Case Mod - In Progress Project N.V. [FINAL pictures and video on page 10]
Discussion in 'Project Logs' started by p0Pe, 14 Jan 2013.
  1. Axoxenon
    Axoxenon Do it right the first time
    28 Dec 2012
    That gif was effin cool!
    Update is gonna be awesome!
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    After filling and bleeding the loop poor Pope suddenly realises he forgot the TIM. Local news reported extreme language heard up to 6 miles away during this event.
  3. Cheapskate
    13 May 2007
    Damn, you PopE! I swear I blacked out and watched that .gif for an hour.
  4. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Haha I see you posted that gif to /r/gamingpc too. Seems the the Bit-Tech projects have a habit of breaking their preconceptions. Really beautiful, this is going to be truly a beautiful machine, heck it already is!
  5. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    totaly amazing brow, TOTALY AMAZING !
  6. White-Fox
    White-Fox What's a Dremel?
    11 Feb 2013
    this is going to be ****ing AWESOME!! oh and the best of luck for you :)
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    SPERM colour Cheesecake!!!!
    Thanks for going with my suggestion, Hans Peder. ;)
    But: Green O-rings? Wouldn't white or black ones have been a better fit?
  8. ali_robb2000
    ali_robb2000 What's a Dremel?
    17 Feb 2003
    So cool - never seen anything like it! Awesome way to create a tidy setup around the ram blocks / CPU
    Looking forward to the next update!
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop::rock:
    I missed this somehow, looks a bit. :jawdrop::D:clap:
    Just a bit. :lol:
    Really glad to see this coming along. :)
    Heck of a beast of a system too, shweet. :D
  10. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Wow.
    Nice stuff!
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is utterly gorgeous. Nate did such an amazing job on those.
  12. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Glad you like it boys! Thanks for all the comments! I will post a quick update before I start packing. Have to go to a weekend trip to Jutland in a hour:D
    The motherboard blocks are DONE! And I would like to clear up a few things. There is two blocks sitting on top of the grafic cards, one that will lead flow parralel into the cards, and the other, smaller one, is a connector block to the motherboard South Bridge waterblock that has its in and outlet in between two of the grafic cards, hence why this has to be there (And of course because I think it looks damn awesome!)
    Top view of the completed thing. I am awaiting bitspower passtrough connectors So I can get it connected to the motherboard tray.
    Another glory shot. This should look really good and clean with the pass troughs and clear tubing. Just need to figure out something smart to get the cables looking good too.
    Of color in the cpu block, I am leaning against none transparent white fluid.
    But I had to check out my other options too:D
    The pump system. There will be four pumps in this build, connected two and two like this.
    The rear system will connect with the PSU showoff reservoir.
    Which looks like this from the back.
    And now for the grand finale, and one of the main features in this build! The 3 kilo dual loop reservoir!
    This was an absolute pain to design, and acording to Nate from E22.biz also quite "fun" to mill out.
    How it works I cannot explain, but when fluid gets in there you will see:)
    A shot from the front of the case. From my knowledge, this is the biggest and most complicated reservoir ever to be put into a computer.
    Another closeup of the middle of the res.
    And a shot from the bottom chamber that will house one of the loops.
    I hope you enjoyd this update! Next up is some hard tubing madness!
    Waynio likes this.
  13. Falqoon
    Falqoon Minimodder
    13 May 2013
    THE most BEAUTIFUL water cooling I've ever seen! :jawdrop: :thumb:
  14. Azariel
    Azariel What's a Dremel?
    23 Oct 2008
    Wow! That res looks stunning and I can only try to imagine how it would look with the loops attached to it!
    Also love the 'alternative tubing' solution! Might have to consider using that technique aswell...
  15. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Looks good Hans,cant help but think the deadspots in that res will cause you problems down the line tho.....
  16. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    There are no deadspots:) I just havent drilled in and outlet yet:D
  17. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    AMAZING, love it will be watching the rest of this build, awesome work mate :)
  18. White-Fox
    11 Feb 2013
    This will be one of the best mod's ive seen so far... and it's not even complete! :D good luck! :)
  19. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    Oh my .. no words dude
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hmmm, dual sided cool patterned monsteRes, will make more sense when water flows. :)
    Until then it's bleeping awesome. :D:rock:
    Ahhhh, not drilled in & out, that's why it didn't make total sense to me. :D
