Project.:. MythTV Box>>Updated September 13
Discussion in 'Project Logs' started by sum41, 3 Sep 2005.
  1. Avner
    Avner What's a Dremel?
    19 Sep 2003
    :D :D :D
    :duh: :duh: :duh:
    hehe,
    take it easy,
    I have bent a few cathodes already (taking them out of the plastic tube first :hehe: )
    but they all finished by breaking....
    Good luck !!
    Av
  2. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    lol, u can't bend a cold cathode. And I believe they don't reacht too well on heat either. Just get some lovely EL wire!
    Good luck with the project!
    L
  3. sum41
    sum41 What's a Dremel?
    23 Dec 2003
    I got some good sand paper... 400 grit..so the bondo work is done and i've begun painting..Expect pics tonight of painting complete...I've found the paint doest take well to the plastic at first because its so smooth..But if i use a really fine steel wool pad and rub off loose paint, The paint stays good...
    I started to order stuff off of newegg but it was messed up big time! Im just gonna find somewhere else to buy stuff
  4. sum41
    23 Dec 2003
    I've been having trouble with the paint..It gets gritty and by the time i sand the grittiness off the paint is basically gone..And i have to do some bondo on front ...
    And I finnaly ordered stuff on newegg..I should have it early next week :)
    THE LIGHTS CAME
    A little preview:)
  5. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Can't say it's the gretest casemod I've seen, but It's a hell of a lot better than what the case used to look like. By the way, what brand are those CCFL's? I've got a red one, but it only glows pink:(
  6. trvr
    trvr What's a Dremel?
    7 Sep 2005
    looking good so far....keep it up!
  7. X_VADER_X
    X_VADER_X What's a Dremel?
    7 Sep 2005
    nice...
  8. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Not bad, for a dell :p
  9. shadowmob
    shadowmob What's a Dremel?
    3 Aug 2007
    I built a myth box from an L800cxe. I worked pretty well. Now the Dell is just the frontend and I run a separate backend. As long as you install the appropriate linux modules for the i810 video chipset you can use XvMC so that the video card will do most of the mpeg2 decoding. It works like a charm and play dvds great. I am going to upgrade to an Nvidia FX5500 and 512MB Ram just to get a little better performance overall. Other than that it is a great frontend machine. I got mine for free too and paid 100 bucks for the backend which is a celeron 2.5Ghz 1.25GB ram and 140GB of hdd space. Soon I am going to throw 2 500GB hdd's in it.
  10. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Aha, well, evidentally im not the only one to mod one of those p.o.s. dell boxes.
    and i did pretty much the same thing you did. but i replaced the mobo and psu in mine.
    bondo'd all the dell logo's and such.
    i had all the brackets for mine, and i put 3 hdd's in mine.(btw, it will stay in the verticle position if you use the screw from the fron of the case to the hdd.)
    i also cut the small grill off the right panel and put in a fan guard.
    Spec's
    SantaFe-Km W/ 1.4Ghz Socket A.
    512Mb Ram.
    Evga FX5200 128Mb
    2x 50Gb Hdd's
    1X 20Gb Hdd
    running:
    Red Hat With Freevo
    Windows XP MCE
  11. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Holy thread revival
  12. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    :0 omg i had like 12 of these exact computers (minus ram cept' for two of them i put 512 in) igot them out of the dumpsters they were from my A+ certification class.
