Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    That's better already, but I would like something like this better:
    This would make the mounting sheets unnecessary, and would make it all look a lot cleaner :)
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    I would do that but i do like it the way it is now so i think ill stick with it as it is.
    Thanks anyways :thumb:
    Josh
  3. x06jsp
    2 Apr 2007
    OH god ive been relixed!!!
    And on with the update :D
    well here is my tubing
    And the first section cut long enough with the p4 connector through
    I then cut the holes in the front of the psu housing
    and then all the holes i will need in the back plate including watercooling holes
    and here is the first hose through the p4 connector (it is not secured yet as i have to wait for the case to be painted before i can secure it)
    Then i cut more hose there is the p4 connector one, the one for the atx cable and one for a dual molex that will then plug into 2 extensions that will go from the mobo housing to the rad and pump housing as power for the fans and pump
    I then cut one for the sata power cable for my dvd drive
    front of the psu so far
    and here is an image from the back to show you whats going on so far :D
    Crazy huh :D
    I have worked out i need about 5 more meters of tubing that i will have to wait untill the end of the month to get as i am out of money :(
    And thats it for today as always comments :D
    Josh
  4. jhanlon303
    7 Sep 2006
    I see some real hose management opportunities here. Grab the plexi and make hose keepers like the billet alum. spark plug wire keepers on the show car engines. That's a LOT of hoses dude. :jawdrop:
  5. x06jsp
    2 Apr 2007
    Lol yer it is :D
    and hmmmm i will try that out and see if i like it :thumb:
    Josh
  6. Cheapskate
    13 May 2007
    Or you could make the bit that holds your cd up one solid-single-layered-part, drill holes in it, and run the hoses through that.
  7. x06jsp
    2 Apr 2007
    Nah im gunna leave the dvd housing as it is now :D
    Josh
  8. Attila
    Attila still thinking....
    22 Feb 2008
    I gotta say this is looking amazing, as those hoses go in
    it starts to look more organic, alive even. :eeek:
  9. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    It's just a beast :eek: personally I'd have had the tubes going in the sides and tops of things, but each to their own, it still looks awesome
    Are you threading the tubing through any of that green wire tubing reinforcement stuff by any chance? (just to keep the colour scheme)
  10. x06jsp
    2 Apr 2007
    Thanks :D :thumb:
    Yer the reason i dont have the wiring going in the top is becase of the window there is no room and the sides there isnt room because of the supports :D and i may add green coil springs i dont know yet :D
    Josh
  11. x06jsp
    2 Apr 2007
    Well ive got more tubing and some 18awg wire on the way to me :D so there is now no need to worry about making the cables thinner :D
    Josh
  12. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Looks great - I'd got to say.
    But.. there's going to be one hell of a tube-mess to connect all these bits :jawdrop:
    I'd vote for cheapskates suggestion, would really be a great idea :)
  13. x06jsp
    2 Apr 2007
    Im looking at making some sort of tube holder to tame the beast but if it doesnt work out i dont mind the organic look :thumb:
    Josh
  14. DuVeL
    DuVeL What's a Dremel?
    4 Apr 2007
    I wonder what the size is and the weight in the end.
    It starts to look a bit like a spacestation to be honoust.
    /Starts following this thread...
  15. x06jsp
    2 Apr 2007
    Lol thanks :D and size will stay the same it is roughly 90x50x55cm :D and itll be heavy
    Josh
  16. x06jsp
    2 Apr 2007
    Update time :D
    First the wire and tubing that arrived on saturday
    The tubing for the molex for the hdds
    All the sata tubing done aswell 2 from the hdd housing and 1 from the dvd housing both to the mobo housing.
    and the pci e power tubing
    and from the back
    the starting of the tubing tamer
    polished
    so good that you can see all the way through perfectly :D
    marked out for holes
    and one of the holes cut
    Thats it so far (more tomorrow)
    Josh
  17. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Awesome, Josh. Personally, I like the tubing like it is.
  18. x06jsp
    2 Apr 2007
    So do i but if this makes it look better then so be it :D
    i wont make it permanent untill i have decided if i want it as it is or with the tamer :D (but i do love the 1cm thick acrylic)
    Whichever i decide it will look better with green coilsprings and paint :thumb:
    Josh
  19. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Nice all the tube and a serious cable management ;)
  20. x06jsp
    2 Apr 2007
    Thanks mate :D btw loving your project :D
    Josh
