Case Mod - In Progress Project " Mazda Z"
Discussion in 'Project Logs' started by Dmitry, 19 Jun 2016.
  1. Dmitry
    Dmitry What's a Dremel?
    3 Sep 2015
    I present to you my project rework the computer case Raidmax sagitta.
    Computer case gave my father. He planned upgrades and new components were not located. I volunteered to help him, but also to change a bit the look of the computer case.
    My father is very fond of cars Mazda and I decided to stay on the car theme. The case is very suitable for work in this direction.
  2. Dmitry
    3 Sep 2015
    The process as always with the disassembly and planning.
    I apologize for the quality of the photos. I photographed on a smartphone. And I'm not an experienced photographer.
    There was a problem with the installation of a long graphics card. I put the basket drives and cut off a piece of cover to install card readers, or FDD.
  3. Dmitry
    3 Sep 2015
    Later, I began to complete disassembly of the body to be painted in black.
    I stained black paint Montana. Given the fact that this is not the body of the computer enthusiast, and will only be opened for cleaning is the best choice.
  4. Dmitry
    3 Sep 2015
    Assembling painted parts.
    The result was quite satisfactory.
  5. Dmitry
    3 Sep 2015
    Then I began to prepare the side covers and the front panel to the alteration.
    It was more difficult to find auto logo required size. I approached logo on the steering wheel.
    They became prominent features of the project.
  6. arduum
    arduum Minimodder
    10 Mar 2015
    subbed:thumb::rock:
  7. Dmitry
    3 Sep 2015
    His project, I decided to paint the liquid rubber. And then the first error occurred: before painting color rubber product, it was necessary to cover the 2 white rubber layer.
    One can see the old pattern. Exude even after 4 layers. It was necessary to remove the rubber. Rubber is very easy to clean.
  8. Dmitry
    3 Sep 2015
    I decided to paint all parts in black.
  9. Dmitry
    3 Sep 2015
    Plastic clips painted in red color.
    Pre-assembly of the front panel.
  10. Dmitry
    3 Sep 2015
    Side view.
    Check the location of components.
  11. Dmitry
    3 Sep 2015
    Installing fans, LEDs, switches. Checking illumination.
    After assembling the system lay out a finished look.
  12. Dmitry
    3 Sep 2015
    Some photos of the empty computer case.
  13. Dmitry
    3 Sep 2015
    Produced assembly system. Unfortunately the video card would not start. Apparently marriage. We'll have to replace.
    In case there is no room for cable management. I wove small braids for good ventilation.
    Hard disk drive activity LED on the front panel.
