Project Metaversa: LCD goodness (small update 17/07/05)
Discussion in 'Project Logs' started by Nexxo, 11 Apr 2003.
  1. Arkangyl
    Arkangyl What's a Dremel?
    16 Dec 2003
    Thanks Nexxo
    keep up the great work
  2. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    Well.. I have been lurking in the shadows following this thread for a while now. I decided that I must come out and say that you have been doing an excellent job on this case. Keeping form and function woven together in a very nice pattern. :thumb: Keep up the great work!
  3. auspex
    auspex What's a Dremel?
    27 Oct 2003
    bump :lol: nexxoooo
  4. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    ::Cough:: ::Cough:: :naughty:
  5. Nexxo
    23 Oct 2001
    OK, OK! I know I've been negligent... what can I say? Christmas family obligations really slow you down. :blah:
    I have been working on the thing though, just haven't had time to post pics. I wanted some bits to be complete first. But I'll show you what I got so far tomorrow. If you're interested, that is. :D
  6. Darv
    Darv Bling!!
    12 Aug 2002
    Ohh please :baby:
    Been following this project since the beginning and its great :clap:
    Gave me the inspiration to go for water cooling.
  7. The_Sub
    16 Nov 2003
    count me in as "interested" :D
  8. STellY
    STellY What's a Dremel?
    24 Aug 2003
    same.... :D
  9. at_b
    at_b What's a Dremel?
    28 Mar 2003
    ditto ......
  10. Nexxo
    23 Oct 2001
    OK, I finally uploaded some pics. Sorry for the delay, but as I said, Christmas family stuff does slow things down. Moreover, in the Health Service, we tend to work over the Christmas period; no holiday for me... :(
    But given the interest, I'll show you what I got so far. :dremel:
    First, I braided the PSU. Red cables go to the Mobo (which is red, geddit?) and the rest is white. I was originally thinking chrome/silver braiding, but I feel it just doesn't look right... a bit tacky, like Christmas tree decoration.
    I also started drilling more holes in the front of my case...
    ...and changed the power button screws for countersunk ones, to increase the flat area surrounding the button. Why all this? Here's why: a Shuttle PN21 USB module:
    Which is mounted hidden behind the (plastic) front bezel of the PC (and it has to be plastic, otherwise the signal doesn't get through!).
    You'll notice some holes below the module as well: this is where the Antec Truecontrol PCB goes, which is shown dismantled below:
    I would show you it mounted, but as I said, I haven't quite had the time. :(
    As you can see below, I added more shiny chrome seperators to the main inlet tube. This will lead the 4-pin 12V Mobo cable, and the molex cable supplying the Radeon 9800 and the Firewire PCI card. It also gives it some structural rigidity to the inlet tube to prevent it from folding under the underpressure.
    Finally, I bought some of these:
    They are flexible plastic D-bus protective caps. You can get them for 9-pin (serial or VGA) 15-pin (Midi) or 25-pin (Parallel) ports, both male and female. A pack of five costs £2,-- tops. As I do not intend to use more than one serial port, and not use the VGA port (going with DVI instead) they will serve to protect the ports which are not in use:
    Serial:
    VGA:
    ... also handy to protect your laptop ports when in transit :D :
    So, that's what I've been doing over Christmas. That's not all, though. I found a chrome billet 3-hole seperator for the three rounded IDE cables (yeah, yeah, I'll post a picture soon). I am also slicing an extra line into the PSU for an always-on 5V supply (again braided). I'm doing the pump control electronics. And I got a bottle of Zerex Racing coolant additive, but I thought that didn't make as exciting a photo. :p
    Sorry for the wait, people...
  11. Darv
    Darv Bling!!
    12 Aug 2002
    Nice work :clap:
    Did you vinyl dye the PSU connectors or did they come like that. And those port covers are a damn good idea.
  12. Fyberwire
    Fyberwire What's a Dremel?
    14 Sep 2003
    Awesome work!
    I would've never thought of using hose seperators as wire managers. Also, cool find with those rubber stoppers for the ports. I'm sure those will come in handy. And great work overall. I assume you'll be able to have bluetooth and PSU voltages front mounted on your case, so It'll be interesting to see how you do that. Great work m8, looking forward to more great things with this case!
  13. bsodmike
    bsodmike Banned
    11 Oct 2002
    Damn Nexxo, I hope you don't go keeping ALL your PCBs on the carpet!
    Looking nice, them covers :D
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    Does that just plug into a normal USB header on the mobo?
  15. Nexxo
    23 Oct 2001
    @ Darv: all connectors of the Antec Truecontrol series come in black as standard! :clap:
    @ Atomic: yup, it's a Bluetooth module that plugs in an ordinary mobo USB header (USB 2.0 or 1.0, although the latter suffices bandwidth-wise). Actually the module comes with a double USB header cable, which plugs into that teensy-weensy PCB you see in the picture, in which you plug the module. Which means that you can plug something else in besides --if you can find out what type the odd small white connector is. In my case the card reader will be plugged in there also.
    @bsodmike: only those PCBs that don't have sensitive electronics on them! :D
  16. Dragosoft
    Dragosoft What's a Dremel?
    29 Aug 2003
    Ah, Your project loking good...
    nice protective caps.. i have allmost same looking.. mine is chromed :D
  17. Altron
    Altron Minimodder
    12 Dec 2002
    The third red plug (not the 12v aux or the atx) is that the AT power connector/ If so, why are you keeping it around?
  18. The_Sub
    16 Nov 2003
    I would assume that is a regular molex for the radeon card.. mo power!! for the gfx... at least that is what it looks like
  19. Altron
    Altron Minimodder
    12 Dec 2002
    Could very well be, there is only a side view and it is hard to distinguiish the number of conductors.
  20. Nexxo
    23 Oct 2001
    The 6-pin connector is the AUX connector. Don't need it here, but I like to keep my options open (upgrade wise). Meanwhile another snag has hit:
    Bugger, bugger, bugger!!! :miffed: :duh:
