, love the E22 stuff. Should be interesting to see the Gene in an 810 hope it doesn't look too empty.
  7. fireisdangerous
    2 Sep 2011
    Picked up the last of my powder coated bits, now all i need to do is tube it up. :)
  8. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    That's a really nice build. Those fittings look ace, were they powder coated?
  9. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Wow very cool and clean. And custom mobo back looks very neat :)
  10. fireisdangerous
    2 Sep 2011
    They are the bitspower deluxe white fittings.
  11. fireisdangerous
    2 Sep 2011
    I have started to tube up the build but need some feedback. I am going to use black tubing but have used some clear tubing just to test length etc.
    The aim is to keep the loop as clean as possible to match with the rest of the build. What do you guys think of the first attempt of the loop. Any suggestions are more then welcome :)
  12. Piotrek_PL
    Piotrek_PL What's a Dremel?
    29 Mar 2013
    Wouldn't it look better with tubing aligned in straight lines?
  13. fireisdangerous
    2 Sep 2011
    Changed the look a bit what do you think?
  14. fireisdangerous
    2 Sep 2011
    Thanks for all the coments on my loops much appriciated. Think I am happy with the final loop and have now used the black tubing as planned. Although it is black, it is a gloss black so will reflect the led's in the case nicley (when I put them in!). What do you think?
  15. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Much prefer the black tubing but just IMHO would have used black fittings on the white back plates- I have an all black case with all black tubing/fittings etc. and really like the minimalist look which I think you would get the contrast between your white fans/ back plates and that- I'll try and post a picture of my rig sometime but love the clean lines of this so far- Keep up T'good work
  16. fireisdangerous
    2 Sep 2011
    Final part of my modded switch arrived!
  17. The_Crapman
    5 Dec 2011
    That looks awesome. I love the white fittings with the black tubing and i think you've got the routing spot on.
  18. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    This is the bees knees dude :D I'm stealing some ideas for my next rig!!
  19. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    I like it!!
    Only points of critique: I would've liked seeing the top radiator in black also, and personally I don't think the red and black fits in, white and black braided cables would've gone with the build nicer imho.
    Super nice build none the less tho! I love those white BP connectors!
  20. The_Crapman
    5 Dec 2011
    You want yet another red and black build? boring! i love the white. It helps pick out the red even more.
