Project: Miranda (changed!!)
Discussion in 'Project Logs' started by Razor_cut, 15 Feb 2005.
  1. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Miranda
    *****Update*****
    Trying the new motherboard
    and memmory..
    Polished pump in
    the wait for chroming.
    Handels and polished
    HDD blocks.
    xx/08/2005
    Ehh.. plans gone away, replaning and
    going for dual watercooling loopsystem.
    The plan​
    • Lian Li PC-2000B
    • Asetek Lightspeed compressor, where you should mount your HDD:s.
    • Watercoold GPU by Silverprop:s Cyclone Fusion HL,
      Watercoold HDD blocks made by hj07,
      Criticool Reservoir,
      Chromed Black Ice Extreme radiator,
      Ehime 1048 in Aquacomputers FMJ cover
    • The powersuply, a OCZ 520W will be mounted on some way, new box is possible but not sure where in the box..
    • Chromed components, the budget decide how meny ;)
    [​IMG] [​IMG] [​IMG]
    All pictures are taken with a Nikon Coolpix 3100 and mith Macro option always in :thumb:
    Pleas tell if you what some spesific photos..
  2. Firehed
    15 Feb 2004
    Oooh, same case I've got. I'll be watching this one :)
  3. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    why did you replace the caps??
    Good luck with that mod :thumb:
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Sweet, good luck ;)
  5. Razor_cut
    12 Mar 2004
    To get more stability.. But I cant tell if ti did any or what so ever difference..
    The more extreme the better :D
  6. planki
    planki ...
    20 Dec 2003
    good luck with trying to get that cooling unit in there, will be awesome if you can but i can imagine its gonna be heavy afterwards!
  7. Razor_cut
    12 Mar 2004
    Well I plan to use some steel beneth the compressor and betweene the alu.. Maby panit it black :clap: and screw it to look nice. Well see. But the alu alone whont make the compressor alone for sure..
  8. ModKid
    ModKid What's a Dremel?
    5 Jul 2002
    it would look nice :) good luck,
  9. Razor_cut
    12 Mar 2004
    Picked these beauties this morning :thumb:
    Cant say Iv seen any better looking H2O HDD blocks.. Or what do you say.
    They are entierly made out of copper, and waights around 4kilos :eeek:
    They will fit in beneth the DVD rom.
    Edit:
  10. MegadetHCl
    MegadetHCl What's a Dremel?
    8 May 2004
    Those are very sweet HD blocks. Never really saw them before being commercially available. Mind telling us where did you pick them up from?
  11. planki
    planki ...
    20 Dec 2003
    i dont see the benefit of those hdd blocks as in my experience most of the heat in a hard drive is in the top and bottom and by having 3 hard drives stacked on top of each other is only going to increase the heat and reduce your waterflow round your watercooling circuit?
  12. Razor_cut
    12 Mar 2004
    Well its a enginer i Sweden who makes them.. But if you are nice maby he would make some for ya... Try this webbpage = http://hj07.dyndns.org/ its in swedish but have a try :thumb:
    Well the harddrives are constructed to lead the heat to the sides. And with the blocks you will be able to chill them better than air and reduce the sound, by putting som soundresistant material around them or so..
  13. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    This should be good if you can pull it off...which you can. Good luck, and keep us posted. I'd like to see this when it's done.
  14. Razor_cut
    12 Mar 2004
  15. lrghobo
    lrghobo What's a Dremel?
    18 Feb 2005
    Sounds like a great idea. Let me know how it works out with the lightspeed. I have done the same thing with a promie and its a really tight fit plus the evap block isnt round so mounting it was a lot harder with the mb upside down and all. Also you may want to reinforce the bottom area where the hds go as when you take out the rails for them it becomes rather weak. It sagged in the middle quite a bit on mine until i reinforced it a bit.
  16. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    I was going to do this very project.
    Subscribed.
  17. M1ndZtorm
    M1ndZtorm What's a Dremel?
    8 Feb 2005
    Hey, this is exactly what I'm working on at the moment. I thought I had a mod no one else would do for a while, well :wallbash:
    I'm going to follow your work closely to see if I can learn any thing that might come to use in my project.
    Keep up the good work! :rock:
    Regards,
    Karl
  18. Razor_cut
    12 Mar 2004
    Yeah thats a trouth, well some kind of a steal length would do the jobb I think to stabalise the case.. Thanks for the reminder :)
    Well its really nothing speciall with the idea.. So I understand menny are palning on the idea..
    So stay tuned, Im currently waiting for some aqua products, and by the middle of nex weak, the compressor should be inside the case :dremel:
    Offcourse Im hooping for a sooner proces but, wile Im studying I really cant focus on the modding :grr:
    See ya
  19. M1ndZtorm
    8 Feb 2005
    The funny thing is I'm from sweden as well :hip:
    My project will be based on the 2100B case, VapoChill LS and AquaComputer bit's 'n pieces....
    I guess it wasn't that imaginative, but hey! I'm after the performance not the bling.
    Well, well, where did you get the VapoChill and the Lian-Li? On-line or from a swedish retailer?
    I'd like to see some detailed shots of your compressor install. Was it a tight fit or is there plenty of room? My initial idea was to squeze the VapoChill in to the Lian-Li V1100 case, I'm fairly good with the :dremel: ....
    How do you plan to manage the heat from the compressor? Any additional fans or blow holes?
    That swedish HDD block is pure art :jawdrop: jummy...
    Kind regards,
    Karl
  20. stu_69
    stu_69 What's a Dremel?
    11 Mar 2004
    this is a good mod. I like the HD coolers - I hope they work.
