Case Mod - In Progress Project Meticulous - Dual Loop Thermaltake Tower 900 Build
Discussion in 'Project Logs' started by faheemrazzaq, 1 Aug 2018.
  1. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    I am going to start a new build. Always wanted to build into one of these massive cases and now is the time. Here is the link to the case. Obviously it will be a watercooled hardline build with dual loops.
    Hardware List:
    Case: The Tower 900 Snow Edition E-ATX Vertical Super Tower Chassis by Thermaltake
    CPU: Intel® Core™ i7-5960X
    RAM: 32GB Corsair Vengeance 2666MHz DDR4 (4x8gb)
    Motherboard: ASUS X99-A II
    GPU: Nvidia GeForce GTX 1080Ti
    PSU: SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply
    Cabling: Sleeved cables to match the build theme.
    Storage: A combination of SSD's and HDD's
    Watercooling loop:
    Coolant: Mayhems Ultra Pure H2O with dyes+biocide to match the theme build
    CPU Cooler: EK Water Blocks EK-Supremacy EVO
    EK 1080Ti full cover GPU Block
    Reservoir: Custom build
    14/10mm Acrylic Tubing
    560mm Hardware Labs Black ICE Radiator SR1 560
    360mm Hardware Labs Black ICE Radiator GTX 360
  2. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Reserved
  3. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Reserved
  4. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    I have the case now but instead of doing photos myself, this animation from Thermaltake will be more useful in demonstrating the capabilities of this case. Gigantic case really.
  5. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Cables sleeved. Here are some pictures. :)
  6. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    The reservoirs are finished. Made out of 5mm clear acrylic. Dimensions are 41cm x 5cm x 5cm. Liquid capacity 0.7L.
    Used the right size drill bit and tap to make G1/4 fitting ports.
  7. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Active Member
    14 Sep 2004
    Old skoool res making i love it :D
  8. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Thanks mate. I wanted to use a really tall res and there aren’t many options for such dimensions. Inspired me to come up with these. They should compliment this case nicely.
  9. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    This is the basic layout of the build. I have taken out a lot of stuff from the case to make space for a custom base. Working with acrylic sheets to build everything now.
  10. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    GPU Back Plate is ready; fitted with RGB strip.
  11. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Installed some castors. Very convenient to move it around now.
  12. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Some more progress. Taking some shape now.
  13. _Prometheus_
    _Prometheus_ Active Member
    2 Jul 2017
    Not the really good idea to put such vacuum cleaner on a floor. I think so...
  14. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Valid but I have no fans at the bottom (Other than PSU, which is mostly off). And I may actually put it on a table. But for meanwhile it is easier for me to work like that. Cheers
  15. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    The transparent screen is ready with backlight Leds installed showcasing the Project and Thermaltake logo. Still some tidying up required.
  16. faheemrazzaq
    faheemrazzaq Member
    26 Sep 2015
    Loop done. Almost ready to go.
