Case Mod - In Progress Project: Mustang Cobra GT500
Discussion in 'Project Logs' started by TheGreatSatan, 9 Nov 2010.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    (This project started 6 days ago)
    I did just say in another thread that I haven't had the time to work on my mod, but this is different. At the Micro Center where I work, we usually have a computer with great specs on display for the customers to check out and enjoy. At the moment we have nothing on display, but the manager wants us to throw something together. He also wants it to be "different", so I'm doing a custom Cobra GT500 theme case with the dual white stripes going up the front and across the top. I will be painting everything else flat black.
    I chose the Coolermaster 690 since it's a case that we sell and it's not all that pricey. The employee cost was $50.
    Oh, and I plan on finishing within 10 days!
    Here's the case on Newegg
    Here's the inside top panel. It's ugly and will be modded as well
    The inputs have been removed as I prep for painting
    The whole interior will be flat black. There's a lot of painting left to do once I get some more!
    murraynt and DeadP1xels like this.
  2. TheGreatSatan
    5 Aug 2005
    This is the goofy pattern on the inside top and front
    I used a wire cutter to remove the pattern and then a sanding block on my dremel to smooth out the edges
    Then I taped up the top for painting
    And added a few coats of flat white paint
    Three hours later the tape came off
    Next, I removed the filters from the front bay covers so when I paint on the other side it doesn't leak through
    And I peeled off the Coolermaster logo on the front
    The front is then taped off too
    I also taped off the side panel where I'll cut the window
  3. TheGreatSatan
    5 Aug 2005
    I put the inputs back into the top panel
    And then reconnected the painted panels on the case
    Now that the paint is dry within the case I put the bay clips and screws back in
    The backplates are getting painted too.
    I got an actual Cobra logo from Ford
    The lettering is 2" and applying it is easy
    This is the same striping used for cars
    I carefully cut more than enough to mold
    I was happy to get a flat edge with the striping
    Now comes the big one. I had to cut it from 6" to 2"
    We're nearing the end!
  4. CoolModder2010
    CoolModder2010 New Member
    7 Nov 2010
    Dude I love the GT 500!! And if the case looks half as good as the car, its gonna be mean. The only thing Im not caring so much for is that you painted the stripes over the front and top but you used vinyl on the side, looks a little odd to me but it could just be the pic. Otherwise very nice. Cheers
  5. TheGreatSatan
    5 Aug 2005
    I taped off the side panel where I want to put the window and then clamped a ruler along its edge to keep my dremel on the right path
    And it only takes about 10 minutes
    Then I grab a large piece of plexi to size up
    Once the window edges are filed down and the holes for the rivets are drilled, I add a coat of paint
    While the paint dries I go back to the other panel and use an epoxy to add an automobile filter that will later be used in conjunction with an intake fan
    Now that the paint is dry I can add the window I cut with rivets and these little pieces of metal I cut from the old side panel
    They'll take the pressure from the rivets off of the glass to prevent it from cracking
    I still have to be careful putting them in because I could easily scratch the glass or damage the paint
    Here's where I'm at right now
  6. TheGreatSatan
    5 Aug 2005
    So, I've been thinking that plain old thumbscrews weren't going to be good enough this time
    Then I found that they actually sell cool cobra tire valve caps. I'm going to make my own thumbscrews!
    I just have to add a little QuickSteel and a regular case screw
    Now I just have to let them dry
    Now that they're dry I put them in the case
  7. mav2000
    mav2000 In Training
    16 Oct 2010
    Looking great....super stuff
  8. TheGreatSatan
    5 Aug 2005
    For the most part, the store will supply the inyards, but in this case I had to supply the fan for the rear of the motherboard/processor. I needed it to be a thin 15mm fan to fit behind the right panel and it had to light up to make good use of the air filter on the side of the case.
    It lights up the filter very nicely
    Even in complete darkness
  9. stonedsurd
    11 Mar 2009
    Damn, very nicely done!
  10. bulldogjeff
    2 Mar 2010
    Looking good, that filter mods different:thumb:
  11. craigr1982
    craigr1982 New Member
    29 Jun 2006
    Nice work TGS :)
  12. jprykov
    jprykov New Member
    29 Oct 2010
    nice work! :)
  13. DeadP1xels
    DeadP1xels Music Enthusiast
    30 Nov 2009
    Coooooool
  14. Bounty`
    Bounty` New Member
    10 Nov 2010
    Gt500 is an epic car, and this is looking to be an epic case :)
  15. LatinSpirit
    LatinSpirit Member
    23 Apr 2009
    Very nicely done, I have been wantng to put stripes on my next case for a long time!
  16. TheGreatSatan
    5 Aug 2005
    Now's a good time!
  17. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Love the case, love the mustang, hate the filter. It doesn't look like it belongs there.
    Wonderful job with the pin strips btw
  18. Skorchio
    Skorchio New Member
    16 Oct 2009
    Love that Filter mod :)
  19. TheGreatSatan
    5 Aug 2005
    My Ford logo arrived
    And so did my Cobra Engine decal
    My mods are a piece of art, so I always sign them
    And I am done!
    This case will be on display at Micro Center in Brentwood, Missouri.
  20. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    First of all the car pictured is a mustang gt. NOT a gt500. Two different animals.
    Secondly, this is not a mod, this is a paint and stick deal. Being that its a paint and stick deal, I expect the lines to be straight & the case to be prepped if your going to spray it. You did neither.
    So it lacks originality, precision and creativity. I am sure Chinese case manufacturers are going to eat this up.
    PS get rid of the ford logo, it does not belong there. The mustang is built with pride.... not built like a Chinese toy. :duh:
