Project: Miranda (changed!!)
Discussion in 'Project Logs' started by Razor_cut, 15 Feb 2005.
  1. Liquid Steele
    Liquid Steele What's a Dremel?
    11 Apr 2005
    I am sure you already know this but the term is BLING BLING
    Where did you get those handles??
  2. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    do these hard drive coolers actually work? cuz all my hard drives have a far from flat side. Do u have to lap the sides of ur HD too? :p
  3. quantum-modder
    quantum-modder What's a Dremel?
    4 Aug 2005
    wow 3 hdd wanna buy me some jp :)
  4. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    From local marine store. Ask for "ring handle".
    And thanks, gave me a laught. Projekt will be pritty blink bling
    Havent tested them yet, so I will come back with that.
    problem is economy, I will wait with the graphiccard and go for 3 harddrives for now, since one must be a raptor it will tighten the life.
  5. Razor_cut
    12 Mar 2004
    Anyone know where I can find black tygon, or likewise tubing, in 1/2" ?
    With tygon thickness It would look great, but hard to find..
  6. Totenkopf
    Totenkopf What's a Dremel?
    1 Aug 2005
  7. Razor_cut
    12 Mar 2004
    "The page cannot be displayed"
    But thanks anyway..
    Forget that. It works goodie.
    Thanks!!
    Edit.
    Got some tubing orderd. Feels good, to get somehing you really looked after to get. I also got some black tee fittings :thumb:
    And finaly AQ will send this little order :)
    Next up, Building something to hold thous 8kg heavy water HDD blocks..
