Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    Mate seen this on cpc and as ever a lovly product or artwork. well done keep it comming i love it.
  2. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    just wow! this projekt are realy 100% kick ass!
  3. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Thanks guys :D
    Josh
  4. Rozzy
    Rozzy I'll get there :P
    1 May 2008
    This is really starting to take shape now, its really looking amazing!
  5. x06jsp
    2 Apr 2007
    Thanks rozzy :D
    Josh
  6. x06jsp
    2 Apr 2007
    Well as i said i am back with another update :D
    and i started by marking up the acrylic to cut the acrylic accents
    and cut them
    and then got to sanding and polishing them
    i didnt have time to do the fourth one so i will do that tomorrow and get them mounted so that i have finished another module :D
    Josh
  7. x06jsp
    2 Apr 2007
    Hey guys update time :D
    I got the last bit of acrylic for the psu housing polished
    I then got them all mounted
    All my completed modules so far
    I then got the other bits of acrylic for the rad housing polished up
    And mounted
    Tomorrow i will be making and mounting the front and back of the rad housing.
    Josh
  8. x06jsp
    2 Apr 2007
    Well im back for another update :D
    I started off today by cutting new front and back end pieces for the rad housing
    I then got them mounted up
    And then i grabbed some mesh and cut it to size
    I then marked the hole i need to make on the rad housing
    Took it apart
    and then cut
    I still need to file that down so i will get that done first thing monday morning :D
    And i also got a bit bored so i decided to start on a decorative dagger thing (it wont be used as a dagger!)
    Initial cut
    I then started to give it a bit of a sharpen (note i wont be able to sharpen this properly as it is alu not anything like stainless steel allthough i am thinking of buying some so i can make a proper dagger of my own :D
    How it is held
    I will probably cut 2 bits of black acrylic to put either side of the handle aswell
    And thats it for today :D
    Josh
  9. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    lol that thing looks highly iligal :p lol kepp it up :D
  10. x06jsp
    2 Apr 2007
    Thanks mate but its not illegal its decorative and the only sharp bit of it is the point of the end :D but i will be hopefully getting siome stainless steel so i can make some more better ones :D
    Josh
  11. x06jsp
    2 Apr 2007
    Ok midday update :D there may be an update later but i dont know yet
    i started where i left off last week and filed down the cutout on the rad housing
    and then i mounted the mesh so that the rad housing is finished apart from the struts for the rad
    I then took a break to bake this for my family its an apple crumble :D i love em that will be devoured tonight after tea
    i then moved on to the pump housing and got the front mounts mounted to the module
    then i fitted the front
    then i mounted the back
    finished
    the only bits i have to do on the modules is cut the cable management and the tubing holes and then on the pump/res housing i have to cut the front panel for the res im using but i cant do that yet as i cant afford the res... buttttt that is it and other than that i just have to make supports :D
    so im nearly there now
    Josh
  12. Cheapskate
    13 May 2007
    Nice.:D It's getting to the point that you should start doing pics of everything together at the end of each log. (HINT!)
    Mostly because I'm feeble minded and can't tell which part you are working on anymore.
  13. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    From the size of this thing, you should be able to fit several computers in it!!!
  14. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Jeez, Josh....I walk away for a bit to concentrate on my own logs, and I find all this progress! It's really coming together, mate. Is it already starting to feel heavy?
    *like Homer Simpson*....mmm....Apple crumble...... :baby:
  15. x06jsp
    2 Apr 2007
    Haha yer i will :D thanks cheaps :thumb:
    lol i would be able to fit many small pcs in it but im not going to lol :D
    Lol yer mate i have been getting a lot done lately :D and i weighed it and without all the supports or any hardware or watercooling hardware it is 12.5 kg :D
    Thanks guys :D
    Josh
  16. x06jsp
    2 Apr 2007
    Ok well on with todays update :D
    I started this yesterday but hey,
    I started off by getting out my tile cutter
    and attempting to cut the acrylic straight it didnt really work
    So i then used the score and snap technique that i learned from syrillian and its very very effective
    So i was quickly able to do these yesterday
    Then this morning i got the rest of the 56 black pieces done :D
    so now i just need to do the 42 green bits and then i will be ready to start the proper work on them :D
    Josh
  17. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Damn that's a lot of plexi, nice :D I really have to get myself a decent table saw, I can imagine it saves so much time. If it works properly, off course ;)
  18. x06jsp
    2 Apr 2007
    lol yer i would really love a bandsaw but i cant afford it atm :D
    thanks mate :thumb:
    Josh
  19. x06jsp
    2 Apr 2007
    Very very small update today
    i bassically only got just over an hour to do work soooo i managed to get 24 out of the 42 bits of green cut out (enough for 8 of the 14 supports) so here are the 2 photos the second is all the bits to make up 8 of the supports just thought i would show how much acrylic there is there lol
    Thats it for today i will get the rest cut tomorrow morning and then start gluing :D
    Josh
  20. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    that's just an insane amount of acrylic... :thumb: though for all your patience with it!
