Project Metaversa: LCD goodness (small update 17/07/05)
Discussion in 'Project Logs' started by Nexxo, 11 Apr 2003.
  1. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    Thats pretty cool, it's something I've been working on (when I have the time and cash) for a while now since I do HTPC stuff I wanted something like Koolance's EXOS for it but you know something that actually matches the rest of the A/V gear. Although I'm doing a custom case rather then retro fitting an existing one but it did occure to me to do that, just too much extre work IMO.
  2. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    the case looks verry nice
  3. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    Nice lookin mod! Keep it up!
  4. scooby
    scooby Minimodder
    3 Mar 2004
    Hey Nexxo, I have been reading through your work log and I must say (just like everyone else) SUPER JOB BRO!!!! Your attention to detail and your patients has really paid off. I too try to follow the clean streamline elegance toward my modding, and you my friend do it so well.
    I am soon going to go water-cooling for the first time and have a few questions for ya. I notice a few posts back that you said you where using ½” barbs on most of your setup and that you are using 3/8” tubing am I correct on that? I am planning on using ½” setup myself and would like to get your input on those nice hose clamps from Pi-thon. What would be your recommendation on that, like hose size and clamp size with using ½” barbs?
    TY, Keep us all posted and never stop modding :thumb:
    Scooby :cooldude:
  5. BIOHAZART.RU
    BIOHAZART.RU What's a Dremel?
    6 Jun 2005
  6. Nexxo
    23 Oct 2001
    The Pi-Thon website has a diagram with all the relevant dimensions to help you select the right clamp. If you want to slip your tubing over a 1/2" barb (irrespective of whether the tube is 1/2" ID or 3/8" ID), you want a Hoselock 1A-08.
  7. spookyman60
    spookyman60 What's a Dremel?
    4 Jan 2004
  8. scooby
    scooby Minimodder
    3 Mar 2004
    Thanks Nexxo, So it would not matter if I use a 1/2" or 3/8" tubing the 1A-08 Hoselock will fit? Just want to make sure since you have experience with it because I don't. :confused:
    TY :D
  9. Nexxo
    23 Oct 2001
    That's right. The "hose ID diameter" in this case really refers to the barb OD (rather confusingly). As long as the OD of the tubing as measured when stuck over the barb does not exceed 0.830" (21 mm), you can use this clamp.
  10. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Blast! There I was, thinking there had been an update :)
    Hahahaha!! I know Nexxo is a psychologist, but I don't recall any mention of his patients, but perhaps scooby has insider knowledge :D
    just kidding.
  11. koola
    koola Minimodder
    11 Jul 2004
    lol - I thought the same thing!
    So Nexxo, is there going to be an update any time soon?
    You know you need to! :D
  12. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    I thaught he was done.
  13. Nexxo
    23 Oct 2001
    Not nearly --there is still some cosmetic work to be done on the side panels, and a permanent installment of a MO LCD. However money and time have been a bit tight, and I had some trouble sourcing a lasercutter etc. so things are on hold for a while.
  14. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    Nice work
  15. Nexxo
    23 Oct 2001
    Small update:
    During my holiday this week I have had some time to tinker again. You will remember that I put a 5" colour LCD screen in the bezel.
    People frequently muse what software they can use to meaningfully display useful info in a pretty manner. I find that Samurize is just the ticket. Usefully it recognises secondary screens and allows you to display pretty much whatever you want, in whatever way you want.
    Below is my current config:
    I will probably tinker a bit more. You can also display HHD activity/space, Winamp stuff (inc. Spectrum and CD covers), voltages, temps, whatever. It comes with Speedfan and MBM plugins. Samurize can perform mathematical operations on the data it displays; note how it registers the SF800 flowsensor (connected to a mobo fan header) via Speedfan, and handily converts its RPM values into l/min. flow. Which is nice. :D
    (EDIT: took better pictures)
  16. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    umm...somone just made me regret selling my last 2 PSOne screens... :(
  17. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    i've got 2 if you want em kaotic
  18. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    how much? im lookin for one
  19. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    Ok ok ok, i have enough, just a few pages too much too take in. Man... this mod is wicked. You have read this already by other users, but i guess every praise, makes you feel better. So feel good, and go go go.... stop reading and carry on modding.
    P.S how much have you roughy spend? I read somewhere that somebody else was being nosy. So i guess if you think i am, am sorry, and you dont have to say.
    Good luck :)
  20. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    It's alive...it's ALIIIIIIIVVEEE!!!
    /me falls over
    Nice job, Nexxo. I like how that screen turned out. I've been meaning to get into samurize, but I'm just so damn lazy.. ;)
