Scratch Build – In Progress [Project Mod] "SOUL TREE AVATAR"
Discussion in 'Project Logs' started by DEFCON Emy, 19 Nov 2010.
  1. DEFCON Emy
    DEFCON Emy The Emy Charger
    16 Nov 2007
    Good day boys, siccome today they are to house are put to play designing to me on the ideas for my next one mod ...... and from my fantasy this sketch has exited ........
    Now watched the details also because in design I'm not Giotto, but is not what I have for the time being overhead for being able to realize this work. The branches as in the film they will be alternated with branches and cables in illuminated fiber optic, the spirit of the tree will be made with of the iron thread covered with plastic model in order simulating the log and the corteccia, in the roots s' the illuminated fiber optics like the film . In the below part there will be obviously all hardware, than will be looked at through of big windows, that I still do not have in mind like making, the bathtub will be large with inside that small (as it is looked at from the sketch visualized in green), made it specifies and identical like in the BioLab with inside a model of Avatar….Other things will come to me later on in mind of this Modding…. Syntonized remained thanks and will be looked at some of the beautiful ones!
  2. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    Could be very interesting :)
  3. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Wow. took me a while to read that. but yeah, will be interesting. I really want to see the optic fiber stuff.
  4. DEFCON Emy
    16 Nov 2007
    Here as the tree will have to come ..... and it will be enormous because it will have to contain besides optics fiber, cables USB and part of hardware .......
    Bye bye.....
  5. Razer2007
    18 Jul 2010
    hardware in the tree? does it grow on there? you should use "core i7" and "GTX580" seeds for it.
  6. Mattmc91
    Mattmc91 Well-Known Member
    18 Oct 2009
    Ghetto Paint Mod.
  7. DEFCON Emy
    16 Nov 2007
    I task to put a small part of the hardware (maybe the hd) and output USB will be put in the cavities of the log ......
  8. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    It's a very very big tree if you plan to put an hd (2,5 I hope) inside :D
    How do you plan to light the fibre optics?
    Because usually only the endind point light up.
    ciauz
  9. jhanlon303
    7 Sep 2006
  10. DEFCON Emy
    16 Nov 2007
  11. DEFCON Emy
    16 Nov 2007
    Hello finally acquired the optics fiber here that made part of a lamp led of Ikea suggested to me from Weisses….and task that alternating them one to the others would have to be also of the just length ......
    now me it does not remain that to take of the green stuff or bicomponent plastilina, iron thread and resin and to begin to model of my tree ...... at this point we are waited for still a little .......goodbye!!
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    This will be interesting.
  13. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    I've only ever worked with fiber optic cables once, and it was an endglow cable (as I imagine these are also) and the one tip I think you might want to hear is that if you have to alter the cables lengths, use a hot-knife to cut the cables. If the ends are not flush or have a jagged cut it drastically reduces the brightness of the cable.
    I found that using a hot knife and then sanding the end of the cable worked well (I think I used 1300 grit sandpaper?).
    Cool idea though, can't wait to see progress!
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome, after viewing your outstandingly awesome LOTR mod I am very much subscribing to this :jawdrop::thumb:. I guess it will take a long time to make but am very keen to follow this one from the start :thumb:.
  15. DEFCON Emy
    16 Nov 2007
    Hello excused the waits, but I must at least have in mind like realizing the case
    Obviously opportunely it will be modified, instead that to be two separate modules they will be united in order to contain total hardware with one of the two containers for the liquid ....... this will be inside of the case ......
    The other largest one will be in the below part of tree and will simulate the unoptanium ........
    And then the tree will be inserted in a plastic much realistic one of Pandora, where the module-case will rest you ....... I have already all in my head I hope to realize it ....... Been syntonized monday it is begun ........
  16. nagyizom
    nagyizom Member
    2 Jun 2008
    Interesting ideas!
  17. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Fantastic idea Defcon, done right this should look stunning!
  18. DEFCON Emy
    16 Nov 2007
    Finally part! Today afternoon I have made a turn to the Briko ...... and here my purchases
    After to have centered the plywood for the measure that serves to me that is 40x40cm I trace the circumference of the base of tree with the hole to the center for the passage of cables for the led, output usb, headphone and microphone ....... Remembered that under to this base the container-tube of the liquid green-blue that it will simulate the unoptanium and will have the same dimensions of the plywood with un' height of approximately 20cm .......
    Now cut with the Dremel .....
    Detail of the used tip in order to make the circle the center ...... watched some imperfections has not made all of haste also because then all it will completely be covered of clay, therefore does not import to have a perfect circle….
    Here roughly where will come put the greater roots (those numbered) and the secondary roots........
    Remained comfortable tomorrow with others up ......
  19. DEFCON Emy
    16 Nov 2007
    New up ....... here as it is proceeded: for first thing I have given a layer of assembling in order to make to attack the clay to the wood, later on I have given the form of the root and have made a kind of dam for being able to put the initially liquid resin as. I have coiled two you spin of iron in order to make the structure of the tree (in all will be 12), I have supported the thread inside of the two clay cords and I have poured the resin so that then after hardening I will have a very solid base in order then to make the log of tree ........
    The continuous adventure remained syntonized goodbye.
  20. Chairboy
    10 Jun 2004
    Love it! :)
