Modding Project name? Please Help
Discussion in 'Modding' started by icutebluezone, 11 Aug 2010.
  1. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi all modders.
    Mark here. Just about to start a new project custom case build. Going to be using a cubit3 itx case as the start of it. Going to be replacing the front panel of the case 1st.
    Im trying to make a name to go on the front of it at the bottom.
    Anyone got any ideas on a name for this case?
    Couple i was thinking:
    Blackbox
    Cybercube
    Cypertech
    Hypercube
    Hypertech
    This is a picture of the case.
    The case has 5mm thick alloy front and back and the housing is 4mm.
    Will be laser cutting the name out of the alloy so has to be a font thats still got the dots in the QROPADB.
    Thanks and hope sumone can help out. :)
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    epicube
    pwnbox
    microgiant
    xitx
  3. Kenny_McCormick
    Kenny_McCormick Minimodder
    19 Sep 2006
    We mix them all and we've got... Cubetech!
  4. icutebluezone
    6 Aug 2007
    Can give a EPS file to scale if anyone wants to design up a front.
    Only thing you will have to watch is design has to be 5mm in for sides.
  5. vmast3r
    vmast3r What's a Dremel?
    9 Aug 2010
    Rounded Rectangle
  6. icutebluezone
    6 Aug 2007
    A bit long.
    I found a nice Font Im going to use. :)
  7. Nexxo
    23 Oct 2001
    lbs3
    (in a nice font, the "3" in superscript).
    Why?
    • 3 pounds is the weight of the human brain.
    • "lbs" can stand for "Little Black System" (or "Little Black Square" if you like)
    • 3 indicates that it is a three-dimensional shape: i.e. it has three axes, i.e. it's a cube.
    See what I did there? :p
  8. icutebluezone
    6 Aug 2007
    Very nice man. :) What a smarty pants.
  9. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    How in earth did you come up with that? :confused:
  10. Nexxo
    23 Oct 2001
    I'm weird.
  11. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Qbit? ...with the bit inside the Q :p
  12. bulldogjeff
    2 Mar 2010
    I think some ones got to much time on their hands:D
