Project: Mystique by Koradhil [ Completed ]
Discussion in 'Project Logs' started by Koradhil, 3 Feb 2007.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Great job on the block!!!
  2. frankee
    frankee What's a Dremel?
    6 Feb 2007
    ^ what they said :)
  3. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Thanks all :)
    Hey is it just me, or is Bit-Tech extremely slow today?
    Update: I've now installed the cooler on the card:
    The block is mounted with M3 hex bolts screwed into the mounting holes of a Fatal1ty VGA cooler. The block is pushed against the card by springs taken from ballpoint pens. Simple but effective :) The fact that the memory lost its cooling is not a problem, because the system is going to run Linux anyway.
    Also decided not to countersink the holes because that would make the outer holes get too close to the edge.
  4. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    nice work,
    I also like your fanbus-idea, imho it'll look great!
  5. Koradhil
    9 Nov 2004
    I'm thinking of giving this mod a different name. Maybe you guys have any good ideas ?
  6. Evenge
    Evenge Minimodder
    16 Sep 2006
    Green Beast would sound nice! :D
  7. Koradhil
    9 Nov 2004
    Hmm, not really what I see in it. I'm looking for something that sticks with the mystic theme and the green. I don't really like naming the color either.
    I needed a name because Cooler Master has asked me for some information that they will print on a nameplate for CeBIT. This casemod will be on display at the Cooler Master stand at CeBIT this year. Because they needed the info today I'm sticking with Mystique for now.
  8. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Fantastic job. Keep it going. I want to see the finished product (Im sure you do too! LOL). :cooldude:
  9. Koradhil
    9 Nov 2004
    Today I've been working on the watercooling. I remade the cover of the CPU block because I wasn't satisfied with the last one. I chose to make it a reclangle instead.
    Installed it all inside the case:
    Last but not least, I bought an Acer AL2216W 22" widescreen TFT.
  10. Guest-23315
    Guest-23315 Guest
    Very nice curves on the tubing going into the CPU.
    looks very nice. :D
  11. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    Gave mod man, ff een vraagje...waar woon je in hengelo ? Daar woon ik namelijk ook :p
  12. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    very cool stuff with the waterblock!
    Aww why no clear tubing?
  13. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    ok the mod is great!
    i just cant help but think that is a waste of a 6800GT core and 2GB of ram, just to run linux on and to only run every now and then.
    please stick some stinks on the memory, even if its only the stock cooler, it should still fit.
    no offence.
  14. Koradhil
    9 Nov 2004
    @1e8o: I live in the Vossenbelt (Londenstraat).
    @Damouse: I could have taken clear tubing but I wanted to use something more original.
    @Burnout21: Well I know that it will be a waste to use linux with a 6800GT and 2gb ram (I think I'm going to replace the ram with 2x512mb), but for me its not a problem. I have two machines at the moment and I'm going to build a new one after CeBIT, so I don't have any use for it. After the mod is done and used with casemod contests I'm going to sell it or give it away. About the ramcooling, I could stick the original ramcooler on, didn't think of that.
  15. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Congrats on the front page man.
  16. Koradhil
    9 Nov 2004
    Thanks, I just found out :D
    Only I'm not sponsored by ACRyan, but that's okay.
  17. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Great mod, very clean work so far. I love the fan/light switch bus too! Mind if I steal the idea?? :D
    Also, what kind of blade did you use on the scroll saw to cut the side panel?
  18. krimson
    krimson What's a Dremel?
    16 Nov 2006
    this is looking pretty good.. i was tempted to start hacking up my mystique, and this gives me a couple nice ideas!
    call it green myst?
  19. 1e8o
    13 Oct 2005
    Awesome mod :p
  20. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    The wb covers are awesome..specially the gpu plexi cover! :jawdrop:
