Scratch Build – In Progress Project: MCE V.2 [Update - May 19th - Matrix Orbital mayhem!]
Discussion in 'Project Logs' started by Sleepstreamer, 20 Nov 2007.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Amazing work... What I wouldn't do for a mill of my own.
  2. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Okay guys, here comes a small update on the build.
    Thought I might sort out the electrical stuff, as it is now, nothing in the computer has any juice.
    Did the four leds for the other side of the case.
    Put them in there, and on with the molex-connectors :)
    Time to get the psu hooked-up. I wanted to use molex connectors here aswell, mostly because I want it to be removable, and also because I did'nt have anything else to choose from :hehe:
    It's pretty obvious I don't want to connect my hdd to this one, cause that would be bad.....
    Something like that....
    I don't want to use two powercords to run the system, so I took the one for the screen and cut it. Stripped off the insulation & put the wires in a molex.
    Soldered a couple of cables onto the socket for the psu, och put a connector on them.
    Yay! My stuff has arrived :) Not really cutting-edge, but it'll be good enough for a decent LAN-pc.
    Here you can see the riser I bought for this build. Seems to work perfectly. Now I just have to fix it to the bottom panel.
    My thought was to make something really-really stable. I don't want some strange short off the mobo because of crappy mounting. So I picked up my jigsaw, and a 15mm thick piece of aluminium.
    chop-chop...
    Done! That was actually much easier than expected :)
    Some threads in there aswell...
    Put a small piece of aluminium on there aswell, so the card is the correct height.
    Mounted:
    And last, a small bracket to hold the card in place.
    I'd say "tight" is the right word for it :) Looks good though.
    And after a very complicated afternoon I got everything in place, and installed windows.
    It's Alive :D:D
    This is more of a sneak-peek due to the low lighting in the room, but you can clearly see it's working :)
    That's it for now. :) Stay tuned.
  3. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    sorry, i just need to pick my jaw up off the desk.
    That is extremely nice, id be seriously proud if id made that.
    Keep the updates coming :)
  4. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    Thats Friggin amazing work. Beautifully Done.
  5. Cheapskate
    13 May 2007
    Niiiiiice! I didn't expect you to put a giant video card in there too.
  6. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    very nice !
    Is the video cable going to be visible at the bottom of the case ?
  7. Sleepstreamer
    23 Jul 2006
    No not really, you can see the DVI-VGA adapter if you look close enough, but the cable is tucked away behind the alu-panel, and then working it's way behind the screen (across the mobo on the back).
  8. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Looking great as always!! =)
  9. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
  10. FragileSocks
    FragileSocks What's a Dremel?
    25 Nov 2007
    Its most refreshing to see such a practical Mod, made with great elegance.
  11. b4i7
    b4i7 modding dreams into reality
    7 Apr 2007
    i truly love this mod, youve really inspired me to build something similar
    one question, how big is this thing?
  12. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    this has become more than a simple HTPC, i reckon you'll start using it as a main computer soon, well depending on spec's of your current daily drive..
  13. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Woah man this is one beast of a computer. don,t know how i missed it seeing im on this site everyday.
  14. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Man that's amazing workmanship. I love the riser solution. It looks so clean!
  15. ThatGingerGuy
    ThatGingerGuy † Bogan Red Neck †
    28 Mar 2008
    Dude ... WOW that all i can say looking very good Very clean
  16. Macros_the_Black
    7 Jul 2007
    Btw, is that a small piece of plastic I spot between the mesh and the right heat sink in the PSU (in the last pic of the PSU)? If so, thumbs up! =) Is there such a spacer on the left one as well?
  17. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    What do you feed that thing? kittens?
  18. E.E.L. Ambiense
    26 Jul 2007
    LOL. Hahahhaa. I wouldn't doubt it either.
  19. Sleepstreamer
    23 Jul 2006
    I'm honored to hear that :)
    Hmm, well it's really the size of a standard 19" Wide LCD-monitor (+ hardware on the back). I'll try to get a decent pic comparing it to something... tomorrow :)
    Well maybe not as my main system, but definately as a LAN-pc as my P190 is not something I want to carry around :hehe:
    Thank you :) I'm pretty satisfied with it aswell :)
    Yup that's right, there's acually two of those on each heatsink. It's not really pieces of plastic though, more like a very thick double-stick tape.
    It actually prefers baby Turtles over kittens, but then turtles are harder to find ;)
    Thanks for all your comments! :)
  20. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice work. That riser solution is indeed cool! :)
