Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. ComputerKing
    8 Sep 2006
    buddy all I can say is well done :D kick ass job :) I really fall in love with your work. it's nice.
    take care and keep it going
  2. jhanlon303
    7 Sep 2006
    Better and better, Josh. This as awesome. :jawdrop: You want to holdoff buying that mill until you get the forklift. Going be heavy when electronics all in! LOL
    Looks like first page.
  3. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Thanks guys :D
    Josh
  4. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    You, sir, ROCK!!!!!! :rock:
  5. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    beautifully planned amazing hope you will fill that thing up with some amzing things ! are you gonna hit some water cooling in it or is that planned for a later time
  6. x06jsp
    2 Apr 2007
    Thanks guys :D and Pks yes its having some watercooling :D
    it should look the biz when its done :thumb:
    Josh
  7. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    m8t what can 1 say ...... ill just air fix my jaw back on later.
  8. x06jsp
    2 Apr 2007
    Lol thanks :D
    Josh
  9. skullen
    skullen Minimodder
    31 Oct 2007
    Its looking the part now :thumb:
  10. x06jsp
    2 Apr 2007
    Thanks skullen :D
    Josh
  11. x06jsp
    2 Apr 2007
    Guys i need a really quick answer is it ok to use wire that is slightly thinner than 18awg on extension cables for powering bits?
    Josh
  12. x06jsp
    2 Apr 2007
    Hey look more room :D (it looks like there is less than there is in the pic trust me there is more :D)
    And i dont need to buy a board anymore my dad found me one Just gotta chop it a bit.
    my p4 extension cable
    I then drilled the hole for my power button that i havent been able to buy yet
    and i made up a mounting plate
    And then i tried out my thinner cable with a normal molex extension (not very pretty but it works :D)
    Josh
  13. Zorndar
    Zorndar What's a Dremel?
    26 May 2008
    Looks pretty sweet in daylight. Cant wait for the final shoots.
    Nice 400D by the way ;)
  14. x06jsp
    2 Apr 2007
    Thanks mate :D
    Josh
  15. x06jsp
    2 Apr 2007
    Another small update :D
    i cut out 2 rectangles of black acrylic
    Polished
    and then put one with the green its going with
    it needed a bit of filing down to be uniform
    and in place:D
    I got started on the second one and i just need to polish it up now and i will show that one installed tomorrow :D
    Hope you liked it
    Josh
  16. ComputerKing
    8 Sep 2006
    I wish If I had a work space like you :( I mean basement :( I do my mods in my bed room :( not fair.
  17. x06jsp
    2 Apr 2007
    Lol thanks mate :D its our garage not a basement though :thumb:
    I love it its a kl space to have to myself :D
    Josh
  18. jesterod
    jesterod What's a Dremel?
    11 Oct 2008
    what kind of power switch are you going to use?
  19. x06jsp
    2 Apr 2007
  20. x06jsp
    2 Apr 2007
    On with the next update :D
    i got the second support for the dvd housing polished up
    and mounted
    i then measured the bits of cable i will need going from the psu housing with string this isnt all of the cables either and it is about 7 meters worth of cable (which means i need nearly that of tubing for just these bits...i have ordered 4! lol)
    p4 cable extended to 1.13m (tested aswell :D)
    and sleeved
    Thats it so far :D
    Josh
