Its basicaly a case made out of one of those old skool milk man crates. I have started cutting it up a liltle already but i have taken some pics and as soon as i find a place to host them il put em on here.
pic1 pic2 pic3 I know the pics are pretty bad quality but as the project continues il get some better ones..... if you got any complaints of the ***** pics send me a camera
I went away for spring break but i just continued working on the project and have gotten the basic frame cut out.......my next step is to get the cd drive flip down plate attached to the case using the hardware from an old broken cd-rom Its lookin a bit less ghetto now too
i dont know, sometimes the ghetto factor comes out looking way cool. Anyone recall the expanding foam case?
can somebody tell me what kind of glue would give me a good strong bond when gluing plastic to plastic and to plexi/ lexan
i just finished gluing my plexicase.. i used this super attack, dunno, so far it seems great.. no problems..
does anyone know of a place to buy glass frosting...preferably in Canada????? i cant find it anywhere
WHOA With a couple more cuts i found out that a normal atx mobo will fit nicely while before it was about 2cm to small. All together there will be ATX mobo (hopefully with sound and lan on board) video card chopped down PSU full size cd rom one hdd lcd or vdf 1 or 2 cc's The only downside is that i have to wait until i find a new job to buy it all because im just not getting the hours i need. New pics tomorow hopefully
this mornin i woke up and got off my bed put my feet down and CRACk i step on project milk man......both sides cracked rite down the middle so my log is over
well at least now u know milk man wont be strong enough to hold a computer.... otherwise u will crack milkman when ur mobo is in it....lol
