Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Gorgeous work, mate! I'm guessing a bulgin for the switch mounted up on top of the custom rise?
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Yer jeremy im using a black bulgin with a green ring mounted on the front of the mobo housing :D
    Josh
  3. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    nice details and amazing work done with the plexi :jawdrop:
    I subscribe great works :clap: :thumb:
  4. x06jsp
    2 Apr 2007
    Thanks mate :D
    Josh
  5. jhanlon303
    7 Sep 2006
    Great work! That said, I'd like to make a comment about the DVD mount. The Drive part is excellent as is/are the external laminated mounts to the horizontal plate that connects the modules. Here's my thoughts. The horizontal rods are cool but the big flat plate the DVD sits on doesn't seen open enough to match the rest of the mod. Maybe just use enough of the plate to secure the DVD 'legs' to the connecting rods. Doesn't seem to 'float' enough. Minimize the flat plate to smaller separate mounts and let the module just rest on the rods. Seriously cool the way it is but my $0.02. What do I know.
    This plate:
  6. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I'll add $0.02 to that comment, exactly my thoughts.
  7. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    i think i mentioned the same thing in the design phase. I've been following this mod closely, and i'll be damned if you don't make a killer digg article when done, but i completely agree on the DVD mount: it needs rework into a more open format.
    :clap:
  8. x06jsp
    2 Apr 2007
    Ok thanks for the comments guys ill take it on board and work on that today :thumb: And also thanks for the encouragement and if it does get a digg article that would be awesome :D
    Josh
  9. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    this thing is amazing! very cool to see it take shape from your sketch up's.
    wireing this thing is going to be a bitch, but so worth it!
  10. x06jsp
    2 Apr 2007
    Thanks mate :D and wiring shouldnt be too bad im just needing ridiculously long cables....
    Next update in a few mins :D
    Josh
  11. Tec_
    26 Feb 2008
    lots and lots of soldering or making new cabels with molex ends and spools of wires
  12. x06jsp
    2 Apr 2007
    Lol yer....
    Well on with yet another update :D
    I took on board some suggestions about making the mounting plate of the dvd drive smaller and got on with that today.
    First i had to cut some longer bolts to go in place of shorter ones that were holding the green and black bits to the rods as the short ones were now too short. and i removed the protective wrapping that was on the rods
    I then shortened one side of the dvd mount
    And then i did the other one and mounted the dvd housing notice how now you can hardly see the mounts compared to the massive sheet :D
    I then removed the protective bits that were on the mounts
    My tubing hasnt arrived today so hopefully it will arrive tomorrow....
    And thats it :D
    Josh
  13. Xtrafresh
    27 Dec 2007
    oh wow, this is MUCH better :clap:
    I hardly understood what was going on untill i saw the last picture. Great cleanup on design there!
  14. x06jsp
    2 Apr 2007
    Thanks mate :D and yer it now looks alot more floaty :D and i love how polished the rods look :thumb:
  15. jhanlon303
    7 Sep 2006
    That's the idea - floaty!
  16. x06jsp
    2 Apr 2007
    Lol thanks mate :D
    Josh
  17. Xtrafresh
    27 Dec 2007
    are we making up words again?
    It would be good design challenge: a PC of which all the elements appear to float in thin air :D
  18. x06jsp
    2 Apr 2007
    Lol floaty is so a word..... but yer that would be kl to do :thumb:
    Josh
  19. Fumduck
    Fumduck Have torch, will melt.
    5 Aug 2008
    :worried:
  20. x06jsp
    2 Apr 2007
    Lol!!!
