Project : Mod in alu @ 17% /PAUSE\
Discussion in 'Project Logs' started by b!p, 30 Jul 2004.
  1. b!p
    b!p New Member
    6 Jul 2004
    Hi,
    When I saw the Blackmesa I wanted to make my case like it. But today I prefer to start more simple than this case. It's my first mod, so my objectives are simple. I want to do a clean case (if it possible :D ) and I want to find it cool.
    First the electronic part, I never brazed something, and my material is not, how to say ... Look at the photos ;) I wanted to do a little case in aluminium, with 5 swiches for the 5V-12V.
    My case ;)
    Ok let's cut and braze !
    My IDE cabel, nobody in France like it :waah:
    My workplace :
    It's finished !
    Ok today I made box to range my cables, it's inspired by piloux, I started with this :
    I put tho cabels because it will be Molex cables in the box.
    After a paint (with Boltgun Metal ;) and black Ink) :
    Equally for my fan :
    That's all for today, what do you think about it ?
    Sorry for my english, it sucks ...
  2. hmekk
    hmekk New Member
    17 Jul 2004
    quite good start ! :naughty:
  3. invader crack
    invader crack New Member
    18 Jul 2004
    what this bad ass case look like? :D
    i like ur switch bay a lil different then the norm, cant go wrong with that
  4. drinn
    drinn New Member
    16 Jul 2004
    Wow :D That Coca-Cola box is sweet :clap:
  5. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? New Member
    13 Jun 2004
    ha ha ha thats sweet dude, now all you have to do is show us the case!!!, keep up the good work (nad don't ever think you are stealing a idea is someone else came up with it, just give them credit and wala!!!)
  6. Romirez
    Romirez New Member
    31 Jul 2004
    Looks good... the cola can is sweet :thumb:
  7. b!p
    b!p New Member
    6 Jul 2004
    Ok, for today I have cutted my ancient radiator for my graphic card (waiting for hl² ;)). It's in aluminium, to cut it I use a hacksaw. I paint the 8 blocks with undercoat (Games Wokrshop :D), because it reacts with my UV neon (photo tonight ;)). The based are polished with P600.
    We don't see the white paint, it's my camera :(
    The base polished
    Well, I take two photos but the result is bad, my camera doesn't want to see, it's bad, look at this :
    No reaction ? :waah:
  8. -EVRE-
    -EVRE- New Member
    12 May 2004
    Darn!
    although wouldnt the paint keep it from passing heat as well?
  9. Nightingale_zero
    Nightingale_zero New Member
    30 Dec 2003
    I am sure the paint will have a slight effect but nothing major. As long as the coat of paint is one thin coat there should be no adverse effects.
  10. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    i wanna see the case,
    there should be no heat transfer problems as long as he dint paint the bottom cantact area which it apears he may have done :eyebrow: but those heat sinks look lovely
  11. b!p
    b!p New Member
    6 Jul 2004
    I think too, there isn't a lot of paint on the blocks, and only on the exterior faces, so it's cool. But I don't like the UV effect, I will paint the blocks with fluo, orange, yellow or green I don't know.
  12. Mixx
    Mixx New Member
    19 Oct 2003
    LOL @ the IDE cable. lollll. uhh you might not want to use that soldering iron because i have a similar one and i tihnk it was too powerful so i ended up frying my mouse while trying to put a blue LED in it. but that was prolly just my fault loll
  13. b!p
    b!p New Member
    6 Jul 2004
    Okay ! But I don't want to put led's in my mouse, and I haven't an another iron :(
  14. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    ya i have an iron like that and i was trying to change out a light in my original NES and i fried it, so be careful please, hate to see good hard ware destroyed
  15. b!p
    b!p New Member
    6 Jul 2004
    Well, i've made a test with my green stabilos, but I have a problem :
    In the dark it looks good :
    But under light ... :waah:
    How can I enhance this effect ?
  16. toyomatt84
    toyomatt84 New Member
    1 Jun 2004
    Is that paint you're using to create the glow primered before it's applied? You'll find that priming whatever you're going to paint, will adhere the paint much better.
  17. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    As he said, he did this using a stabilo. As far as I know it's a pen with UV active ink (stabilo boss). My guess is you should have used real UV active paint for this. The pens really come in handy for doing the lines on your motherboard, graphics card, etcetera. :)
  18. b!p
    b!p New Member
    6 Jul 2004
    Okay for today, modding my pomp and an electrolyse for my radiator
    Just a little pic, it's my computer before :
    Without the electronic part :
    The machine to made the electrolyse, it's very old but it fonctions, good :thumb: :thumb: [​IMG]
    In the watter ;) :
    Berrrrrrrk :rolleyes:
    It's clean now, that's good :rock:
    It's in aluminium :
    I protect and I cut :
    Theory and pratic ! yeah !
    I cut now the plexiglass
    It's finished ! Reacts ?
  19. boubou
    boubou New Member
    31 Jul 2004
    nice one for pumpen and the other one :clap:
    french ( and belge ) powa !
  20. MrBurritoMan
    MrBurritoMan New Member
    27 Jun 2004
    the |x| of DEATH!
    well at least for me
