Scratch Build – In Progress [Project] Modularis Evolution... updated alot!!! nearing completion!
Discussion in 'Project Logs' started by x06jsp, 4 Jul 2008.
  1. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    to tell you the truth not being mean but you could do a better job on the words modularis evolution.. other than that pure sexy!!!
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Lol dont worry thats being redone :D
    Josh
  3. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    loving the res josh where did you get that from?
  4. x06jsp
    2 Apr 2007
  5. x06jsp
    2 Apr 2007
    Update time :D
    I started off today by cutting the 4" hole in the front of the res/pump housing for the res
    i then got it drilled and tapped and fitted the res
    mounted
    i then decided to see what it would be like with the pump in there aswell and it looks fine to me plenty of room :D
    I am contemplating whether to do a window in the side of this module so you can see inside. and also im considering wether to cut some green to go ontop of the front facia of the res..
    and also it is starting to look like i may have to paint these cases myself as i cant get hold of my airbrush artist and i cant afford another guy as my guy was doing them as a favour but oh well it just means i will have to miss out on the green metallic flakes.
    Josh
  6. bradders2125
    bradders2125 What's a Dremel?
    14 Jul 2008
    Check out dupli-color they do metal speck paints and effex which adds glitter to the paint.
  7. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    That idea of a window screams "green tinted plexi"
    still looking immense:)
  8. x06jsp
    2 Apr 2007
    Thanks i will look it up :D
    Thanks mate :D
    Josh
  9. camera man
    camera man What's a Dremel?
    3 Nov 2008
    looks awsome cant wait to see it finished how did you come up with the idea??
  10. x06jsp
    2 Apr 2007
    Thanks mate :D ummm i dont know really it just came to me :D
    Josh
  11. Cheapskate
    13 May 2007
    You have enough room for a full diorama in the pump housing.
  12. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Josh, have you had any issues with those res's? Like anything in terms of flow issues or anything? I like the look of it; it fits your build perfectly where it's placed. It reminds me of a shortened Aquatube or something, but I suspect high-flow systems would have issues with it. I'm curious what your take on it is.
  13. jhanlon303
    7 Sep 2006
    Josh, Go get some tiny figures and put them inside like the Nautilus engine room from the movies.
    Watched it last night on Netflix
    John
  14. x06jsp
    2 Apr 2007
    Lol :D it had to be this big because of tubing radius' etc :thumb:
    I havent actually ever used one or tested this one yet so im not sure but i will let you know when i get it all plumed in :D and yer it is bassically a shortened aquatube it is another of ac's res they do.
    Lol
    Josh
  15. slap-o-mite
    slap-o-mite What's a Dremel?
    14 Nov 2008
    Nice build , very innovative , seems to make ppl look twice & wonder ..
  16. x06jsp
    2 Apr 2007
    thanks mate :D
    Josh
  17. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    dude, you have so much space left there, some nice potential :)
    Dont add any green to the front of this module, i like how the res is color-coordinated with the tubes on the other side.
    Maybe a fancontroller and a small screen (VFD or LCD) to display various temperatures? It would make sense if you concider that the PC is sitting right of the user most of the times, so you'd have a nice view on it, and buttons will be easily reached.
    In the most extreme case you could get a 5 or 7 inch TFT and display a custom samurize install there :thumb:
    In any case, keep modding! :thumb:
  18. x06jsp
    2 Apr 2007
    Thanks mate :D tbh i dont need a fan controller as the fans i use are quiet enough for me anyway... and i just dont have to money for a screen ..... but thanks for the advice. i may think of something to add
    Josh
  19. x06jsp
    2 Apr 2007
    Update time :D
    Well i got to work on the facia of the res mount today
    So first things first is was to disassemble the res
    I then drew around the original mount
    And if anyone was wondering what i look like on a normal cold day in the south of england here you go :p
    After a while of cutting i have this
    And drilled and assembled
    And thats it for today i will hopefully get my mini window done on the pump/res housing tomorrow
    Josh
  20. x06jsp
    2 Apr 2007
    Another update for you lovely people :D
    I marked out the area for cutting on the side panel of the pump housing
    and the acrylic
    acrylic cut
    and after more cutting and filing i have the side panel cut
    and mounted
    and also i found some satin black left over from ages ago along with some primer so i thought i would just test it out this is with 1 coat of each and the only prep was a very quick rub down with some 320g sandpaper it turned out pretty much perfect :D but its very hard to photograph
    Thats it for today unfortunately
    Josh
