Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Lol thanks :D
    Josh
  2. x06jsp
    2 Apr 2007
    Woop midday update guys :D
    i started out by cutting the rest of the green pieces and ended with this
    And i have just started gluing bits together to make the supports
    Thats it so far i will be gluing more after ive eaten but i will show you how many i get done :D
    Josh
  3. x06jsp
    2 Apr 2007
    Ok well here is the rest of the update :D
    I continued gluing...
    That there is 1.5 hours worth of gluing :D lol fun day!
    and this is roughly how they will be arranged :D
    psu+hdd
    Rad on top of pump/res
    hdd on top of psu again :D
    and thats it for today. ill be back next week to do more
    Josh
  4. jhanlon303
    7 Sep 2006
    I'm seeing pieces coming together here. This is verra nice. Take a rest.
    John
    PS: Thanks for trying to tell us what was hooking to what! I get confused and and have to do the first page sketchup click back. Hard on an old man. Just shweet.
  5. p3ri0d
    p3ri0d What's a Dremel?
    9 Jul 2008
    That thing is just great ;D
    It's ultimate Cheesecake
  6. x06jsp
    2 Apr 2007
    Thanks guys :D
    And John dont worry im having a nice relaxing weekend :thumb:
    Josh
  7. x06jsp
    2 Apr 2007
    Hey guys im back with another update :D
    I decided this morning that i would make the supports a bit simpler so i am not drilling holes in them and they are a slightly different shape but it like it and it means that i can just about cut them on my scroll saw then i just need to use my belt sander to flatten them down
    and then i got them polished (ill get better macro shots another day
    i then drilled and tapped them.
    attached the first
    And the rest
    Then after a while i had this done :D rad,pump/res and mobo
    Thats it for today so i will hopefully get at least the next four done tomorrow and i hope to have these supports completed by thurs then i need to make the support that runs between the rad and hdd housings to hold the dvd housing.
    then i need to wait for money so that i can buy my cable management stuff then i just need to get it painted and its done :D
    Josh
  8. Guest-23315
    Guest-23315 Guest
    It looks lovely and all, but I can't help that think extruded/turned Aluminium would have look better.
  9. skullen
    skullen Minimodder
    31 Oct 2007
    Its coming together very nicely,nice one x06jsp :thumb:
  10. ComputerKing
    8 Sep 2006
    Very hot! I love it. You are doing a nice job buddy. well done.
  11. x06jsp
    2 Apr 2007
    Lol maybe so but..... i cant afford to get my mill yet :D
    thanks mate :D
    Thanks
    Josh
  12. x06jsp
    2 Apr 2007
    Hey guys well i have got the hdd mounted to the psu housing :D
    support before polishing after sanding
    and polished
    Attached to the psu housing
    And attached to the hdd housing :D
    so there we have it all i have left for these supports is putting feet on the psu housing and then joining that double section to the rest of it then i just have to make the supports for the dvd housing then all fabrication is done :D :D
    And i maybe be able to buy some of the stuff for cable management this week/next week
    Josh
  13. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    It's becoming a really really nice case, but how are you going to do the wiring and tubing?
  14. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    very special case and all the plexi whoa nice :D
  15. x06jsp
    2 Apr 2007
    Thanks guys And binkz0r i am going to be running black watercooling tubes between the psu housing and other housings with cable extensions in that will be part of the case so that i can just plug the psu in inside the psu housing and then the watercooling tubing will just be routed whichever way seems best :D
    Josh
  16. Cheapskate
    13 May 2007
    Oh, Sh- I had an image of this thing made with heatsinks!
  17. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    NO CHEAPSKATE! NO!
    :p
    Looking good so far Josh... probably the most obvious thing in the world but it'll look a million times better without that protective film over the plexi :)
  18. x06jsp
    2 Apr 2007
    Lol thanks guys :D (and cheap dont worry one day soon ill have my mill and ill be using that a lot in my projects :thumb:
    Josh
  19. x06jsp
    2 Apr 2007
    Well guys im back with yet another update :D
    So i got the four supports that will be the feet of the psu housing :D
    Marking out where i want them to go
    Mounted
    This is how far i am now the only bits i need to join are the supports between the psu and the mobo :D
    and i had a bit more time soooooo i cut and polished the supports that will be going between the psu and mobo :D
    And i will mount them on friday.
    Josh
  20. x06jsp
    2 Apr 2007
    Well guys another update and its a goodun :D
    All the last acrylis supports drilled
    and secured to the mobo housing
    and then secured to the psu housing :D
    then i polished up another rectangle of acrylic
    and cut the rod of arylic i had into two
    and then secured together along with a bit of alu angle
    and attached to the hdd housing
    angle and acrylic then attached to the rad housing
    woop
    then layout
    and secured
    and i can just about lift it!! lol its heavy and i have to get a board for it to sit on so i will barely be able to lift the case alone when its done lol!
    Now there really is only wiring and painting to do :D
    Hope you like this update i know i do!
    Josh
