Project Metaversa: LCD goodness (small update 17/07/05)
Discussion in 'Project Logs' started by Nexxo, 11 Apr 2003.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Sure, what color do you want them in? I have access to a wide variety of scrap plastic.
    Can you measure the outer diameter of your IDE cables? Mine are a little under 1/2"
    I'd love to make some out of aluminum but I don't have a source for scrap and they would be quite a bit harder to make with the tools I have.
  2. Nexxo
    23 Oct 2001
    My IDE cables are the same as yours in the picture, so no worries. They measure 11mm in diameter. I'm happy to have the spacers in black, thanks! :thumb:
  3. zerocom
    zerocom What's a Dremel?
    13 Jan 2005
    Very very and a lot of more very's. This case is just superb. Clean fisish all around. Perfect just about concludes it :thumb:
  4. Wrigley1
    Wrigley1 What's a Dremel?
    5 Dec 2004
    I subscribed, and even though it seems like it's taking forever, it is an amazing mod, so I will watch it and derive ideas. :) mod on!
  5. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    damn nexxo this is one of the mods where i say " why do i mod? i never get something that good looking " anyway keep us updated. i really wanne see where this one goes. its so slick and shiny. me.... want... watercooling!!!!!
    u rock big time :rock: :rock: :rock:
  6. Tricky
    Tricky What's a Dremel?
    29 Jan 2005
    Hail the conquering hero: (Aladin style trumpet fanfare - Nexxo walks towards his throne, Pete decides on less coffee next time).
    Just wanted to thank the site collectively, and this thread in particular for providing such a good resource for the new modder / electrically inept (that would be me).
    I'll be having a bash at some of this modding stuff myself now then. Hopefully I won't be accused of vandalism when I post the results for Nexxo et al to cast their beady eyes over!
    Cheers - Pete
  7. Nexxo
    23 Oct 2001
    Welcome to the forums Tricky! :rock: Go forth and mod, and be sure to post pics of your project!
  8. Langer
    Langer Jesse Lang
    24 Jan 2004
    Shouldn't you be working on something Nexxo?
  9. Nexxo
    23 Oct 2001
    Who says I'm not? :naughty:
  10. Tanaban
    Tanaban What's a Dremel?
    6 Aug 2002
    Us, because you're not posting pictures :grr:
    PICTURES I SAY! If we don't know about it, then it doesn't exist, right? :p
  11. G69T
    G69T CNC Modder
    6 Jun 2004
    Nice work! :thumb:
    I love your water blocks... :D
  12. Nexxo
    23 Oct 2001
    Why thank you. :D
    Small (but significant) update: Metaversa is up and running! Booted up not long ago and CPU temps are stable at 40C and 39C respectively. Together with an ATi 9800 Pro, all on a single BIX, ladies and gentlemen! The radiator doesn't even feel luke-warm. :D Which is nice.
  13. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    is it oc'd?
  14. Noldor
    Noldor What's a Dremel?
    10 Aug 2003
    Most impressive! Probably due to your rediculously efficient loop ;)
  15. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    while your project is amazing nexxo, the sad part is that it's sort of fallen behind the times. When you first started it with the kickass CPUs and videocard, it was amazing, yet as time progressed, components aged, and that 9800 Pro just looks inadequate now... lol.
  16. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Well that just proves it, the BIX will most likely cope with an SLi setup. Are you still going to change the radiator for a BIX2? Any pictures of the system up and running? :D
  17. Nexxo
    23 Oct 2001
    I wouldn't call a dual Opteron 250 "behind the times"... :eyebrow: :p
    But you are right that the GPU isn't cutting-edge anymore. No matter, I can simply upgrade it for an X800. ;) Anything beyond that is simply overkill.
    Nope, I don't think I'll drop in a BIX2; there is simply no need and I don't think it justifies the added expense and surgery... I'm drawing a line under it here. I will now concentrate on finishing the details and the external cosmetics of the case.
    Pics will follow as soon as I have tidied up the wiring a bit.
  18. Tulatin
    16 Oct 2003
    A Simple X800? Nexxo, you've got Twin opertons in there. You need at least an XT. I can see where a PE would be a little over the top :D
  19. Nexxo
    23 Oct 2001
    I meant an X800 PE. Is there anything else? :D
  20. Tulatin
    16 Oct 2003
    Well there's an X850 XTPE
    orrr you could get one of those tyan boards and 2x6800U
